Question about Sony VAIO R505JL Notebook
Sony Viro Laptop/ No Power and no boot up
Having turned my laptop off by shuting it down properley, i came to turn it on the next day and no power or boot up; i kept pressing the on button but nothings happened.
The green LCD that on the power pack is visable and i've tryed taking the battery out and then putting it back in but still nothing
Can anyone plaese help me?
    Problem Solver:
  • 4 Answers
When it comes to powering up a system, one of two things could prevent a successful boot.
1. The power supply may be bad
2. The motherboard could have just stopped working.
I have run into problems similar to this with a couple of my desktops.  My desktop had a burned out board and while diagnosing I found this out.  I eliminated the Power supply by trying it in a different computer and it booted over.  Now I know with a laptop it is much more difficult to use this part swapping approach.  To me your best course of action would be to have it sent to the manufacturer if it is still under warrenty or have a technician examine it and see what the true problem is.
Posted on Feb 04, 2009
NP350E7C-A01US samsung laptop windows 8 keep shuting down after 5 mint or some time 10 mint .
are you sure the cooling fan is working . sounds like a overheating problem t me
Feb 28, 2015 | Samsung Computers & Internet
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
My laptop wont turn on and yet its fully charge. The power light keeps on blinking with orange and when i push the start button, it turns green and when i stop pushing, it turns orange again-blinking.
Hi.
This sounds like there is a problem with the battery.
Remove the AC mains power and take out the battery from the laptop. Plug AC power back in and try booting the laptop up.
If it boots up let it boot into Windows/linux and then shut the computer down as normal. Remove AC power and re-insert the battery. Plug AC back in and power it up, see if it does the same thing. If it does the same thing the battery is faulty. If it boots up with the battery in then there was a glitch.
Regards.
Jun 08, 2011 | Sony Computers & Internet
Sony vaio vgn-fj270 bios wont boot, just display [Be-$]Be-$
try to turn off the laptop. Remove cables and battery then press and hold the power button for 8 secs. Then reinsert the cables and battery on the laptop. Turn on the laptop. Check if the BIOS screen appears. If it is still wont boot to windows, try to restart the pc and repeatedly press F8 to Boot to safe mode. If unsuccessful, this might be a problem with the memory of your laptop. If you cannot tear down the laptop, consult a technician to tear it down and reseat the memory .. or better call your manufacturer to repair it...
Jan 05, 2011 | Sony VAIO VGN-FJ270/B Notebook
I have a Hp laptop bt it is now not shuting down ie all its light on keep on glowing even on shutting down and also it makes a noise while shuting down or turning it on
remove charger first and remove battery second to try which one causing problem.
if any power source cause the problem that is mean the mainboard or power board inside failed.
good luck.
Nov 21, 2009 | Computers & Internet
Sony Laptop wont power ON
Try booting it from your CD drive.
Any messages on the screen ? any lights on??
Aug 26, 2009 | Sony VAIO PCG-K35 Notebook
Sony vaio vgn series doesn't turn on no power
You should try another ac adapter.If that does'nt work the power jack where it plugs in may be bad or the power board under the power button is bad.You should try another ac adapter first though.
Aug 04, 2009 | Computers & Internet
Bought 6 months ago and will not boot up, with battrey out it will attempt to start for a couple of secs and then nothing
After 8 days of no life at all in the laptop , having 2 computer technicians around saying it was probably the motherboard and just about to send to Sony I pressed the power button and hey presto it worked again..Guess it was just sleeping or hibernating...after all it is spring now....Actually one guy of the many forums I have visited advised just to leave the Laptop alone and perhaps it would mend itself..and hey presto he was right, although having said that I have yet to turn the laptop off and startup again..HMMMMMMM...
Apr 14, 2009 | Sony VAIO VGN-FS630/W Notebook
Gateway laptop
Probly its overheating and shuting down.But if it do turn on try to run in safe mode by pressing f8 when booting up.
May 28, 2008 | Computers & Internet
Sony VAIO R505JL Notebook Logo
664 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
