Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Original rmote i can adjust the red crosshair up and down with the universal but why not left and right
    President:
  • Philips Master
  • 1,779 Answers
The Univ. is not programed to use the l+R for those types of adjustments.
Posted on Feb 04, 2009
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Tip
    How to set convergence on Projection TV ' s
    I have given an general explanation on most projection TV ' s
    1. Enter the menu on your TV. Use the remote control and bring up the menu.
    2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    4. Press "Enter." A crosshair pattern will appear on your screen.
    5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    8. Repeat these steps for all colors.
    on Mar 18, 2010 | Televison & Video
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Hi in the convergence to adjust the color the red is above the plus sign in 3 spots and will not come down and they are not straight
    does the blue convergence crosshairs move up and down left and right? Does the red move left or right. does the red move up at all. this might indicate a faullty resistor, bad ic or just bad convergence data. let me know i am here to help
    Nov 04, 2010 | Toshiba 43A62 43" Rear Projection...
    I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
    If the following doesn't work the tubes could be at the end of life:
    Adjusting convergence:
    Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
    To adjust the convergence of the picture tubes:
    1. Press the 'MENU/SELECT' button on the remote.
    2. Press CURSOR RIGHT to enter the PICTURE menu.
    3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
    4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
    5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
    6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
    7. Press the 'EXIT' button to exit the menu.
    If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
    To Adjust multipoint convergence:
    2. Use CURSOR RIGHT to enter the PICTURE menu.
    3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
    4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
    5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
    6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
    7. Press the 'EXIT' button to enter ADJUST mode.
    8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
    9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
    10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
    11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
    12. Press CURSOR RIGHT to save the multipoint settings.
    13. Press the 'EXIT' button to exit the menu.
    Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
    How do you set convergence
    What is your Make and Model number?
    I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
    http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
    The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
    Please rate my help++++Thanks for using FIXYA
    Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
    Unable to align red crosshairs in horizontal range
    No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, one or more colors won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary. And the power supply fuse links to the power pacs checked and replaced as needed.
    It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills. After the above repairs are performed it may be necessary to perform the static convergence realignment procedure using the outer cross hairs as you mentioned, and realigning them.
    Apr 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
    No crosshair on manuel convergence
    It may be the fluid in the CRT or convergence chips are bad.
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    2c07611.pngSolution
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
    Feb 08, 2008 | Philips 51PP9100D 51 in. Television
    Blue Convergence
    Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
    http://electronix.com/
    Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
    Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
