Question about Campbell Hausfeld No.FP2028 Gal Pancake Compressor
Will not fill a car tire
This compressor despite having almost 90 lbs of air won't fill a car tire. you have to work and work just to get a little to go in. i was told it was probably my valve stem freezing up. Not the case. it doesn't fill any tire on my car. not too happy about this dropping of 77 dollars with tax.
  • 3 Answers
Go to rehab and while your there you need to get a size 7 valve and shove it up your but
Posted on Feb 07, 2009
    Problem Solver:
  • 4 Answers
Tire nozzle may be to big. not able get a good contact. try a different nozzle make sure you got it all the way on there
Posted on Feb 08, 2009
I have a 3 gallon air compressure that wont go above 40 psi
Mine has a little knob to turn to set the pressure. Mine is set at 120 lbs. Probably yours is set so tire pressure won't go over 40 but there should be a setting to set it what you want.
Dec 04, 2014 | Psi Air Tools & Compressors
The air compressor will now only pump a small amount of air. Not enough to put 12 lbs into a lawn tractor tire. Worked fine for several years. how to repair, please?
many small air compressors are made with ceramic internal parts, when they wear out there is no fixing them, one must buy another compressor
Oct 21, 2013 | Air Tools & Compressors
Salon tc 60 airbrush compressor won't build up over 17 lbs pressure.
Either the pressure switch needs adjusted or the compressor needs rebuilt.
Jul 27, 2012 | Hobbypet TC60 Super Quiet High Performance...
Craftsman air compressor manual 921-152100
go google searspartsdirect. enter model number, free diagrams!!
Oct 17, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Have a 3 year old Goodman Compressor GSC130301AE. Compressor shut down with very hot outside temps, now works occasionally, compressor not starting after a start up, despite 90' temps today.
this could be a stuck compressor or a low voltage condition shut it down as the compressor is only getting hotter. wait about 1 hour and tryagain hope this helps let me know Jon
Jul 25, 2011 | Goodman Heating & Cooling
What is the tire pressure required for a 700c Denali Model# ov52706?
Look on the sidewall of your tire and see what it is rated for. Also, do not go to a gas station to fill it up, go to a bike shop and ask them or buy a bicycle pump with a gauge. Always make sure that your tire is seated on the rim evenly or you will pinch the tube and it will blow up. Car tires have more volume so that is why you cannot use the same air pressure device. Your tire will say 90-120 lbs more that likely but your tires is not that big around.
Sep 19, 2010 | GMC Denali 700C Road Bike
AC problem with 2001 Montana passenger van
Did you replace the expansion valve?
Also try adding just a little more freon and see if that makes a difference....is there a sight glass you can view with the system activated to be sure you have it completely air free?
Jul 21, 2010 | 2001 Pontiac Montana
Gauge says tank at 120 lbs of pressure, but won't fill tires
sounds like you have a bad batch of schrader vales on your tires OR
you have a defective chuck end that is not milled properly to push the schrader valve and let the air into the tire stem
Jul 05, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal ari compressor low presure
put a blower on the hose and see if air comes out
very possible there is a blockage in the hose or if you are using quick connects they may have failed
Apr 17, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Campbell Hausfeld No.FP2028 Gal Pancake Compressor Logo
765 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
