Question about RCA HD52W59 HDTV Projection Television
No power to tv
Watching tv and it just went out.. power to outlet but tv dose nothing...
    Master:
  • 848 Answers
The power management and protection circuits have taken over. There is something taking too much current and the protection system has shut the system OFF to prevent further damage ...............if you are familiar with tv service you can check the main fuse that should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as soon as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply.......Check horizontal output transistor.............
Posted on Feb 04, 2009
Hi, i have a Panasonic viera tx-l47et5b and yesterday i was watching tv as normal and it just went off by itself since the green light is just flashing every time i switch it on there is no red light...
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 14, 2013 | Panasonic Televison & Video
We were watching our brand new TV, we set it up 2 days ago, when the power for the TV went out. We tried using another outlet to make sure the the outlet wasn't bad but we still have no power on the TV....
Try a lamp in the outlet and since the outlet has power, the problem is in the tv set.
This new set is under warranty and you should return it to get it fix/replace.
This sound like the power supply board has failed. Probably the fuse on it has blown.
Feb 14, 2011 | Vizio 42 in. LCD TV
TV is 4 years old. Not used very much. Watching TV yesterday, everything normal, great picture, etc.. TV goes off. Checked outlets,cable, etc.. Could not get TV power back on. Any suggestions ? No life,...
Question heading shows it is Sharp LC-37G4U tv and if power indicator dose not lit if tv plugged in that means power supply board got defective and need to be replaced.
Required power supply board is available with ShopJimmy.com for $79
Click above link to view power supply board image and price info.
If you are handy with electronics stuff repair then can replace power supply board by yourself OR call local tv repair shop to do this job.
Hope these info will help you.
Let me know if you have additional question.
Thanks
Nov 15, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Tv will not turn on
A: Is there a humming sound coming from the TV set?
Check the brightness/contrast. If nothing still, remove power to the set for 24 hrs. and reconnect and retry. If it's not coming back up, the PCB ("motherboard") for the set has most likely died. Check for warranty information in your user's manual for further instructions.
B: Is the TV sharing an electrical line with a wall switch?
Remove the set from that circuit and try another outlet. If not, follow the Steps for "A".
C: Was it during a power storm, when it went blank?
Check the outlet with another appliance - if that device works, try the Steps in "A".
Nov 28, 2008 | Philips Magnavox 27MS343S 27" TV
No power
Did you try connecting the TV on a different power outlet? just to check if its a prioblem with the outlet... IF still no power this is a problem with the power supply of the TV that may needs replacement..
Hope that helps........
Sep 02, 2008 | iLO 3200 32 in. LCD Television
7 yo 36 inch trinitron
first,check the fuse if it's busted.replace it and power it up.if it gets busted again,maybe theres a short in the power regulator.if you have experience in troubleshooting,try to fix it.but if no,bring it to a service center neer you and let them do the job.you might get electricuted by the capacitors inside.those are charged w big amount of current and can cause shock.u
Aug 31, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Panasonic Problem
replace the fuse of the tv device (in the primary main power section),or contact the nearest repair shop.
Jul 18, 2008 | Televison & Video
Not Powering Up...Please Help Me!!!
This may sound silly but check your circut breaker or if you have a GFCI on your outlet because maybe you have too many things plugged into it. Plug a lamp or something into the outlet. If you are sure it is the TV check the owners manual for common troubleshooting. After that I would pursue the warranty; it should be 1 year with this model.
May 15, 2007 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
RCA HD52W59 HDTV Projection Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
