Question about Canon PowerShot A620 Digital Camera
A620 wont operate from batteries but will work off of ac adapter
I've had this A620 for about 2 1/2 years. Bought new. I've kept good care of the cam. Batteries are good. When I push down on the on/off button only the green indicator light flashes momentarily once.
  • Anonymous Mar 23, 2009
    the same thing is happening to me! HELP!
    Scholar:
  • 170 Answers
Try replacing the batteries and check again. If this fails to solve the problem, try cleaning the battery terminals and the camera's contact points with an eraser. It could also be possible that the battery chamber's door is not closing properly. Try to press it while you turn the camera on.
Posted on Feb 04, 2009
Packard bell netbook nav50 battery stopped charging properly. bought a new charger and battery and it still wont charge it up.
LOL, I didn't know Packard Bell was still making computers. I would think they sold you a bad battery. I've purchased new batteries before that would not charge.
Apr 04, 2012 | Computers & Internet
Dell Studio 1440. New battery&adapter won't charge
You either have one of the following:
1. Bad Battery
2. Wrong adapter - yours no comprende w/ unit.
3. Cracked Jack - means you've got to get a tech to take the unit apart and replace it. $150-200
4. Goto your device manager, double click bat., then right mouse click on acpi driver and update it. Hopefully that works.
or
5. Dell needs to shoot out a bios flash fix.
Feb 16, 2012 | Dell Studio 15 Laptop
Do you need a working battery to run camcorder off ac power adapter? I havent used camera in 2 years and just bought replaceable power adapter and wont charge battery or work off outlet at all..camera was...
You do not need a battery to run the camcorder off ac power supply. It is one or the other. The only time that both will be used is when you are charging the battery on the camcorder with the power off.
Hope this helps.
www.austintelstarservices.com
Jul 21, 2011 | Sony DCR-HC52E Mini DV Camcorder
Toshiba A200 1vo. works on battery but freezes when ac adaptor is inserted then has to be turned off manually-no keys function at all except on/off button.Won't start upon ac adaptor either although...
You say you bought a new adapter--was is a Toshiba adapter? Was it a "generic" one?
You have to be careful, because some adapters have different polarity and could damage the computer.
If you are sure the adapter is OK and is putting out the correct voltage (~18 v.) then disconnect the battery and try running the computer without the battery just using the adapter.
I don't think this is a BIOS problem. The operating system should not affect the function of the adapter.Most likely you have a motherboard problem if all else is working.
May 31, 2011 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Dell XPS 1530 wont power on at all..
Troubleshooting is pretty simple.
  1. Try a different Dell 90W or larger D/E-Series AC adapter and see if the system gets power. If no known good AC adapter is available, then check output voltage of AC adapter (Should be about 19VDC or so) If you can't do either, then the AC adapter is still the cheapest item to replace for a no power issue.
  2. If system will not power on with a known good AC adapter or new one, then the motherboard is the likely failure point. Roughly $150 on Ebay
Feb 24, 2010 | Dell Computers & Internet
Battery doesn't stay charged
The problem is with the battery. All Lithium batteries last for around 1000 charges or so. Since the laptop is 2-years old the battery needs to be replaced.
I Hope this solves your problem. Kindly Accept my solution.
Regards, Arjun
Apr 01, 2009 | HP Compaq Presario C306US Notebook
Sony handycam DCR-DVD205: use new ac adapter or reinsert
Remove the battery insert your AC adaptor turn on your DVD CAM if it work fine reinstall the battery set CAM to off position the amber light should be on to indicate battery is charging
You got that msg depend what function you use if the CAM calculated the battery not enough to run or finish this task it display that msg for you to use AC adaptor to ensure no power corrupted such in formating the disc
Some time system control is faulty even you use AC adaptor it still display this msg I hope that is not in your case
Let me kown how you go with this problem
Nov 30, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
Dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Nov 26, 2008 | Dell Computers & Internet
Digital camera
1. Check batteries.
2. Connect camera to an AC adapter.
3. Remove all batteries, disconnect AC adapter, wait a minute, reinsert batteries and reconnect adapter. Turn on camera.
Dec 01, 2007 | Cameras
Canon PowerShot A620 Digital Camera Logo
188 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
