Question about Cisco 1760-V Router
We are looking for a work around
We have discovered recently that our Cisco 1760 onboard ethernet connection is 10/100 and the Ethernet WIC is only 10BASE-T I am curious if anyone has heard of a hack or workaround to get this to 10/100 I am pretty sure there is not, but sometimes things are possible. Thanks for your thoughts
  • 100 Answers
I dont think you can, sir.
Posted on Aug 01, 2007
Desktop pc windows 7 sp 1 wired cisco dpc 3008 no additional devices random connections
I would first get a new Ethernet cable and try it. If that doesn't fix it, call your cable company and have them do a diagnostic from their end. They can tell if it is their equipment or not. It their modem is OK, and the Ethernet cable is OK, then your LAN (Ethernet) card is either going bad, or possibly not completely inserted in the socket. To check: turn off and unplug your PC. Take the side off, look where the Ethernet cable goes into your computer. If it is on the motherboard, you may want to get a LAN card and use it instead of the onboard. If the cable goes into a card plugged into one of the slots, make sure it is fully inserted. If it is, you may want to get a new card.
Oct 28, 2017 | Cisco Linksys DPC3008 - cable modem
I can't get the onboard network connection to work. Wireless works fine. When I look at properties it says that it is connected.
The Ethernet jack might have a broken wire inside the laptop. Try a modem that uses a USB connection instead of Ethernet - if it works, then the Ethernet jack has an open wire.
Nov 11, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
7940 cisco ip phone being powered by a power brick seems to loose power when connected to the ethernet. When ethernet is disconnected, power comes back. Ethernet works fine when phone is not connected. No...
Change out your cable from the wall drop to the phone. A Cisco phone is capable of receiving inline power (Power Over Ethernet) via the blue and brown pairs of the cable. It sounds like you may have a cable with a short in either the brown or blue, or both pairs, shorting out the power when it is connected via ethernet.
If you can, have your IT Tech check the cable, and the line through the wall to the switch.
May 26, 2010 | Cisco 7940 IP Phone
Cisco 1760 router had not accept password i think i forget my give me suggesion to recover it
you will have to reset it or recover it. It can be a lengthy process, here's the howto on cisco's site for a 1760 router password reset/recover:
http://ciscosystems.com/en/US/docs/routers/access/1700/1760/hardware/installation/guide/trblsht.html
Apr 01, 2010 | Cisco 1760-V Router
Cisco 1721 Router IOS
I can help you with the IOS you need, but Cisco does not list 12.3.x XC, they only have YZ, YG, XR, XK, XG for this router. Email me at thrca@thrca.com for more help.
Aug 30, 2009 | Cisco (WIC-4ESW) 4-Port Ethernet Switch...
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Mar 27, 2009 | Zyxel IP Express IES-1000 (91004098002)
Cisoc 2950 with odd Problem
I recently had a client switch do this to me. The only way to get it working was to manually put the NIC on my laptop to 10 Mb and Half duplex. After calling Cisco and opening a TAC case, it was deemed faulty hardware.
If you have SmartNet (anyone buying Cisco should always buy SmartNet) on the switch, call TAC and open a case. It's probably faulty hardware.
Good Luck!
Feb 02, 2009 | Cisco Catalyst 2950 24x10/100 Mbps...
Dose cisco aironet 1100 support routing
You must use a router to perform NATing to the ISP. Simply use a Netgear or Linksys router and plug your access point into it. You can even use a Netgear or Linksys wireless router with the ethernet ports built into it. Just disable the onboard wireless.
Jul 31, 2008 | Cisco (airap1120bak9airpcm352) 802.11b
Cisco 1760-V Router Logo
107 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
