Question about RCA HD52W59 HDTV Projection Television
A portion of the left side of my TV looks 3D.
It is outlined in rainbow colors. Is this a problem that I can fix myself or do I have to send it to the shop.
  • bj19872005 Feb 21, 2009
    Thank you for your help it worked great ! ! ! ! !
  • RCA Master
  • 5,138 Answers
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 there is 3 of them in a roll on right side of FBT/flyback ttransfomer they are small brown rectrangler lookins caps but are FUSES it will be the one in the middle.
Posted on Feb 20, 2009
The left half of the picture has gotten blurry, with pink, green outlining what seems like 3 different pictures of the same thing. The left half works fine and the HD of direct TV is good on that side. I...
The tv have a problems known as a tv convergence pictures problems,it is dead.Tv set have any colors lines like R,G,B mis alingnments,have colors shadows pictures or a 3D pictures look alike?Yes,than the tv set convergence board it is dead to causes all these pictures problems.The tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set covergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Sony KP-65WS510 65" Rear Projection...
Its a 2004 61 inch big screen projection tv and the subject on screen has three colors outlining it green red blue on the outer portion of subject on screen
Tv have a problems known as a convergence pictures problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to repair it.To solved tv pictures convergence problems.The shop will cost u like $300-350 for parts and labors.
Jul 05, 2011 | RCA R61WH76 61" HDTV
My tv has the rainbow/3d effect on the right hand side, and is starting on the left side.
Hi my rear projection tv has got a blue and yellow line looks like a rainbow how can i fix it please.
Feb 21, 2011 | Zenith R57W46 57" Rear Projection...
The left side of the picture looks like it is in 3D. It has a pinkish color . the right side of the tv is fine. thank you for your time
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
SONY kp-51ws510 rear projection tv. recently it started showing a rainbow on the left top corner and middle bottom of the screen. what might be the problem? can it be fixed? for how much?
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Jan 20, 2010 | Sony KP-51WS510 51" Rear Projection...
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Color very faint and blue or yellow outline
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I jhad was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
Mike
Aug 08, 2009 | Philips 55PL9524 55" Rear Projection...
3d rainbow pictures..with colorful waves..and no convergence menu to fix it.
Replace FL231, DL231 and CL230 you can get the parts and istructions at the following link listed under RCA Parts
http://servicemanuals.vstore.ca/
May 31, 2009 | RCA HD61W66 61" Projection HDTV
You will need to replace the FL231, DL231 and CL230 you can get the parts with free instructions with pictures at the following link. The parts are all listed under the RCA parts category total cost is about 11.00 http://servicemanuals.vstore.ca/
May 14, 2009 | RCA HD61W66 61" Projection HDTV
Kp-46wt500 shadow and slanted images with rainbow colors
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 04, 2009 | Sony KP-46WT500 46" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
