Question about Toastmaster 3302 Iron
Need way to open the iron 3302
My 3302 iron fal on the floor and broke the the place to hold the screww to the base can you tell me how to open the iron to try to fix the problem the iron still work fine
  • 1 more comment
  • Charles Raheb Aug 01, 2007
    i could not get in
    please help
  • Charles Raheb Aug 02, 2007
    thanks but ceremic washer under the 2 screws insside are broken do you know what is called and can i get 2 of them
    charles
    it is fixed thanks
    charles
    Genius:
  • 2,985 Answers
Usually start at the cord end to locate internal screws to get top off then down to the next layer
Posted on Aug 01, 2007
  • Anonymous Aug 01, 2007
    As I said at the cord end is where it all starts.
    So at the cord end turn it over what is at the back of the sole plate ?
SOURCE:
My ultra T-fal iron is leaking right out of the iron, before I turn it on. Should I get a new iron, or can this be fixed?
I believe there`s faulty construction'and the cost to repair is about as costly as a new purchase.The valve that inhibits the water flow apparently is remaining open.
Mar 04, 2013 | Irons
Where do you put the water in for the steam?
The water fills through the hole on the front of the unit! Use a measuring cup and pour it in the hole....it should have a clear guage on the handle to show the water level.
May 07, 2011 | Toastmaster 3302 Iron
How do I clean the water reservoir in my T-FAL Avantis 90 iron. When I use the iron hard particles come out of the steam holes.
When empty, fill with white vinegar, let it heat up then hold the steam button down to let the vinegar run through the iron. Do this over the sink!! Then fill with water and repeat to rinse the vinegar out.
The vinegar will dissolve the mineral deposits in the iron.
Dec 07, 2010 | Tefal Avantis 90 Iron
Re: cleaning the iron
Here is a tip that will help you with cleaning the bottom of your iron...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Mar 07, 2010 | Tefal UltraGlide Easycord FV4256 Iron
T-fal ultra glide easy cord iron stopped working while ironing
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 03, 2009 | Tefal UltraGlide 1569 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Just stopped heating
Unless you have a 5 or 6 hundred dollar iron, there is an excellent rule of thumb when an iron quits working. Buy a new one. These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Oct 04, 2008 | Toastmaster 3302 Iron
Iron Problems
Penny,
Here is where you can download this manual:
http://common.csnstores.com/common/marketing/tmr1010_user_manual.pdf
Cheers!
Mike
Nov 20, 2007 | Toastmaster 3302 Iron
Toastmaster 3302 Iron Logo
316 people viewed this question
Top Toastmaster Irons Experts
Marvin
Marvin
Are you a Toastmaster Iron Expert? Answer questions, earn points and help others
