Question about Kenwood VR-307 Receiver
Rear speakers won't play sound.
I ran the sound test and found all channels are producing sound, but when I play dvds that have 5.1 sound nothing plays out of the rear channels. i have a single red cable as part of a rca cable leaving the digital audio output on my dvd player and am sending it into the digital audio video 3 input on the back of the kenwood receiver. the light shows it is playing dolby digital and the Front left, right, center and subwoofer are all working, just not the rear. Any ideas?
  • 24 Answers
Check on the front of the unit for a speaker selector- make sure A & B is selected
Posted on Feb 04, 2009
4 Suggested Answers
  • 24 Answers
SOURCE: Connecting Powered Subwoofer to a Receiver
you will need a line-level converter to use this subwoofer- it is a rectangular-shaped box with wires coming out on one end and red-and-white RCA plugs one the other. The end with the wires coming out will hook to the receiver, and the other end will need to plug into the sub.
Posted on Feb 21, 2009
lynchms
  • 93 Answers
SOURCE: JVC - Problem connecting a Powered Subwoofer to a Receiver
Have you set speaker setup configuration to SUBWOOFER YES? Also check SUBWOOFER OUT ON/OFF button on the front panel.
dunnbiker
  • 8546 Answers
SOURCE: Cant get bass, fuse is fine
You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
Posted on May 16, 2009
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
Speaker output doesnt work
Hi when using surround sound its important to understand that not all soundtracks have a "rear channel' meaning that the rear speakers will not always produce sound. In fact the rear channels may only produce sound about 10% of the time.
Your receiver has a "test tone" which sends a tone sound through the 5 speakers you should turn the speakers up or down so that all 5 speakers produce about the same volume.
The speakers of course will have a different sound to them depending on the brand and model but just try to balance it as much as possible.
Should also point out that you need to start out with at minimum a STEREO signal and that it needs to be connected with good quality cables. If possible use the optical inputs or HDMI which is a digital signal but not all receivers have that capability.
Lastly play around with the settings Dolby is of course the standard but many receivers have Neo or other proprietary surround formats which may produce the desired effect.
Hope that helps
Jan 02, 2010 | JVC RX-558V
Sound from 3 channels only
Sometimes what happens is that people r just confused with all wirings.Considering that you have connected the speakers correctly...Now according to u the center speaker is not working
  1. If u have a jack attached at the end of the speakers then try connecting the center speaker jack into the Right front/Right Rear/Left Rear socket at the back of the reciever.Just to make sure that your speakers r fine.
  2. Secondly play an audio cd first,sumtimes a video DVD not being 5.1 channel one confuses a lot.
  3. Assuming that you have checked the center speaker,like I asked u too,Connect it into its proper socket or better connect all the speakers.
  4. Now with the remote you check the predefined equalizer in it n keep changing that [pop,rock,jazz etc] or you might even want it to change it to 5.1 from a 3channel or 2channel Stereo.Everytime you change it listen to every speaker.
  5. Also check that you have increased all the speakers volume one-by-one.
  6. Disconnect any headphones attached.
  7. Switch on the selected source or select another source.
For further details u can check the manual.
The VGA cable of the monitor will work fine.
Jun 03, 2009 | Philips HTS3450 System
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Hi, first of all did you verify with the manual if it is possible to run a testsignal through all 5 channels?
One of the most common problems in this case is the basic settings of the device. If you don't have the manual, mostly you can download them from manufacturers website. Chances are that for some reason the setting is set 3.0 stereo (also known as 3channel sound) which is always the 2 fronts and the centre speaker.
Best thing to do it is take a DVD with THX on it and run the THX setup, it will send test signal to all channels.
Jan 15, 2009 | Philips HTS3450 System
Sound on DVDs
It sounds like she has the player set to output 5.1 surround sound, but only has left and right channel speakers hooked up. Either change the dvd player to only send two channels or hook up a center channel speaker.
Jan 01, 2009 | Computers & Internet
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
Trouble with Speaker 5.1 +Vista + Asus P5k Motherboard. No Rear Speaker sound
Hi Perseo,
If you run through a speaker test in windows, and hear playback from all 5 speakers and the subwoofer, then your system is correctly connected, and working properly.
Vista uses a layered sound system that renders sound a bit differently than what you're used to on your previous system. As a result, it will most often refuse to project stereo sources in 5-channel surround, on it's own. it will just play them as stereo, and the bass will fill in whenever it can.
One possible way you could use to get around this, is to force the system to use all 5 speakers, through the driver. If you're using a realtek onboard card anything like mine (I have a p5k-VM board myself), this can be done by opening up the HD Audio Manager, and selecting the "Speaker Fill" option, under the Speaker Configuration" tab.
another option would be to load your media player you use to play music or movies, and see if there's an option to change speaker settings within the programs.
hope this helps!
Dec 30, 2007 | Logitech X-530 Computer Speakers
Kenwood VR-307 Receiver Logo
237 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
