Question about Ricoh Aficio GX3050N Printer
Ink cartridges full but come up empty.
The following is the weight of each cartridge and the amount of ink as per the GX3050 printer.
Black 208 gr Full
Red 207 gr Empty
Yellow 206 gr Empty
Cyan 188 gr Half Full.
I have only printed about 20 pages.
The cartridges before did not last too long either, but I don't have the exact statistics. We have had the printer for about a year but it reads out of ink so soon that it is too expensive to use. I don't think these were really out of ink. If I could get a chip resetter then I could use them until they are really empty. Have not found one yet. What to do?
  • thgolding Feb 07, 2009
    I am using other printers. I bought the Ricoh after having read a lab report that it was the most economical from an ink consumption point of view. May be true except when it reads out of ink when it is not out of ink. I suppose it bothers me to have paid a few hundred dollars for a well built workhorse and not to be able to use it.
    It is a Ricoh GX3050N. True you cannot expect the first set to last too long. The second set did not last what I thought it should have. The third set is the one on my post of 02/04/2009. The cartridges go for about $45 each so that is $180 for a set of 4. So far that is $360 in ink for the printer that was the highest rated for being economical for ink consumption.
    Sergeant:
    Champion:
  • 289 Answers
Hi..the best solution to this problem
is by cleaning.so u first clean the catridge.
It will definitely workout.This is the main reason
for the problem.This will solve ur issue.
Try this out.
thank u..
Posted on Feb 07, 2009
  • Hariharanath V Feb 09, 2009
    hi..it is a better solution that you give ur
    printer for a service.
    try this out..
    thanks..
  • 6,487 Answers
Unplug and replug the cartridges back in and also if you haven't tried uninstalling and reinstall the printer software you can also try that just to make sure this is not a software problem...
  • 744 Answers
Hi as u know that purchasing a new cartridge will cost u more everytime... so its better see to that u purchase a more economical printer which will work for longer duration and costs u less...
    Master:
  • 474 Answers
Typically the ink that come with it out of the box, is usually half full or less, but the new ones should be full.
Is the printer connected via network or is it through paralle or USB ( connected directy)
If its directly connected you should be able to use the software to view the ink and be able to change the settings.
If its networked, you can IP into it by typing its IP address into the explorer address bar. Then you will go into it internal management which would allow you to make changes directly.
Also check for updates and be sure there arent any out there that need to be installed.
Also, are the ink cartdridges made by the same people who made the printer or are they knock offs?
What is the Brand and model of the printer?
Typically small home printers have expensive ink and you pay more for them than the printer, thats how they make all the money, they sell you a cheap printer thining its a good deal, then you find out later the ink is $50 or more.
I work on Dell,Lexmark and HPs and I find HP makes better quality. Dell printers are made by lexmark and lexmark stinks so stay away from those.
Posted on Feb 04, 2009
  • 679 Answers
Try cleaning cartage head using a thinner and also clean printer rod.
and let me know.
Thanks
  • rockfixya
    rockfixya Feb 04, 2009
    please let me know for further assistance.
    Thanks for using FixYa.
    Genius:
  • 2,920 Answers
The best thing you can do is go buy a new printer. you can buy one brand new for 40.00 and have one you can use thats not going to be expensive to use
  • Ronnie Houston Feb 07, 2009
    buy a new printer unless you want to keep going through ink like this.lexmark is pretty good and is about 40.00 new and the ink does last alot longer that i can promise you
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
How do i shut off the colored ink and use only black ink
You can't really "shut off" the color ink with this printer, but you can trick it. If you rarely or never print in color you can put in a full black cartridge and keep your empty color cartridge in the printer. As long as the electronics are still good on the color cartridge your printer will print and won't use any color. You can also set your printer properties to greyscale.
Jan 05, 2010 | Canon PIXMA iP1600 Printer
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
My C6280 printer says the black is empty but it is
Dear Sir,
Printer doesn't identify the ink accurately all these are controlled by software only.So it is showing your black cartridge is empty but trace amount of ink actually remained,by this you are getting black and white prints correctly.After the consumption of that trace amount of ink it may print black text as a greenish-brown because printing taking place only by means of color cartridges.So if you observed blurred text or greenish-brown text, now you can replace your ink cartridges.
i think it helps
good luck
Aug 11, 2009 | HP Office Equipment & Supplies
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
Can't print when there's only black ink
Mostly it connot print w/out color ink if when printer message empty / sometimes the printer no message while ink was empty still black can print. it depends to the chip .
Jan 11, 2008 | Xerox DocuPrint M750 InkJet Printer
Epson C66 won't print without color cartidges
epson printers won't really print if one cartridge is not detected or detected as empty. the only option that i can suggest to you is that, buy a continous ink kit at any ink refilling station in your place. i highly recommend that dont leave a cartridge empty with ink cause it might clog your printhead. using a continous ink system's cartridge is auto reset, whenever the printer says that the cartridge is empty, it will automatically resets itself. ink refill kit comes with 100+ml of ink per color i think. and it is much cheaper using original epson ink.
Sep 26, 2007 | Epson Stylus C66 Inkjet Printer
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Ricoh Aficio GX3050N Printer Logo
44 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
