Question about AMD IC Power CN5560 Notebook
Laptop Blackout.. Battery Icon after disconnecting from power source drained within 5 minutes and then turned off as if battery went totally dead, and when connected back with powere source Laptop will not even turn on and indicator light has not come on..Please help do I need to purchase a new Battery or what...or did I fry my Laptop..Thank You Cathy Grossi
    Sergeant:
  • 183 Answers
Your Battery went bad so you need to replace it.
and if you wanna run through AC power adapter then just take off your battery then plug in your power adapter then turn it on it should be working.
Posted on Feb 04, 2009
My hp laptop TPN-C126 has power but its screen was totally blackout
that TPN-c126 is not the model number
In fact its the EPA/EU, power (sleep )and energystar
regulations RMN:TPN-C126 (the R means gov. regs)
proof here:
http://h22235.www2.hp.com/hpinfo/globalcitizenship/environment/productdata/Countries/_MultiCountry/europe_erplot3_notebo_201542919128520.pdf
if you look again at the back of pc. base.
on the right side of where you where looking
is a SERIAL.(I dont want that)
then below that, is model
"HP 255 - G5" (or very close)
when posting use real names and models
as seen here
http://partsurfer.hp.com/search.aspx
click Hierarchy
then notebooks
then hp notebook PCs
behold. photo below.
one is yours, matching words on bottom of your PC.
LT black screens
http://pcdied.com/black-screen.html#Laptop
below is your pc if you knew its real name.15cdf60c-9764-4e4a-a480-66af380fe0ab.jpg255-g5-hmzm4reoidw0tx1unypabkrd-3-2.jpg
Jul 21, 2017 | HP Computers & Internet
My ipod was working no rpoblem last night. I left it on docking station overnight and this morning it is not working. It is like there is no power ? It wont sync either totally dead! Any ideas?
  • If an iPod appears not to turn on, check the hold switch on the device. If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
    If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds. If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
    If no battery icon appears when trying to turn on the device, try resetting the iPod. Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset
Nov 26, 2011 | Apple iPod nano
Acer Aspire 5738Z won't hold charge
Sorry. It seems that your battery is dead.
If your laptop is working fine on AC power only (with the battery disconnected), then your battery will need to be replaced.
Jun 16, 2010 | Acer Aspire Notebook
Won't turn on. Battery is plugged in and lit. n
Try removing your battery pack. Then connect the power adaptor (even without the battery) and connect is directly to the power outlet. If it powers up, then the battery pack might be defective or totally drained.
If the battery is just totally drained, simply place the battery to the laptop. Do not turn the laptop on. Plug the power adaptor to the laptop and plug it to the power source. If you see that the charging LED is blinking in your laptop, then just leave it charging up to 5 to 8 hours.
Never use a laptop on battery mode while it is plugged in to a power source. This is the number 1 reason why laptop batteries don't last longer.
Jun 06, 2010 | Sony VAIO Notebook
Easynote r1004 wont power on
The battery is too low and the power supply can't charge the battery and also power the laptop at the same time.
Try this:
1. Remove the battery from the laptop
2. Plug in the power cord and turn ON the laptop.
3. It should work ok.
4. After the laptop is "stable" (what 5 minutes?), you can put the battery back into the laptop while it is ON.
5. Leave the laptop ON so the battery can get charged.
6. Lower / close the lid so that the screen will turn OFFand not take up power from recharging the battery.
If this doesn't work for you, try these steps again, maybe wait a few minutes between steps.
This WILL work!
Hope this helps!
Sep 03, 2009 | Toshiba A15-S1292 Notebook
Screen went black
That is a low battery warning icon. Check first the DC adapter/charger output. It might be not working so the battery is drained. Then the player will not turn on. The player will still turn on even the battery is dead when plugged into an outlet.
Aug 03, 2009 | Televison & Video
My Dell Inspiron 1000 Laptop would not power up.
possible power supply are motherboard possible bad pin on board
Mar 28, 2009 | Dell Inspiron 1000 Notebook
Power will not turn on??
Try this:
1. unplugging the power cable
2. removing the battery
3. plug in power cable
4. switch on and start up
If this works, shut down, unplug and replace the battery.
Hopefully your problem is resolved.
John (Computer Tuition, Blackpool)
Nov 08, 2007 | Compaq Presario 900 /1500 Series EVO...
AMD IC Power CN5560 Notebook Logo
168 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
