Not conected Installed from cd-rom site. Used it but it wouldn't close when I hit closed. Had to shut down pc to get it to close. Now it says that it's not connected. Also is this compatiable to use with yahoo messenger?
  • 63 Answers
Go to Start-Run- Type MSconfig- Startup- Disable All- apply- Restart the PC- Connect ur mouse- it should start working
Posted on Feb 04, 2009
My cd-rom on dell Dimension 8250 pc desktop computer will not show up on my computer. Am i missing cd-rom drivers.
hello,
1.first go to http://support.microsoft.com/mats/cd_dvd_drive_problems
click on the green button that has run now
Run the microsft fix it tool
if it works GREAT! if not go to #2
#2 go to this site http://www.techsupportall.com/fixed-solved-cd-drive-not-found-not-detect-remove-upper-and-lower-filter/
follow instructions
IF THAT WORKS GREAT! if not proceed to 3
#3 turn off computer unplug power cord.
open your computer case unplug the cables that connect to the back of the cd rom. plug computer back in power it up. shut it down once it loads. then once it is powered down open case again and plug the cables back in make sure they are connected well. close case and power up the computer.
hope that helps
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
Cd wont eject acerdesktop
look closely at the front side of the cd-rom, you will find a very tiny hole at the cd-rom door, used a hiar pin or an any wire that can go inside the hole and press it good to make the door open.
Dec 28, 2009 | Computers & Internet
Close the CD Rom tray and CPU powers off
it is broken remove it from the pc and replace
May 25, 2009 | Samsung SN 124 (SN-124) Internal 24x...
Windows XP 'writemaster' not recognised
There were more problems and I needed a solution fairly quickly. The solution I used was to wipe the hard drive, re-install windows xp and start again. A bit drastic but the problem did not re-occur.
Apr 12, 2009 | Computers & Internet
CD/burner is gone and Wont load anything i put in.
Try using device manager and deleting the CD from it, then reboot and let windows do its thing with intalling it again. Let me know if windows does NOT try to reinstall the CD drive or you get any error messages
Tje cd rom isn't working properly
your cd rom motor needs to be replaced..so it is better to take it to nearest service center...
Jan 04, 2009 | Gateway Computers & Internet
CD tray wont close but remain open.
There may be still some peices of cd's which block the cd tray to close. So try your best to clean those by unscrewing it from ur desktop. then try it. You can also try removing the screws of cd drive and clean it inside.
Oct 18, 2008 | ASUS (CRW-5232AS QUIETRACK) CD-RW Burner
I can't read CD on my computer anymore so I can't instal my LG 18x Externall Super Multi DVD Rewriter
first turn off your pc then you sec your cdrom power cable is plug in or data cableare properly conected to the mainboard ide socket if eaverything is parfectly then you power on your pc and sec cd rom eaject batton push it if tray open then you put your instollation disk and close it. if the cd rom not reading instollation disk then you seour that your cd rom pickup or lans is bad or damage. replace your cd rom or put your instollation disk other computer and copy your assential file in to a usb pen drive and transfer your pc.
Jul 16, 2008 | Computers & Internet
Cd-rom drive
try to separate the ide cable. /
Feb 08, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
