Question about Nikon D90 Digital Camera with 18-105mm lens
I get an ''err'' error report on my D90, what do I do!!!!!???
It wont let me take pictures normally and i just got it
please HELP!
  • 13 more comments
  • Anonymous Feb 11, 2009
    I GOT A "err" message,and it cant help me to take the pictures
  • dennisusky Feb 13, 2009
    I have the same problem. It occurs often! I've noticed that when I am ready to take a photo if the shutter speed indicators says "Lo" and maybe if the aperature indicator says "F--" and I depress the shutter button, then ERR occurs and CHR appears, indicating that it is a memory card problem. However, no end of different memory cards prevent this, and after I clear the error, there seems to be no problem with the card same card. A very bizarre effect then happens when I get this error. Even if I turn the power switch to Off, the camera will not turn off! It's frozen on, but will not respond in any way. The only cure seems to be to take the battery out to force it off, and then to return it and turn the camera back on.
    I use the MB-D80 Power grip loaded with AA NiMH rechargeable batteries. The problem occurs regardless of the level of battery charge. I have not noticed a pattern with normal or cold temps.
  • dnana Feb 27, 2009
    I too experience the ERR and CHR errors, my d90 is 2 months old. I have to pull out the battery to switch it off. After a reboot, it works ok.
    This problems seems to be very common, i'm seeing a lot of it on the internet.
  • drewmain Mar 05, 2009
    i just got my d90 3 days ago great camera. worked great until tonight when i was taking some pictures of a sunset tonight and than "err" popped up on my screen. i noticed that my lens kept unlocking of the body with out me pushing the release button. took the lens off and notice that one of the plastic connectors thats holds it onto the body was busted. since i am relatively new to photography i don't have any other lenses to try to see if i still get the "err" msg.
  • Anonymous Mar 05, 2009
    I was on a photo shoot today and it did the same thing to me - ERR. Out of nowhere this happened. I was using it on a complete auto setting in sunny 70 degrees. I was so frustrated! Like to other guy said, I had to take the battery out to clear it because it froze up. I got this D90 for xmas and its been giving me probs ever since. On xmas day I was getting the F--- flashing, and i can only get that to stop if i take the lens off. I'm seriously considering returning this camera. Very disappointed since its a Nikon!
  • KR2009 Mar 08, 2009
    I had the same problem with ERR message suddenly in the midst of a shoot. I guess it is a problem with changes in Humidity.
  • Veloce916 Mar 13, 2009
    I get the same problem. You have to remove the battery to reset the camera and then it does it again a few shots later. I am using an 8 gig SanDisk Ultra II card. Don't know if that's related or not
  • Anonymous Mar 16, 2009
    I have the same problem; the F--- message is alot more common than the ERR message however.
    I personally resolve the F--- message either by slowly rotating the focal length of the lense (usually from a large focal length like 105mm to 18mm). Or I turn the camera off and back on again.
    Apparently this is caused either by a non CPU lense attached, or not attached correctly. The other thing it could be, according to the manual, is something to do with the aperture. It says it in the back of the manual.
    To resolve the ERR message, I turn the camera off and take out the battery then replace it again. In the manual, it says if the mesage persists, you need to contact Nikon - not ideal!
  • nikiCanada Mar 24, 2009
    After taking a photo, I get an err. The camera froze. To unfroze, I had to remove the battery. Put the battery back, turn the camera on, I take on picture. Err flash again. I remove the battery again. the camera unfroze and I take a few more pictures. Err returns. I have a 2G card as well as a 32G card. The err . . . message happens every other picture with the 32G card. Err . . . error message less frequent with the 2G. Very annoying. thinking of return the camera for a full refund.
  • Anonymous Mar 24, 2009
    same problem - can't focus time after time. It worked good before! Nevertheless, it's been given F--, ERR etc. since few months ago. Any solutions?
  • nikiCanada Apr 04, 2009
    my D90 froze once a while during the first week of ownership. then just a few days before the 90 days warranty, it keep giving me ERR message. I gave up and return it for full refund. The ERR errors keep coming back. I was expecting something better from Nikon.
  • kuryaking Apr 06, 2009
    Yup this happens to me too. I am very dissapointed.
  • ghumphreys May 08, 2009
    I had the same problem (18-105 kit). I even exchanged the kit for a new one, and had the same issue. I'm convinced it's the connection between the camera and the lense - when I wiggled the lense, it would sometimes return to normal. But usually I had to remove the battery to get it back. I considered cleaning the contact points, but then the problem just went away. I've been shooting hundreds of times, without it happening once - although I haven't taken the lense off the whole time.
  • Sujith Gopinath
    Sujith Gopinath May 11, 2010
    Please give a detailed, step-by-step account of what you did before getting this error. And what is the error message you get?
  • Sujith Gopinath
    What is the error message you get? What did you do before getting this message? Without knowing all these, I wouldn't be able to help.
    Novelist:
    Scholar:
  • Nikon Expert
  • 197 Answers
The Nikon D-90 manual addresses this problem on Page 256.
It says that ERR indicates a camera malfunction and can be cleared by releasing the shutter.
I usually have to turn the camera off and back on to do this. Sometimes, I have to remove and reinstall the battery.
In an emergency situation, you may be able to continue taking pictures in the manual mode but you'll have to set the shutter speed and aperture yourself.
The manual also says that if the problem persists to contact a Nikon authorized service center. Before doing that I suggest you contact Nikon tech support at www.nikon.com and see what they have to say about the problem.
