Question about Dell Latitude D505 Notebook
Dell laptop internet connection problem
I purchased a used laptop and I am having problems getting it to connect to my wireless linksys.
The linksys is working correctly as there are 2 other computers linking up to it.
It appears to be something monked up with the laptop.
It’s a Dell Inspirion E1505.
I don’t even know where to begin as I am almost a computer dummy.
I have followed the “diagnose connection problems” and did a “repair” thing.
Sometimes it works momentarily, then loses connection and info says limited or no connection.
Someone please help!
nightgirl
  • Anonymous Feb 16, 2009
    When I click on Wireless Network Connection (on the laptop with no connection), it says there are no wireless networks were found in range, so I can't get to the IP address. What else can I try?
  • 520 Answers
Ok ...on one of the other pc's that do connect ok go into control panel...open network connections...click on wireless icon to highlight it...in drop down menu(now exrended)choose change settings of this connection...this will open wireless properties....
scroll down the list to internet protocol (tcp/ip)double click to open ....check ip address,subnet,gateway and dns server...write down the info in the fields...if theres no info (because obtain ip auto is set)connect to internet...youll see wireless icon in sys tray(bottom right in screen) double click on this icon...a box will appear giving you connection status ...click on support and you can find same details there.you can now close all programs and turn off pc if you like...boot up pc that cant connect.. do same precedure to get to wireless settings and in the given fields write in the info you now have like ip 192.168.0.3 subnet 255.255.255.0.gateway 192.168.0.1 dns 192.168.0.1 ....and now you should ba able to connect no prob
Posted on Feb 04, 2009
Wireless Connection Problems between an Dell Laptop and Actiontec
Have you got permission to connect into her Internet using her wireless router?
If so you need to get the WPA encryption key from her to configure your wireless card's encryption to get access.
Jun 28, 2009 | Dell Inspiron E1505 Notebook
Windows vista laptop lost connection to the internet
Start off simple. Try a different port on the router. If that doesn't work, try a new cable. If that doesn't work, go to the Device Manager in Windows. (Right-click My Computer, select Manage, go to Device Manager). Does the card look okay? Has it been disabled or need a driver update? If we're still looking at issues then I would take a look at your router security. How many DHCP licences do you allowed to be assigned? Also do you have security in place (WEP/WPA, Mac Filtering, SSID Broadcast)? If you are light on security and only have a few assignable DHCP licences, you may have neighbors leeching your internet access.
To clarify: DHCP assigns a network IP address to each device on its network. Most Linkys routers have a default of 10, you may have reduced this yourself. If you have, you've limited the # of devices allowed on the network. So if you have 3 DHCP licenses available, and a couple neighbors are leeching, your Dell may not get assigned an ip.
If you still need further help, let me know.
Jun 24, 2009 | Linksys Ultra RangePlus Wireless Routr...
Dell Latitiude D 610 unable to connect to internet
When the network-cable from your computer is connected to the Cisco LinkSys router, click START -> RUN -> 'cmd'
and press ENTER.
Enter 'ipconfig' and press ENTER.
Look for a line like:
Default Gateway . . . . . . . . . : 10.20.30.40
Open Internet Explorer, and enter: http://10.20.30.40
to connect to the web-server "inside" the Linksys router.
Enter the router's password (probably still 'admin'),
and you can then configure the "wireless" settings inside the router.
Once configured, you can disconnect the network-cable,
and start using the wireless-adapter _inside_ your computer.
May 21, 2009 | Dell Latitude D610 Notebook
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Mar 11, 2009 | Linksys WRT160N Wireless Router
Connecting lap top to internet
Try to connect with wireless lan to linksys router. first u shuld check ping the ipaddress of linksys router with laptop
Jobi
Feb 21, 2009 | Dell Latitude D600 Notebook
Dell Dimension DE051:Wireless Internet Problem (Can't Load Sites)
contact Comcast and have them reset your IP address. also have them ping your modem after they reset IP.
Also, see Linksys website for LELA (easylink advisor) to add devices to network. Uses a good bit of memory so don't allow to run automatically at start up.
Dec 30, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Problem connecting linksys wusb54g wireless to internet.
Sounds like you need to reboot the router and probably the cable modem. Unplug both, wait 30 seconds, then plug them back in. It can't hurt anything and it solves this problem 90% of the time.
Dec 06, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
I recently purchased a new desktop which I had linksys connected to my old pc so that my laptop would work wirelessly. Both are Dell computers. I have a Linksys WRT54G router. I have Vista and the...
I don't see why not..
are you trying to hook up both computers to your linksys router?
if you have 3 computers now... I'm assuming your old pc was connected directly to the router, your laptop was connected wirelessly and now you have a brand new computer that you also want to connect to the internet using your lynksis router.. you should have not problems doing it, wirelessly or using a wire...as long as your router has ports avaliable...
Sep 21, 2008 | Computers & Internet
Dynex
just plug the network cable to the pc and linksys device
Apr 06, 2008 | Computers & Internet
Dell Latitude D505 Notebook Logo
334 people viewed this question
Alun Cox
