Question about Dell Inspiron E1505 Notebook
Dell Inspirion E1505 internet connection problem
I purchased a used laptop and I am having problems getting it to connect to my wireless linksys.
The linksys is working correctly as there are 2 other computers linking up to it.
It appears to be something monked up with the laptop.
It’s a Dell Inspirion E1505.
I don’t even know where to begin as I am almost a computer tard.
I have followed the “diagnose connection problems” and did a “repair” thing.
Sometimes it works momentarily, then loses connection and info says limited or no connection.
Someone please help!
nightgirl
  • 4 more comments
  • nightgirlb Feb 04, 2009
    I have windows xp,
    I dont see Start>my network places
    I now have found my NETWORK CONNECTIONS Area
    under LAN or High Speed Internet
    I have 3 choices
    Wireless Network Connection
    Connected,Firewalled
    Dell Wireless 1390 WLAN Mini
    Local Area Connection
    Disabled, Firewalled
    Broadcom 440x 10/100 Integr
    1394 Connection
    1394 Net Adapter
    Which LAN do I choose?
    How do I find my IP address for solution 2?
    @Niraji This is paid wireless at my home.
    I Think I solved it
    I had the Dell Wireless Utility mamaging my wireless connection.
    I went to Dell Wireless Utility manager and unchecked the box next to "Let this Utility mamage your wireless network" and clicked apply.
  • sanjay Limbu
    sanjay Limbu May 11, 2010
    Is it paid wireless service for free of cost?
  • 34 Answers
NightGirl,
What I would try to do is first check to see if there is a static IP address. You check this by goto START-MY NETWORK PLACES-VIEW NETWORK CONNECTIONS (in the top left hand side) From there, you should see your LAN,HIGH-SPEED INTERNET then under it you should see Local Area Connection. If there is more than one Local Area Connection connected, then disconnect both of them and try only connection one of them, (i couldn't tell you which one as I'm not there to see which is the onboard NIC) It should be connected, but apparently in your case it may not stay on. Right click on the Local Area Connection, then goto PROPERTIES. The properties box is going to open up. Make sure that Internet Protocal (TCP/IP) is checked, then highlight it and click on the PROPERTIES box, here is where you want to make sure that the (OBTAIN AN IP ADDRESS AUTOMATICALLY) is selected, if not, then select it and do the same for the bottom (OBTAIN DNS SERVER ADDRESS AUTOMATICALLY)
Posted on Feb 04, 2009
    Problem Solver:
  • 4 Answers
Have you properly entered in all of your network's info into the laptop?  Sometimes security settings can block access to the Wireless network.  Here's a quick way to diagnose network connection.  (Make sure you know the IP address of your router!)
1. open your Command Prompt
2. type in the following "ping (Router IP address example: 192.168.1.1 " after entering the following press enter.  (you should see a series of lines that say how long the packet took to make a round trip...if not, then you have no connection to the wirless network)
3. if the results of the ping test read "100% loss" you know that connection is definately not established.
Your next course of action should be to inspect your laptop's settings and ensure that your laptop can "see" the router.  If your laptop's NIC ( Network Interface Card ) cannot detect the network it is possible that the NIC is bad or your router isn't set to "Broadcast" your SSID ( Service Set Identifier ) aka network.  this following article might be able to assit you in the troubleshooting process more throughly.  I hope this to be of some help to you!
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx#2
I had to restore my dell inspirion E1505, and it says i have no wireless network, how do i turn this worless network back on?
You need to check for the wireless switch located on your laptop. Once the wireless switch is on, you'll be able to see networks in range and you will be able to connect to your network wireless.
Good Luck!
Aug 27, 2010 | Dell Inspiron E1505 Notebook
My Dell E1505 won't allow me to go wireless. My
Ideally, see if we can isolate the issue.
Disable the built-in antenna.
Try connecting to the wireless via a USB wireless antenna. (hopefully you can borrow one).
If you can connect, then I would say you need to replace the built-in antenna. Or you could keep using the USB antenna.
Good luck
-Carlos:
Jan 25, 2010 | Dell Inspiron E1505 Notebook
I cannot connect to my wireless internet Dell Inspiron E1505
what does the it say? limited connectivity? etc. or it just can't connect at all?
Aug 16, 2009 | Dell Inspiron E1505 Notebook
Wireless Connection Problems between an Dell Laptop and Actiontec
Have you got permission to connect into her Internet using her wireless router?
If so you need to get the WPA encryption key from her to configure your wireless card's encryption to get access.
Jun 28, 2009 | Dell Inspiron E1505 Notebook
Wireless issues with my Dell XPS/Dimension One desktop
Even if it's a new Dell, you may need to update either the drivers for the wireless card or the BIOS.
Also, verify which protocol your Dell is set to use (i.e. 802.11g, 802.11b, auto-select, etc.). Dell may have fixed to to a slower protocol for compatibility.
May 02, 2009 | Dell XPS One Desktop
Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Mar 04, 2009 | Dell Inspiron 1501 Notebook
Dell laptop internet connection problem
ok ...on one of the other pc's that do connect ok go into control panel...open network connections...click on wireless icon to highlight it...in drop down menu(now exrended)choose change settings of this connection...this will open wireless properties....
scroll down the list to internet protocol (tcp/ip)double click to open ....check ip address,subnet,gateway and dns server...write down the info in the fields...if theres no info (because obtain ip auto is set)connect to internet...youll see wireless icon in sys tray(bottom right in screen) double click on this icon...a box will appear giving you connection status ...click on support and you can find same details there.you can now close all programs and turn off pc if you like...boot up pc that cant connect.. do same precedure to get to wireless settings and in the given fields write in the info you now have like ip 192.168.0.3 subnet 255.255.255.0.gateway 192.168.0.1 dns 192.168.0.1 ....and now you should ba able to connect no prob
Feb 04, 2009 | Dell Latitude D505 Notebook
How do you connect to the internet ?
what u can try is that install the lynksis cd on the computer and then open the network connection and then right click on the wireless network connection and then click on the view available network and then connect to ur network connection and it should work or else the best way u can do is that u can call up dell technical support and they will be definately able to help u to connect to internet cause i really cannot explain all the details here cause it need to be done troubleshooting on ur computer practically by connecting the router with the laptop with the ethernet cable and when u connect the internet with the ethernet cable then the dell guys can take the remote session in ur computer so that they can help u to connect to internet wirelessly.
follow 4 steps to connect to lynksis:-
In order to follow thesen four steps all u need to do is that just follow this link very caarefully and u will definate;y be able to connect to internet wirelessly with the lynksis..
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx#step1
Jan 27, 2009 | Dell Inspiron 1501 Notebook
I recently purchased a new desktop which I had linksys connected to my old pc so that my laptop would work wirelessly. Both are Dell computers. I have a Linksys WRT54G router. I have Vista and the...
I don't see why not..
are you trying to hook up both computers to your linksys router?
if you have 3 computers now... I'm assuming your old pc was connected directly to the router, your laptop was connected wirelessly and now you have a brand new computer that you also want to connect to the internet using your lynksis router.. you should have not problems doing it, wirelessly or using a wire...as long as your router has ports avaliable...
Sep 21, 2008 | Computers & Internet
Dynex
just plug the network cable to the pc and linksys device
Apr 06, 2008 | Computers & Internet
Dell Inspiron E1505 Notebook Logo
1,263 people viewed this question
Alun Cox
