Question about Thermos Grill2Go Gas Grill 4656110
Need some parts
Hello i was given a thermos grill 2 go (nemo) that is in good nik
but it needs a regulator/valve and gas line to the bottle
Is there someone i could call in australia to help Thanks
  • kaldon Feb 10, 2009
    Most places i have asked if they have any parts do not know any thing about the BBQ can you givre me a name that i could try and call
  • 10,865 Answers
Hello. Most hardware stores will have replacement parts which work on all grills. good luck .
Posted on Feb 04, 2009
I need a regulator valve for a thermos grill2go bbq model number UK-467638503,PART NUMBER 4158176
I bought this to replace the regulator I lost for my Thermos Grill2Go. Little modification to the grill and it worked like a champ. Portable Propane Table Top Regulator 1 by 20 Female Throwaway Cylinder...
Jul 29, 2011 | Thermos Grill2Go Gas Grill 4656110
I need the metal part where the gas bottle connects too..
I can only assume your talking about the regulator and screw on connection. These can be bought at most large hardware stores including sears to fit most if not all grills. They basically all use the same type of regulator and gas supply lines. Fot this protable grill you may have to get online at
www.grillparts.com/charbroil/grill-2-go.asp.
Jul 13, 2011 | Thermos Grill2Go Fire+Ice
Grill is one old and won't light. There is no gas coming from the tank to the grill. Is it the regulator?
age of the grill is irrelevant, i am old and i still can do few thingzzzz...
i assume that your regulator is connected directly to the bottle, then hose to your bottle, then hose is connected to the regulator and other end to the grill?
or it is bottle, hose, regulator, grill?
you need to follow the path regardless, be outside, light breeze is better, no open flame in at least 20m (yards) radius in any direction.
1. close gas bottle/tank
2. disconnect, everything from the bottle
3. crack open tank valve and hear if gas is escaping, close valve back
4. connect regulator to the bottle and again crack open the valve, hear if you have esacping gas, allow actually whiff of gas against your cheek or wetted finger to establish the flow. close the valve
5. connect hose to the regulator (procedure is reversed if first is hose and then regulator), crack open the valve, hear for escaping gas, check against wetted finger and cheek if there is flow, close the valve
6. connect your grill open all valves on it and open valve on the tank/bottle. allow free flow for about 30sec, close valves on grill. vent grill for about two minutes, try to ignite any of the burners. if burner ignite, you solved the problem, if they do not, and you did have flow on all previous stages, close bottle valve, disconnect everything from grill, clean grill valves and nozzles (burner have nozzle inside!), reconnect and vent again, try ignite, if ignition occures, you solve the problem, if not, then you are due for new grill...
if at any stage you do not have gas flow, this meant that this particular piece of equipment is in trouble, this particular piece of equipment need then repair or replacement, under no circumstance pull apart the reducer! NO OPEN FLAME DURING TESTING!!!
Jul 27, 2010 | Weber Q Grill
My tank emptied after 2 bbq's.
with the gas bottle turned on make up some washing up liquid in a bowl bursh it on joints to see if you have a leak it will bubble up if you have , the try it with burner on on the gas controls
Apr 12, 2009 | Thermos Quick Set Gas Grill 4000
Jenn Air 740-0141 LP to NG Conversion
If the grill can be converted, it's usually a matter of providing a source for the natural gas and then changing the gas jets for the burner(s) and possibly a regulator, depending on your model. Some grills may require changing the gas burner valves themselves. Kits are usually available from a dealer unless the unit is old.
The natural gas jet will be slightly larger than the propane jet because natural gas doesn't have as high a heating value as propane.
If you do this, check your new conversion for any leaks using a soap solution in a spray bottle.
Just be aware that the grill may not get as hot with natural gas and cooking could take a little longer, but should still work just fine.
Your natural gas line should typically be about 1/2" unless it's huge or is over 50-60 feet away from the grill location. If so, use a 3/4" line. Piping material and methods are usually governed by your local building codes.
Mar 17, 2009 | Thermos Stainless Steel Gas Grill
Not Hot!
We have had two grills that developed similar problems after sitting for a length of time and found that an insect had built a nest in the tubing leading from the regulator. A piece of pipe cleaner up the tube fixed the problem. Can't say if your's is the same problem but it is worth checking.
Nov 23, 2008 | Thermos Grill2Go Gas Grill 4656110
Grill 2 go parts
I have the same problem no reg. and no connection pipe, where can I get?
Mar 18, 2008 | Thermos Grill2Go Fire+Ice
Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Thermos Grill2Go Gas Grill 4656110 Logo
540 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
