Question about Cisco (1841) Router (cisco1841)
Cisco 1841 router
I have a new cisco 1841 router and i bought a HWIC 1T serial card and installed it into the router but the router would not recognise the card. according to the logs it say '..CFG-3-CARD_NOT_SUPPORTED'. i seached the cisco site and it says the card is compartible with a cisco 1841 so i'm not sure what else to do. please help.
Jethro
    Problem Solver:
  • 7 Answers
You can ID the cards by seeing if the card has "V2" on the metal plate. I believe an 1800 chasis requires a V2 card.
Posted on Feb 23, 2009
    Novelist:
  • 210 Answers
The WIC-1T cards aren't necessarily compatible across the entire Cisco range. The card you have may be for a 2600 series (or other) but specifically won't work in your 1800 series router.
If you got a box or manual with it, they will have the router model range in it's product code.
I've seen/experienced this many times before. (usually sorting through old cards at work, where it's almost impossible to identify them)
Let us know!
Posted on Feb 05, 2009
Cisco router 1841 connected to serial interface
Make sure you set up correctly the subnet mask.
Jul 29, 2008 | Cisco (1841) Router (cisco1841)
Tip
Cisco 1841 Router, Hot Sales Product Cisco 1800 Business Router
The Cisco 1841 router is designed for secure data connectivity and provides significant additional value compared to prior generations of Cisco 1700 Series routers by offering more than a fivefold performance increase and integrated hardware-based encryption enabled by an optional Cisco IOS Software security image.<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841</a> dramatically increase interface card slot performance and density over the Cisco 1700 Series while maintaining support for more than 30 existing WAN interface cards (WICs) and multiplex trunk cards (voice/WICs [VWICs]-for data only on the Cisco 1841 router).<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841 router</a> offers embedded hardware-based encryption enabled by an optional Cisco IOS Software security image; further enhancement of VPN performance with an optional VPN acceleration module; an intrusion prevention system (IPS) and firewall functions; interfaces for a wide range of connectivity requirements, including support for optional integrated switch ports; plus sufficient performance and slot density for future network expansion and advanced applications as well as an integrated real-time clock.<br /><br />Cisco 1841 router Product Details<br />Product Description Cisco 1841 router<br />Device Type Router<br />Form Factor External - modular - 1U<br />Dimensions (WxDxH) 34.3 cm x 27.4 cm x 4.75 cm<br />RAM 128 MB (installed) / 384 MB (max) - SDRAM<br />Flash Memory 32 MB (installed) / 128 MB (max)<br />Data Link Protocol Ethernet, Fast Ethernet<br />Network / Transport Protocol IPSec<br />Remote Management Protocol SNMP<br />Digital Signaling Protocol ADSL over ISDN<br />Features Cisco IOS IP Broadband , firewall protection, 128-bit encryption, hardware encryption, VPN support, VLAN support, Intrusion Prevention System (IPS), 256-bit encryption<br />Power AC 120/230 V ( 50/60 Hz )<br />System Requirements Microsoft Windows 98 Second Edition<br /><br />P.S. If you would like a new sealed Cisco 1841, the competitive price offered at RouterSwitch.com is US$586.00 per. Visit Cisco 1841 to see more...<br /><br />Notes: Router-switch.com is a World's Leading <a href="http://www.router-switch.com/">Cisco Supplier</a>, founded in 2002. It sells new, used and refurbished Cisco network equipment including Cisco routers 800/1800/1900/2800/2900/3800/3900 series, Cisco switches, Cisco Firewalls Security, Cisco IP Phones VOIP, etc.<br /><br />
on Jul 07, 2011 | Computers & Internet
Connect to cisco 1841
This is more of a business unit. It requires a serial port connection and a fair amount of CISCO networking engineering knowledge. It is command only. No GUI interface.
Jan 30, 2013 | Cisco (1841) Router (cisco1841)
Garbage in Cisco 1841
There are two things that can cause this:
  1. Incorrect serial settings. The default settings are 9600 baud, stop bits of 1, and parity 0. However, it is possible that these settings were changed. Likely, the baud setting may be higher as someone may have tried to XMODEM an IOS image onto the device and wanted faster speeds.
  2. Bad connection, cable
I hope this answers your question.
Jan 06, 2012 | Cisco (1841) Router (cisco1841)
Cisco 1841 reads, Compact flash not found.
Perhap, your Compactflash is not be formated before you insert it into the slot of the Router.
Feb 11, 2010 | Cisco (1841) Router (cisco1841)
Router not responding to http request
possible firewall on the router check settings make sure its not blocking ping requests everything else works?
Jun 05, 2009 | Cisco (1841) Router (cisco1841)
Cisco (1841) Router (cisco1841) Logo
288 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
