Question about RCA RCR311B Remote Control
Can't Reset TV Don"t have orginial Remote control for TV
I called RCA techinal Support to see if they could help. The problem is that I may have blocked out all the channel except one MSNBC. I have cable on all the other TV's which are on the same splitter. If the universal remote control I bought from walmart does not have a clear button. What can I do?
Please help
To completely clear the remote control's microprocessor:
Remove batteries and press the number 1 button for at least 60 seconds. Release the 1 button, replace the batteries and re-program the remote (if necessary).
Posted on May 11, 2009
  • 22 Answers
The remote must be programmed with the correct code. With the model you have, if something goes wrong or the code is lost it uses the last programmed code.
Go to:
http://66.77.167.109/rcaaccessories/RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_IDSTR_CATEGORY_UNIVERSAL_REMOTES&ACTION_PRODUCT_ID=RCR311S
and click the link for the manual.
If your code is not listed in the book (hard to say without knowing what brand TV you have) then you can use the remote code finder on the bottom left of the nav on the same page.
Posted on Feb 04, 2009
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
My RCA tv won't work without a remote, and I can't seem to reset since I don't have a menu button
Hello
If your TV has no menu button on its front panel, there is no other way than buying a universal or original remote control to this set.
Mar 04, 2012 | RCA Televison & Video
I locked myself out of my RCA 27F520T 27inch Tru
Hello
If you did forget the passcode to your RCA Tv, you can reset it. Simoultaneously press "VOL+" on the remote control, and "CH+" button on the front of the tV. The display will appear for you to enter your new password.
Mar 02, 2012 | RCA TruFlat 27F520T 27" TV
Codes for RCA RTD315
if you need a remote for the rtd315w you can use the RCA D771. Put the code in manually in the AUX 1. Use the codes from the audio system section of the manual under RCA and RCA/DIxxxx. I don't remember which code, but it gave me on/off, volume control, and DVD menu navigation (on the guide and goback buttons).
Dec 22, 2011 | Televison & Video
My fpa lock is on how do i get it off? Do not have the orginial remote
I just did this on my tv same exact model, I used a universal remote, it was an rca remote but im not sure it makes a difference. I programmed the remote to this tv with the tv off and it worked. the programming directions say to turn the tv on but i couldnt. If and when u get the tv on if u are using a universal remote get the menu up. most likely the light will be flashing. take the battery out and put it right back in. the light should no longer be flashing, and the menu should still be up. u can now navigate to the preferences and turn off the fpa lock... good luck
Apr 16, 2011 | RCA TruFlat 27F520T 27" TV
Remote
Here is the web site for the manual. Page 38 may have a solution. I hope this helps.
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Sep 08, 2008 | RCA TruFlat 27F520T 27" TV
I dont know the parental code and my color is messed up how do i fix it.
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
Bill
Jan 30, 2008 | RCA TruFlat 27F520T 27" TV
RCA 27V550T 27" TV
Problem fixed. I unplugged the TV for 20+ seconds, then before plugging it back in, I shorted ac plug prongs together with a metal key to ensure complete discharge. Plugged TV back in and used procedure to reset password WITH ONE CHANGE TO THE PROCEDURE.
With TV turned OFF press and hold <CLEAR> button on the remote while pressing <VOLUME DOWN> button on the TV, hold until TV turns on. When the menu appears DO NOT RESET THE PARENTAL CONTROL CODE as the user guide instructs. When my menu appeared it was in the SETUP screen on the LANGUAGE setting. It was set to SPANISH, using the remote I navigated to ENGLISH. Then using the remote I navigated up to GO BACK. Then I navigated to EXIT and hit <OK> button on the remote. All was back to normal.
Jan 10, 2008 | RCA 27V550T 27" TV
RCA RCR311B Remote Control Logo
150 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