Posted on Sep 20, 2014
3 Suggested Answers
SOURCE: Nikon D90 ERR message after taking picture -
I have the same problem like you. I take 3 photos with my Nikon D80 and this message came out : ERR ... I have NO idea what should I do ? ! Please help me... Lucas
Posted on Dec 06, 2009
SOURCE: My d90 flashes an err sign somtimes when i shoot
Try shooting in manual mode with lens set at maximum (wide open) aperture. Then try at a smaller f-stop, say 5.6 or 8. If the error message appears when your lens is set to the smaller aperture, you could have a lens problem. Try another lens using the same test. If a known good lens gives an error message, then the problem is in the body. Also try zooming to different focal lengths and see if your 18-105mm gives the error at particular focal lengths. An error here would indicate a lens problem. In any case, your lens or body would have to be repaired by a professional as these repairs require major disassembly and re-calibration.
Posted on Dec 02, 2010
I'm getting a r16 error on my D90
The "r16" in the display is not an error code. It is simply informing you of the number of exposures that can be held in the camera's internal high speed memory before shooting would have to stop while the D90 transfers the pictures to the memory card. If you held the shutter release, you could watch the r16 value decilne by one for each exposure (r15, r14, r13, etc.).
Page 256 of the D90 User's manual indeed shows the Err error code, and defines it as a "Camera Malfunction", "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." The "err" error code is a generic error. The camera has detected a problem, but it doesn't know exacly what, similiar to the fEE code. The "err" code could be camera / lens contacts or it could be a circuit board or even shutter failure. You've already tried the common contact cleaning fix (that never seems to solve the problem) without any luck, so you might have to call Nikon Support and arrange for service.
Jan 31, 2013 | Nikon D90 Digital Camera with 18-105mm...
I used the Nikon D90 with Lens Kit 18-200 mm, and I also bought the new Lens call Nikkor 75-300mm. But when I connected the new one (Nikkor 75-300 mm) in my camera and took some pictures, after that I...
That's the Nikon error message for a lens with aperture ring set to something other than the minimum (i.e. highest number).
The camera insists on controlling the aperture ring, and to do so, the ring must be set to the minimum setting.
Unless it is a "G" lens, which has no aperture ring whatsoever.
The camera body sets the aperture of the lens wide open while auto-focusing, and displaying through the viewfinder. When it comes time to flip the mirror up and take a picture, the camera dials the aperture to the setting you (or the camera) have selected.
Dec 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
I have a nikon d90,when i pressed shutter button ,it is giving err message then i press second time it is not giving err message but not taking the photo.
This is an indication that the camera is not "talking" to the lens correctly. When you press the shutter button, the camera tries to focus, set light levels, and then shoot the picture. If it can't focus or set F-stop and shutter speed, then it can't shoot the picture and gives you the error indication. SO
1. You need to make sure the lens is an automatic lens capable of working with the D90. 2. You can take the lens off and back onto the camera a few times in case its a dirty contact issue or just didn't seat correctly. 3. Set the D90 to manual and make sure you move the AF selector on the front to M. Then you would manually adjust all the settings. That should take the auto-coupling out of the picture (pun intended)
4. If it still shows error when in total manual mode, there may be something wrong in the camera itself. Before giving up, do a total system reset on the D90 (I assume you have the manual).
Nov 15, 2010 | Nikon Cameras
My D90 sometimes has an err message and also a CHA in the the ISO mode. Also there is a green LED on the back of the camera that stays on. The only way to get all this cleared is a battery pull. When this...
CHA indicates a problem with the SD card. ERR indicates a camera malfunction. Try reformatting the card which may clear the problem or try a different card. The card may be creating the ERR message. On page 259 of the D-90 users manual, Nikon says this error can be cleared by releasing the shutter but the shutter will not release unless you turn the camera off and back on. Rarely, I have to remove the battery and reinstall it before the shutter will release. The camera will not function at all until the battery is reinstalled.
If you cannot resolve this problem using the above suggestions, I'd recommend that you contact Nikon technical support at www.nikon.com and see if they can help.
Sep 12, 2010 | Nikon D90 Digital Camera with 18-105mm...
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
I shot a wedding and got the ERR message 3
Take your manual reset a little further...remove the card and battery...press all the buttons...leave the camera alone for at least 20 minutes...insert the card and then the battery...turn it on. See if that works.
Oct 08, 2009 | Nikon DSLR D90 Digital Camera
Is there a memory card in the camera?
Also try cleaning the contacts on the lens (light rub with a pencil eraser works).
Aug 07, 2009 | Nikon D90 Digital Camera with 18-105mm...
Got the shutter and mirror clicks and err msg
bring it to your nearest nikon shop for a check up. i suggest a mirror lock up / shutter error.
Jul 26, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 problem!
contact to nikon you have the warranty.
Apr 10, 2009 | Nikon D90 Digital Camera with 18-200mm...
Nikon d90 - can't take the picture
You just found the Nikon D90 F-- error message solution!
I had the same problem with the Nikon d90 F-- error message which drove me nuts!
I called Nikon, they walked me through a lengthy reset procedure which didn't work. After spending a few hours researching online, I found the answer.
It is not the memory card or nor a defective camera body. The lens does not need to be rechipped.
The F-- error means the camera is unable to communicate with the lens and is caused by a poor connection between the ground contact pin on the lens and the metal mounting ring on the camera. Most people buy the camera, install the lens once and then encounter the error. This one time lens installaiton does not give the contact point a chance to seat itself properly. You will find that if you hold down the lens release button and twist the lens as if to remove and reinstall the lens about 10 times that the problem will disappear. You don't even have to actually pull the lens away from the body, just press the release button and twist on and off and allow the friction to provide a better electrical contact.
Too bad Nikon doesn't tell their customers about this simple fix. Other than that, great camera. Good luck.
Dec 07, 2008 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 Digital Camera with 18-105mm lens Logo
1,135 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
