Question about Acer Aspire One PC Notebook
STATIC IN RIGHT SPEAKER
I HAVE STATIC IN THE RIGHT SPEAKER OF MY ACER ONE, DONT KNOW WHAT'S CAUSING THIS.
ANY INFO ?
  • thomasmoore9 Feb 05, 2009
    Thanks for the info
    Scholar:
  • 116 Answers
Generally if it is only one side, the actual speaker has failed. Try connecting headphones, if they are fine than the soundcard (chip) is fine.
This would indicate that the speaker has failed (a lose connection inside can do this as well but that is much more rare).
Posted on Feb 04, 2009
Sansui au-999 static right speaker then blows right speaker fuse
so meaning the right speaker needs a filter which frequency is it normaly u using a certain yf for a certain type of speakers and if you dont the fuse or what ever will go
Apr 15, 2012 | Audio Players & Recorders
I have a lap top easynote TJ75 .with no valid reason my right speaker is not working properly.Sometimes it makes sound with hissing or sometimes it plays normally with hissing.The last thing I did was to...
if these speakers are external as it looks like
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
if its still under warranty take it back
hope this helps
Jul 18, 2011 | Packard Bell Speaker Computer Speakers
Why is it that only one of my Philips speaker is working on the right side, but not on the left side speaker (no sound coming from it at all) after plugging into the USB port of my ACER laptop computer...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 15, 2011 | Philips SBP1100/37 Portable Speaker System...
I purchased theses speakers January, 2011. At first they worked fine. Then I started having problems getting sound out of the left speaker. The sound would return when I plugged and unplugged the speaker...
hope this helps
Jun 04, 2011 | Bose Companion 2 Series II Multimedia...
Hello I have a set of Altec Lansing ADA215 speakers, and one of my speaker has very low sound level. This was not before I dont now what happend I hope you guys have an idea. Thanks B.Versloot
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Apr 10, 2011 | Altec Lansing ADA 215 Computer Speakers
No sound right speaker
dont forget to vote
hope this helps
Feb 06, 2011 | Labtec LCS 2422 Computer Speakers
2.0 CH USB POWERED SPEAKER SYSTEM
The static is probably coming from the computer sound card itself. Turn the volume down on the computer mixer it should limit the static you are hearing.
Jun 07, 2008 | Audio Players & Recorders
Speaker static
first check the sound options if it is alright then check the connections though you problem is not solved you have to replace the speaker.
May 25, 2008 | Sony STR-DE598 Receiver
Right rear speaker has static
Sounds like damaged channel in output circuitry. Take to pro/tech
Apr 12, 2008 | Sony STR-DG510 Receiver
Static from left speaker when adjusting volume control
You might try replacing the connection cables. Old cables can cause the problem you have experienced.
Dec 26, 2007 | Audio Players & Recorders
Acer Aspire One  PC Notebook Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
