Question about Compaq Presario C700T Notebook
Desk to computer shut down problem
As soon as I start my desk top PC it opens and displays the desktop items and again on its own it shuts down.
The same proble repeats , but when I start in safe mode it shows all the existing files without any problem.
may i know how to trouble shoot it
  • 2,404 Answers
Go into safe mode and then go into MSCONFIG and click on the startup tab. You'll see a bunch of checkmarks in boxes of all the programs that are running. Disable all of them, and then restart the computer and let it go into windows normally. It it boots all the way normally then that means you had something running in the background that was causing windows to shut down and you'll have to figure out which program it was and uninstall it.
Posted on Feb 04, 2009
Every time when computer restarts,i get new and fresh desk top, how can solve it ?
How do you shut down? With the windows start menu shut down process? Or push the on/off button on the computer? Take a look at this: http://www.winhelponline.com/blog/fix-desktop-icons-layout-not-saved-restart/
Jan 01, 2013 | Computers & Internet
Delete page superimposed on my desk top home page
I'm assuming this is a Finder window. In Finder, press Apple-option-W just before you shut down the computer. This will close all Finder windows; they will should not open when you start up the computer unless they were open when you shut it down.
If it's not a Finder window, you will have to deal with whatever application is being told to run at startup. Without knowing what it is, I don't have enough information to tell you more, other than to suggest you go to your User Accounts in System Preferences, click the Login Items tab and either check the Hide box for that application, or remove it from the Login Items list.
May 31, 2012 | Computers & Internet
On my desk top computer, I received a ThinkPoint (fake) Anti-Virus. I did CTRL, ALT, DEL. Task window opened and I deleted hotfix.exe. I also ran malwarebytes anti-malware. problem seemed to be fixed....
Run Malwarebytes again but before you do turn off system restore. There is probably a reboot hacktool in the restore volume. Windows will not allow Anti-virus programs to scan there by default so the only way to kill the hacktool is to turn of restore. The hacktool reinstalls the virus as soon as you reboot. So turn it off, run malwarebytes and another program called Cureit! http://www.freedrweb.com/cureit/?lng=en save to desktop (it's free too) when you run the program it doesn't install it runs a quick scan first then offers you a full scan after the quick scan. Also a very good program. Run them both. After you're done turn system restore back on and create a new restore point. Good luck
If this helps you resolve your problem, please
consider giving me a good rating .It will help me
as well. Thank you.
Oct 26, 2010 | E-Machines eMachines Desktop PC
Fan works randomly....when it's not working plug
Hi, If the computer is hot near the electrical plug in the back of the computer then the power supply needs to be replaced. This will also cause overheating problems if the fan does not exhaust enough air. You should not run the computer in this condition because the power supply can short out and take other components with it. Also there is a risk that it will burn up. Power supplies are very inexpensive and can be changed by anyone with basic computer repair knowledge. Hank
Jul 26, 2010 | eMachines T5212 PC Desktop
My pc get restarting
Mostly this problem exists only when your computer is affected my virus. If the computer turns on and if you are able to get into the desktop screen and then if its shuts down, then its a virus. Try formatting your pc and install a fresh copy of a OS.
Or if the PC shuts down soon after you start the computer, its the hardware problem.Open the CPU case, remover the RAM and insert it again. try to clean the dust,
Jun 30, 2010 | EliteGroup ECS Socket AM2+/ GeForce 8200/...
Hi. I have a dell e310...and the desk top turns on but the monitor will not display anything...it has an amber light..sometimes.it will turn to green but then shuts off again Could this be a bad video...
depends . either the video card or motherboard see if the blue video connector is at the top or twords the bottom of the case and that will tell you if it's a card or integrated on the board.
May 13, 2010 | Dell Dimension E310 PC Desktop
1) difficult connecting to yahoo, computer slow
sounds like virus or spyware at first. get microsoft security essentials and scan you PC i bet it's riddled
the PC should power off if you hold the power button in for 4-6 seconds, rather than use the switch at the wall
Jan 13, 2010 | Computers & Internet
My computer keeps rebooting and will not even let me start it up in safe mode.I blew the dust out of it and it restarted and let me into the desk top for about 5 minutes but then shut down before I had a...
Constant rebooting of a computer can be cause by alot of reason the most common for this is due to oevrheating, to check if this is a overheating problem try to open the case of the tower and put a electric fan in front of the tower to coll it down then power ON thecomputer and if it booted up fine with a electric fan blowing on the tower we're sure that you need to add some colling device on the computer tower, But if still do the same thing the problem here is the power supply unit it needs a replacement already....
Oct 22, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
Computer shuts down problem
When you take the cover off and start up, are all of the fans spinning? If the CPU fan doesn't spin, the system will shut down soon after starting to prevent over heating the CPU
Feb 21, 2008 | Intel V2 (INTPRI) PC Desktop
Problem with our Apple Macs shutting down
A quoted suggestion from my Mac Guru: "They need to turn off the Energy saver preferences for processor cycling and hard drive spin down. They would actually be better off turning them down anyway since the G5 duals run really hot and aren't the most reliable model Apple ever shipped for motherboards failing."
As for the iMac 99, It would be more helpful to know what OS the unit is running. I remember hearing a story about a disgruntled employee putting the 'shut down app' in the start up items folder. This caused the Mac to start as normal and then shut down after the startup was complete. Try starting up the machine with the extensions off. 'Hold down the shift key at startup'
Feb 09, 2008 | Computers & Internet
Compaq Presario C700T Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
