Lg WD8013f frnt load washer seal broken
I have taken off the old seal on washer but cannot get the new one to stay on so that i can put the cable and spring bk on to hold in place; can u pls help kelly Hi I have a LG WD1049C which is leaking huge amounts of water from the front door. The entire door doesnt seem to be fitting properly to the washer. I'm having floods!! The seal is intact the washer is only 14months old. Any suggestions??
    Scholar:
  • 99 Answers
Hi this is joyce
I hate to tell you this but I work selling appliances and my advice is to call a technician for this type problem, you dont want any leaks of any kind. get a exspert to do it. it is very complacated to do.
if you need me to help you find a technician in your area I will be glad to help.
thanks,
Joyce
Posted on Feb 07, 2009
Model wm0642hw front load. it leaks by door frame.rubber seal with clamp.only 2 years old. do i need to change the door frame outer part a151? thanks for your response in advance
Hi, If the door isnt loose or broken? Its more likely to be the rubber door seal if its leaking between the seal and the door glass. Check the edge of the seal where it touches against the glass for damage or ware if its ok clean any soap residue or bits from the glass.If it still leaks change the door seal.
Regards Elect App
Jul 13, 2011 | LG WM-2277HW Front Load Washer
Machine wont pump out water, stops before spin cycle is a wd8013f cheers
Try emptying the filter n then put it on a boil wash (empty) it mite jst b glogged up :-)
Feb 20, 2011 | LG WM-2277HW Front Load Washer
Circular grey rubber part ..
firstly u have to take the wire off it with a screwdriver unscrew it take it off then watch how the old on pulls off as there is a lip all around this rubber and it as to bed into the metal drum just see how the old one comes off once you have put the new one on put the wire back around it or it could be a metal strat wich tightens up with a screwdriver,rgds,paul
Jul 07, 2009 | LG WM-1832C Front Load Washer
LG WM2277HB drum wobbles when doing larger loads.
You could have a broken strut. However, keep in mind that these units are designed for 16llbs of dry weight for optimal performance.
Nov 27, 2008 | LG WM-2277HW Front Load Washer
LG doesn't spin!
Are the 4 shipping bolts taken out of the back of the machine?
Nov 03, 2008 | LG WM-2277HW Front Load Washer
LG Top Load Washer
this could be a drain hose loose or broken if the leak only occurs during rinse. If it leaks all the time, could be a broken outer drum or worn tub seal.
Hold inner drum and turn bothways. If it turns bothways, you have a bad bearing, and hence, a bad tub seal. If it turns in one direction only, bearing's good; but tub seal could still be bad.
Jul 17, 2008 | LG WFT1071TP Top Load Washer
The inner spring cable is a tough part to put back on without a special tool.  You're best bet is to remove the front cover of the washer to try and reinstall the seal.  If it doesn't work, you will need to call a qualified LG technician to help you.
Jan 06, 2008 | LG WD-1080FD Front Load Washer
Washing Machines Logo
140 people viewed this question
Top Washing Machines Experts
