Question about Coleman Powermate Premium Plus 6250W Portable Generator
Noisy muffler how can i quiet my 6250 gen.
    President:
  • 2,692 Answers
Put a much larger muffler on it.
Posted on Feb 04, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Sound like truck
Honda to VW, hey? Quite a change of heart. Have the exhaust system inspected-you may have an exhaust leak.
I thought all Nissans were normally loud, until a muffler guy showed me I had a rusty, leaking catalytic converter. Now my Sentra is groovy quiet !
Sep 07, 2013 | Volkswagen Jetta Cars & Trucks
2000 ford focus is very noisy in car when starting in the cold and quiets down as vehicle warms up. Any ideas what could be causing this?
check for broken exhaust pipe or muffler could have hole rusted through muffler or check around exhaust manifold for exhaust leaks.
Mar 26, 2013 | 2000 Ford Focus
How to modify powermate 6250 muffler to make quiter
I wouldn't recommend modifying the muffler, doing so would change the OEM's engine back pressure specifications and can lead to engine damage and carbon monoxide leakage
Aug 15, 2012 | Coleman Powermate Premium Plus 6250W...
To loud, do they have a better muffler kit
Most likely a different muffler is available for easy bolt-on solution. Best way to check is to find model and type of engine and check with engine distributor in your area or the web. Engine model is usually found on the starter/fan cover or the block. The problem is the limited space within the frame of the generator. Other solution is to contact a small engine service center for modification. There are several sources for quiet mufflers, however takes creative installation. Take a look at other generators with very quiet mufflers for ideas (different types of machine may use the same engine so take notice how other types lawn equipment /tools deal with noise ). Some generators are made for camping or use in quiet zones and use other methods for quieting the unit. Still other generators are noisy even with large mufflers. Good luck with your project.
May 02, 2011 | Coleman Powermate Powermate 5000W...
I have a Coleman Powermate 5500 Generator. It is
This engine was not built with quiet in mind, it was built to be cheap. upgrading the exhaust is your best bet and likely the cheapest. Talk to a small engine shop about the possibility of using a muffler from an ATV.
Super Trap makes a fantastic muffler, if it will fit your application (most do). A link has been provided at the end. When you are looking at the various options, you will notice that a rating in db units. Reducing noise by 3db is half the original noise level.
if you can, go with the SuperTrapp. If still noisy (probably won't be), then add on the resonator as well. Downside to using aftermarket is that you will have an exhaust stack / system that sticks out the side of the generator. Upside is that you will be able to think quietly about how much the exhaust sticks out.
And no, I don't have any connection with Jack's, they are just the first hit that came up. Now that you know that something is available, you can do more research on it.
http://www.jackssmallengines.com/Quietmuf_index.html
Jun 05, 2010 | Coleman Powermate Powermate 5000W...
I need to quiet down my 6250
Not all the noise is from exhaust. The mechanics and the telegraphing of sounds via the feul tank and frame are major noise sources as well.
You MIGHT want to consider building a small enclosure, paying attention to venting and fireproofing..
I have heard of people building an enclosure from concrete blocks for this purpose.
You could try the exhaust by adapting with stainless flex pipe to connect to a standard automobile muffler. I have also seen the exhaust "plumbed" into an underground tank to deaden the sound.
Jan 09, 2010 | Coleman Powermate Premium Plus 6250W...
I have a Coleman Powermate 6250. Runs Great, No power to outlets!
Excite the genset.
with the gen engine running,
1) plug a 3/8 drill into an outlet,
(make sure the drill is set to the forward rotation)
2) hold the trigger in the run position
3) by hand, rotate the drill chuck with a quick flip of your wrist.
*** NOTE: BE PREPARED !!! this will excite the gen-set and the drill will start to run as normal.
Oct 07, 2009 | Coleman Powermate Premium Plus 6250W...
Is there any way to quiet down my Tecumseh Craft. Gen?
longer exhaust pipe from motor and better muffler. Go with a larger pipe too to allow for better engine performance. You can get a tractor muffler from Tractor Supply that meets your needs.
Oct 07, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
389 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
