Question about Empire RH35 Mid-Size Heater
Does not put out enought heat
This is an empire dv wall heater
  • 72 Answers
Hi this is tech crazy
the solution and reason to the problem mentioned by you is as follows:
As cold water comes in, it remains at the bottom of the tank because it is denser than hot water. If you use the hot water faster than the heating elements can heat the incoming cold water, and if you consume all of the hot water that the tank holds, you run out of hot water in the middle of your shower. If this seems to happen too often, it could mean that the bottom heating element in an electric water heater has burned out or that your water heater is too small for your house. Or it could mean that you are taking really, really long showers.
Hope this helps u a lot
Please do rate me on the above said solution
Posted on Feb 04, 2009
Empire heater is lite but wont come on
have you check the switch if it is break ?or maybe it has used for a long time .it was out of work .and couldn't discover .you should change a new one.
wall light
May 03, 2012 | Empire DV-35 Heater
EMPIRE MANUAL DV2353SG
I believe all the Empire manuals are there to download or read at their website: EmpireComfort.com.
Nov 08, 2011 | Empire Direct Vent Wall Furnace;...
Low flame and heat output want 2 clean burners etc
This can be done by using an air compressor. Just simply blow out the orifices and the injection tube. That will clean everything out. This may also be a propane pressure problem. Try cleaning it first and then check the inches of water on propane or natural gas.
Jan 23, 2011 | Empire DV-215-SG Wall Mounted Panel Heater
Have an empire wall furnace. Natural gas. Vent through the wall. My problem is that sometimes when it ignites, it makes a loud boom and I can see a flame flash at the top of the heat exchanger. I was...
Not sure what the problem is, but mine does the same thing.It also blows the pilot light out when it does it..Had several service calls, no luck...POS, don't buy another Empire heater....
Nov 09, 2010 | Empire Hight Efficient Direct Vent Wall...
DV-35 safety
The Empire DV units have been in production for over 25 years with very few problems and no class action suites. Although the heaters do get hot, so don't wood stoves, kitchen ranges, etc... I suppose they could put a sticker on the cover stating not to put anything on the heater, but I suppose it would burn off eventually. I would not worry about a statement of a faulty furnace because he/she would be fighting with a very large company with plenty of lawyers on the payroll. It should be expected that a heater will produce heat. If the tenant is concerned, remove the heater, install electric heat and let them pay the electric bill. I am sorry but your tenant needs to start using some common sense! There are no safeties built into this unit to detect when someone puts something flammable on it and I know of no heater that does. Remember, you did not make the heater, you did not spend thousands of dollars getting it tested and approval from UL, you may have purchased the heater and had it installed to provide a low cost alternative to other heating equipment but it is not you that is responsible for what has happened. If I were you I would hand deliver a note to each tenant who has this type of heater alerting them of the risk of damage if they left gloves, hats, buckets, etc.. on the heater and have them sign that they read it. The furnace is designed to be safe, burn clean and heat. Good luck.
Jan 18, 2010 | Empire DV-35 Heater
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
Empire DV-35 low heat low flame
Check your gas pressure, You could have a gas valve problem or you could have a restriction in the air intake.
Sep 04, 2009 | Empire DV-35 Heater
Empire RH35 Mid-Size Heater Logo
149 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
