Question about PC Connection Bulk Cable
I hav the problem that is my network connection
There is yellow triangle comes on the network , and a statement comes written that is Limited User or no connectivity.this is the statement
  • Darzu May 11, 2010
    Your computer is connected to a switch/router?
    Do you had this problem also in the past or it is the first time that you use this cable/connection?
    Your drivers are updated?
    Your NIC is on the motherboard or in a bus inserted (PCI/PCI-E)?
  • 63 Answers
Power off n On ur modem or router
Go to Control Panel- Network connections- Right click LAN connection- Disable & Re-enable it.
If it doesnt work- control panel- System- Hardware tab- Device maanger- Network adapter- Right click and Disable -Enable it.
It should work fine
Posted on Feb 04, 2009
Trying to connect to my wireless router belkin n150 with my laptop compaq presario 2500 have a yellow triangle saying limited or no connectivity
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Jan 01, 2013 | Computers & Internet
How to get rid of the yellow triangle
The yellow triangle means there is an https error. (https:// means the website is secure, while http:// denotes the connection is not secure). If you right click on the triangle it will give you a breakdown of what is causing the error.
Mar 27, 2012 | Facebook Social Network
When i go to sign into playstation network it loads for like 43 seconds and then it says "The connection with playstation Network timed out" what does this mean and i need to log into the...
this meant that u hav used it long before or logging is given to u only for limited period..u hav a check with your warrenty and nothing is problem then u can see this site to solve theissue..
Dec 02, 2010 | Sony Playstation 3 (PS3) Console
I installed my NetGear wireless USB adapter and the install went fine. It connected to my wireless modem/router that was provided by the ISP. The adapter recognized the network and had an excellent...
I would suspect either a bad password, some additional security settings on the router (like MAC filtering), or perhaps the DHCP server functionality not turned on in the router.
If you have an administrator password to the router, you can check it yourself, otherwise you have to contact the ISP for assistance in router setup.
Sep 08, 2010 | NetGear WG111 802.11g/b Wireless Adapter
1005he can not connect to wireless internet. have another laptop and not having same issue.
Hmmm - are you able to connect to other networks? are you getting a "no connectivity" message? Is wireless not showing at all? If the latter, have you tried checking that wireless is enabled? You may have accidently turned it off by hitting F2 key - can be put back on by hitting F2 again or through EEE PC Tray utility. If you are getting a "no connectivity" message or "limited connectivity", you can try shutting off the wireless and then putting it back on to force your netbook to search for the network again. If that doesn't work,try running the wireless network connection utility (I'm assuming you have Windows XP - if not, please let us all know) - open "Control Panel", click on "Network Connections", status of "Wireless Network Connection" should be "enabled" or "connected". If not, right click on "Wireless Network Connection" and choose "Repair". If that doesn't work, double click on "Wireless Network Connection" again to open the Wireless connection status window - the general tab lists status, network, duration, speed signal strenght, etc. - make a note of what it says here as you may need to post this info for more help. You can close this window. Now yet again right click on "Wireless Network Connection" and choose "Properties" to open another popup window - in the window, click on the "Wireless Networks" tab. The box next to "Use Windows to configure my wireless network settings" should be checked. Your home network should be listed in the Preferred networks window - select it and click "Properties" and check that the correct information is entered for your home network (did you change anything recently? Password aka network key, encryption settings, network name - if so you have to reflect those changes here). If your home network is NOT listed, you need to create it. Click OK to save any changes you make, exit out of all the menus, then (if necessary) use F2 to disable and re-enable your wireless to force your netbook to look for the connection again. If this doesn't work, go to Device Manager (open Control Panel, click on System, click on Hardware tab, click on Device Manager). In Device Manager, scroll down to Network adapters - if there is a yellow triangle with an exclamation point next to your 802.11n Wireless LAN Card, then you have some sort of device conflict or driver issue - is there an error message? If there is no yellow triangle and no error message, then you can exit Device Manager. If you are getting an error message or yellow triangle, try and fix this issue by reinstalling the correct driver from Asus or fixing the conflict - right click on 802.11n Wireless LAN Card and choose "update driver" if you need to do that (you will have to download the correct driver using another machine and copy it onto your netbook first) - otherwise choose "Properties" to troubleshoot. If there is a yellow triangle and/or an error message and you cannot get it fixed, it might be a good idea to make a note of error messages and details of what you tried so you can post them here to assist people in helping you.
If there was nothing wrong in the device manager, or if none of the above worked, it is possible that you have a malware infestation that damaged your winsock. In that case you can download Winsock XP Fix from Snapfiles or Cnet (from another computer), copy it onto your netbook and run it. If that fixes your problem, you may have malware issues and should do a virsucan (if you do not have an antivirus installed, get Avira free which is awesome) - I would also strongly suggest you download the free versions of Malwarebytes, Superantispyware and Emsi's A2free usb and run them to clean your system.
If none of the above works, then as a last resort you could back up all your data onto disk or an external drive and then use the Asus restore function to set your netbook back to factory default. You would have to reinstall all your software and reconfigure your netbook and copy all your data back - but at least hopefully your wifi would be working! If restoring to factory default did not fix your problem, then you almost certainly have a hardware failure.
Hope something above helped ya. Good luck.
Mar 06, 2010 | ASUS Eee PC 1000HE Netbook
Error on page in bottom left had corner
I have a yellow triangle on the bottom left hand corner of my facebook.
I cannot open my home page, chat or write any comments.
When I double click on the triangle it states that I have errors.
Can you help me solve this problem please.
Sep 13, 2009 | Facebook Social Network
User creating in domain
In active directory on the server you need to create a network admin user and any other normal users u want to have access to the domain.
Then you have to add the pc to the domain using the network admin user.
After this u can log on to the pc with the network admin or the other created user names.
Apr 15, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Limited connectivity within Wireless Network
reinstall ur lan drivers then contact ur service provider
Jan 09, 2009 | Microsoft Ethernet MN-120 Network Adapter
Views are essentially pre-written select statements, and select statements are limited to 256 tables.
There are a couple of other limits on views as well:
The number of columns in the view is limited to 1024.
Views can be nested (that is, a view selecting out of another view) 32 levels deep.
Jan 22, 2008 | Microsoft SQL Server Standard Edition for...
PC Connection Bulk Cable Logo
76 people viewed this question
Top PC Connection Computers & Internet Experts
David Payne
David Payne
Are you a PC Connection Computer and Internet Expert? Answer questions, earn points and help others
