Question about Microsoft Xbox 360 Console
Console now begins not in color on HDTV
My console now begins in non color, and it has been working fine.
  • Microsoft Master
  • 2,404 Answers
I would suggest to try a different A/V cord to make sure that your original one is still good. If the Problem still exists then its a problem with the main board and it would need to be replaced.
Posted on Feb 04, 2009
I have a Sega Saturn with about 15 years. I unboxed it and started to play my games. Everything worked fine until Resident Evil 1. I start the game (everything fine, menu fine, options fine, intro movie...
It sounds like its definitely something wrong with the system. There must be something about this game that the system is having trouble reading correctly. I don't see there being much of a fix for this unless maybe you brought it in to a local game shop and had let look at it.
Aug 12, 2013 | Sega Saturn Console
I've had a slim PS3 for a few years now and just today, shortly after a usual system update, it started flickering constantly. Not the whole screen is affected but only some especially bright colors, e.g....
First, back up all of your saved data to an external source. Then, to a factory default reset of the system and redownload the update. Check to see if problem persists, if not, copy back all of your saved data and you should be good to go.
Aug 09, 2013 | Sony Playstation 3 (PS3) Console
I moved my ps3 from my hdtv to non hd tv and used the 3 colored audio video wires to connect to the tv but the screen stays black
Hello, you will want to reset your video output.First with the power off, push and hold down the power button till you hear the second beep,then release.Your picture should show in approx 7 seconds.
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
I am trying to move my ps3 from an HDTV to a non HDTV and it won't work on the non HDTV with correct cables used
Ok what you need to do is turn your PS3 on. Then press and hold the power button for 5 seconds. This will revert the video back to standard definition and hopefully cure your problem.
Aug 09, 2010 | Sony Playstation 3 (PS3) Console
My fc twin works fine on my regular tv, but when I plug it into my Hdtv i get sound no video what should I do? Also there is no game mode on my hd tv so its not that!!!
you need to go into settings on tv and put it to non hd or standard , the console came out when standard tv was in or black and white, setting output = not hd you may be able to put it on auto
Jul 18, 2010 | YOBO Fc Twin Console
I have a Samsung and just hooked up a Wii and am getting only black and white on the screen. How do I troubleshoot this? Thanks.
Your TV is probably an HDTV. Change the settings of your Wii to HD and it should have color. If you don't want to do that, make sure your RCA cables are pluged into the non-HD RCA slots on your TV and that the yellow cable goes to the yellow non-HD slot and not the green HD one.
Dec 14, 2009 | Nintendo Wii Console
Color distoration, then the game froze and now video wont work
It could be as simple as the video cables. Get another set of cables and try it. You can get them pretty cheap on auction sites. IF that dont work then I would say your headed for the 3 red lights or no video problem. If thats the case then check with ms and see if your still under warranty. If not we can help. We are registered repair service on this site. thanks
www.videogamerepairservice.com
Jan 29, 2009 | Microsoft Xbox 360 Console
Panasonic PT-53wx53G 53' projection tv problem
was your tv hit hard,a non magnetically shielded speaker set on top or under it?
Nov 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Xbox 360 60Hz over-satured and displaced colors (normal TV, non HD).
Make sure you have the right colors wires in the right ports
Sep 01, 2008 | Microsoft Xbox 360 Console
Color distorted when viewing non-hdtv
convergence ic going. you may also want to check some caps;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Dec 17, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Microsoft Xbox 360 Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
