Question about Canon MultiPASS F50 All-In-One InkJet Printer
Cannot edit after scanning a document into MultiPass F50.
I was able to scan the image, but could not make changes to it.
  • 106 Answers
Hmmm. because it's a fix image... but try to use adobe photoshop to edit your work. ^^
Posted on Feb 04, 2009
How to change scanning from picture to pdf
once you have scanned the picture and saved it . right click on the picture icon. click edit. it should take you into a editing tool like paint . then click file . save as and then the bottom option you can change it to save as a pdf or png or jif, anything your heart desires
May 05, 2011 | Computers & Internet
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
Simply how to use the scanner which does not come with instructions. Many t hanks for your assistance
  • Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
  • Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
  • Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
  • Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
  • Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
  • Feb 21, 2011 | Office Equipment & Supplies
    Scan document into text
    Scanned documents are image documents and they need to be converted using an OCR program. The Optical Character Recognition program converts scanned image documents into a text file which you can open with a Word program and edit.
    You need OCR programs such as -
    OmniPage 17
    ReadSoft
    GOCR (freeware)
    Tesseract OCR (freeware)
    Microsoft Office Document Imaging (included in MicroSoft office Tools)
    May 11, 2010 | Epson ACULASER CX11NF All-In-One Printer
    UNABLE TO MAKE CORRECTIONS TO DOCUMENT
    Scanners put a graphic image on your computer that is a "picture" as far as the computer is concerned and therefore, you cannot edit text because it is seen as pixels and not characters. In order to make a scanned document editable, you'll need to use the OCR function in your software (Optical Character Recognition). This is assuming your printer came with OCR software, if not, you'll need to purchase an OCR software package in order to convert images into editable documents. You should be able to find such packages for less than $50.00. Check your documentation (and help files) and look for OCR in the index or search the help files for OCR to see if such software came with your printer software package.
    Jan 30, 2010 | HP Photosmart C4240 All-In-One InkJet...
    Looking for a canon f50 multipass reference manual. Reason: trying to use flatbed scanner to scan - not the automatic document feeder. automatic document feeder works. The article I wish to scan does not...
    To scan from the platen glass:
    1. Click the "Setting" icon on the multipass toolbar
    2. Select "Toolbar Settings" tab
    3.Under "Image Source", click the "Scan From" drop-down menu and select "Platen"
    Mar 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
    Scan a Document and Need to edit in Word 2007
    Most of the time a scanner by default, will scan a document in a tif or other image file format. That means that the scanned image is actually very similar to a photograph. In order to edit the text, you first have to convert the image using something that's called OCR software. OCR is a process that the software uses to look at a scanned document image and determine what characters are on the page. It's not always very accurate but that depends on the quality of the scan and on the OCR software being used. You must have received some sort of scanning software with the scanner. Hopefully it containes some sort of OCR software. Some scanners will save you this extra image manipulation by having a setting that allows you to scan directly to a word document. Usually in that configuration, the OCR software automatically knows to convert the scanned document image in order to automate the process. But either way, you first have to install the manufacturer's software. Hope this helps. Please remember to rate my answer. Thanks.
    Feb 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
    Canon MultiPASS F50 won't copy but will scan
    Does the copy function work if you place the document to be copied on the platen (open the cover and lay it on the glass)? If so, check the area to the left of the platen. There should be a strip of glass with a clear plastic cover over it. This area is used for scanning when feeding paper through the automatic document feeder (ADF) from the top. This area must be clean. If this area is clean and clear, it's possible that the scanner element (below the glass) is no longer going all the way to the left when using the ADF. This would be a problem that would require servicing.
    Oct 15, 2008 | Canon MultiPASS F50 All-In-One InkJet...
    I press scan it it wont scan my picture.
    1. To load a picture, lift the lid and place the original face down on the left front corner of the glass, with the sides of the picture touching the left and bottom edges.
    2. Close the lid
    Scanning a text document
    1. Load the original.
    2. From the HP Director , click Scan Document .
    3. From the HP Scanning dialog box, select the desired options and Scan to destination.
    4. A preview of the image will appear in the HP Scan window. Make any edits from the HP Scan window and click Accept .
    5. Click Scan . The document will open in the selected Scan to destination.
    Scanning a picture
    2. From the HP Director , click Scan Picture . A preview of the image will appear in the HP Scan window.
    3. Make any edits from the HP Scan window and click Accept . The HP PSC sends the scan to the HP Photo & Imaging Gallery , which automatically opens and displays the image. The HP Photo & Imaging Gallery has many tools to edit the scanned image. For more information about using the HP Photo & Imaging Gallery , see the onscreen help that came with the software.
    Stopping a scan To stop scanning, press Cancel on the front panel. Hope this helps. Good Luck.
    Apr 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
    OCR Instructions ??
    there are two places where this printer can store ocr files . the cache within the printer might be full , do empty old documents from the printer , and secondly it saves directly to your PC , a file or a folder has to be specified from the software , for it to dump the scanned file , In short you should remove your old documents and make space for new ones
    Nov 18, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
    Canon MultiPASS F50 All-In-One InkJet Printer Logo
    old marine
    old marine
