Question about Philips DVDR3506/37 DVD Recorder
Region hack for Philips dvdr3506/37
Does anyone have the region code hack for this unit?
devocap
  • 201 Answers
SOURCE: UNLOCK REGION CODE FOR PHILIPS DVDR3475/37 Recorder
Your device is designed for playing back region 1. It will also playback disks recorded with a region setting of all. The region setting of the device is fixed. Also it will only playback NTSC, and not PAL . This is also fixed on your unit. Sorry I could not bring you better news. However there are many burning and conversion programs you can use on your computer (ie Nero Vision, ConvertXtoDvd,..) which provide you the optional settings you are looking for, and allow you to burn in the setting you choose, allowing for playback on your Philips device. Good Luck!
Posted on Feb 07, 2008
SOURCE: region code
1. Open the tray
2. press the following sequence using the number keys: 98790 (this is equivalent to the code 9879 with the zero at the end representing all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
Posted on Jul 06, 2008
jaffa012001
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
jaffa012001
  • 376 Answers
SOURCE: Hi i need to find
1. Open the DVD cover
2. Press setup
3. Type 9 6 5 3
4. Press the Arrow Key up or down and select 0 for region free
5. Hit OK
Posted on Aug 29, 2008
  • 32 Answers
SOURCE: How to make DVP5990/37 Region Free
First I recommend that you upgrade the factory firmware to the latest version. The current version is .31 and available here. Click "I accept" to accept the license agreement and start the download. Open the zip file and burn the file named DVP5990_37.bin to a CD. Put the CD in the DVD player and it will begin the upgrade and open the DVD tray. Remove the CD but leave the DVD tray in the open position. After just under 10 minutes (6-8) the DVD player will report that the update was successful and close the DVD tray. Press the setup button, go to preferences scroll down the choices (past the bottom of the screen) and select reset to default values. The player will reboot.
Next press Setup
select the Preference menu
Press 1,3,8,9,3,1 on the remote control.
Use the up/down arrows to select region "0" which means all regions.
If you ever get a disc that won't play correctly due to a region error, just use the code above to select the correct region for the disc and you will still be able to play it.
Posted on Nov 02, 2008
Cannot run certain DVd on my Philips S3560 home theatre. It states region code locked for that particular DVD.
Most DVD players have their Region Code locked to only work for the country that the player was purchased from. In other words if you bought your player in Britain and then tried to play a DVD you bought from the US, you would get the error message that you are now seeing. The manufacturers do this due to the licensing agreement they have with the studios. This way you are limited to DVD's only from the country of origin.
That being said they are people who hack into DVD players and are able to read the basic operating system of the player. They are then able to find the unlock code that will allow the player to play DVD's from any region. They will then post those codes and the method to enter the codes, on different websites so that anyone with one of the model numbers listed can unlock that player.
Unfortunately not all players have been hacked this way. I searched the different sites on the Internet and your player is not listed. This means that for now you will only be able to play DVD's that are coded with your players Region Code, or DVD's that are branded as having no Region Code on them. There are sites on the Internet that sell these types of DVD's, and you can find them by simply searching using Google.
The other alternative is to purchase one of the hacked machines that are available on the Internet. These seller's have hacked their players permanently so that they will play any and all Region Codes right out of the box. Again if you do a Google search you will find many sites that can sell you a hacked unit. They even sell the same type of system as your present home theatre.
May 15, 2011 | Audio Players & Recorders
Wrong region error. DVDs dont play and I dont know how to change the region settings
Try searching the net for 'region code hack' for your model number. You can try on Fixya too, this time just put the above. If anyone knows it you should get a reply.
Jul 06, 2010 | Philips DVP642 DVD Player
Need multi region hack code pioneer dv-220v-k
There is no need for region hack on this unit. It plays region free and all PAL dvd's out of the box without reprogram.
Dec 12, 2009 | Pioneer Televison & Video
InVision Revolution series car DVD need to unlock region codes
region codes are only available from the internet by bright people who have figured out how to "Hack" into the software of the device and they call this a "Region Hack", as of this date there are no unlock codes avail for this unit, most of the codes are for mainstream home units and not the car mounted DVD systems. The manufacturer will not provide software updates, the legal status of region hacking is under litigation to determine whether it is copywrite infringement, what this means that soon it will be illegal..
Jan 03, 2010 | Car Audio & Video
Changing Region Code of Philips HTS9800W (from 4 to 0)
if you go into my computer and right click the device then properties, hardware then double click ur drive and region will be a link at the top set it to your region and your all set. remember you can only change the region 4 times!!
hope this helps
Apr 14, 2009 | Philips Cineos HTS9800W System
Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup. [from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Jan 02, 2009 | Philips DVD625 DVD Player
How to make philips HTS3565 region free. Any help will be appreciated. Thanks.!
icon_minipost.gifRegion code hack posted by videohelp4k1ng, July 27 2008:
Hack for HTS3050 also worked with my HTS3565D.
Open the tray. Press 99990 on the remote.
Region 0 will appear briefly on the left of the screen.
icon_minipost.gifRegion code hack posted by rocky631689, August 01 2008:
Also works on my Philips HTS3568DW/75
THANK YOU!!!!!!!
icon_minipost.gifRegion code hack posted by mikoyan, August 05 2008:
I´ve just applied to my HTS3565D/37 and it worked great. Do not expect it to show anything in the display, though. You open the tray, click the sequence in the remote and... Done!
Sep 03, 2008 | Philips HTS3500S System
Multi Region hack for Sony DVP FX 820
Buy the Philips PET1030 instead.
Aug 29, 2008 | Televison & Video
Philips DVDR3506/37 DVD Recorder Logo
207 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
