Question about Metrik Amplifiers MAX-1202 Car Audio Amplifier
Subs wont play music
I have a nitro amp 2500watts hooked up to a stock radio and 2 12's 1200watts each...when I turn my car on there is a humming sound coming from my subs. at this point my radio is turned off. when I turn my radio on the humming stops but the bass remote also turns off. how can I have my bass remote and radion be on at the same time?
  • Jimmy Hall
    Jimmy Hall May 11, 2010
    j_maurice62:
    I need some additional info in order to offer some help. How are the subs connected to the amp? What impedance (ohms) are they?
    It sounds like the amp is detecting an overload & shutting down to keep it from self-destructing. Get back to me & we'll go from there.
    peace-out
  • 323 Answers
Sounds like your RCA's are the source of your problem. Unplug your RCA's before you turn your car on. You may need to isolate your RCA's and the ground wire on the back of your head unit.
Posted on Feb 11, 2009
I have a couple of questions regarding my jl 500/1. the first question: i just transferred my amp/subs (subs are JL W3s) to a new vehicle, and the place i had install it switched the "high/low"...
ok..well theres a lot of question in there, lemme take a shot at it.
the hi/low switch explained: the hi/low switch tells the amp what signal voltage is being delivered to the amp...hi-power (4-15volts) or low-power(micro-volts). Your aftermarket head unit had what are called pre-outs (or preAmp outs) meaning the source signal (your music) is not amplified before being delivered to the amplifier...sooo...your amplifier setting for your aftermarket radio would be 'low' to tell the amp that the music source being sent to it is low-voltage.
Typically a manufacturers radio will not have pre-outs, they will be amplified by the radios internal amp to anywhere from 4volts on up, and you need to tell your jl audio amp that the source music being supplied is 'hi' voltage.
soo...of course...if you are sending 10volts to the amplifier and tell it that your sending micro-volts (low setting) your amp will over-amplify the signal and thus the overwhelming bass you experienced.
May 14, 2011 | Jl Audio 500/1 Car Audio Amplifier
When i start my car my in dash says rear in ? and wont play no music but when my car is off it starts to play music ???
Do you have an amp and subs hooked up and did you just install or did it work proper before
Nov 07, 2010 | Car Audio & Video
Sub woofer
You are suppose to hook subs up to a amp.
May 04, 2010 | Car Audio & Video
I have 2 10' sony xplodes connected to a 2
If your radio is still playing and the subs are giving you music, you most likely have the amp remote wire hooked to a constant power source on the radio. Generally, this is a solid blue wire on both the radio and the wiring harness. It allows the radio to turn the amp on and off when the radio is on or, subsequently, off.
Apr 21, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I play my music on low and it has bass wen i turn the radio up it starts hiting only certain bass notes the lowest dont hit hard it starts sounding weird???? i have it hooked to a audiobahn aw1206t...
sounds like you have some wires crossed. check your radio setting and make sure that the subs are only playing bass and no trebble. buy some new rcas
Mar 10, 2010 | Nitro BMW-486 Car Audio Amplifier
Hooked up subs in my 07 tahoe radio plays but truck wont start
when you turn off the radio and subs does the car start?
do other things work in the car like headlights indicators brake lights
i sugest you turn off the radio and start car or unplug the subs from the battery and try
Dec 31, 2009 | 2007 Chevrolet Tahoe
My amp keeps going into protect
do you have the right size ground wire, relative to your power wire? If your ground is smaller when you turn it up there is alot of power it needs an exit and if the wire is too small it travels elsewhere maybe your rca, causing your amp to protect.
Dec 27, 2009 | Nitro BMW-481 Car Audio Amplifier
No sound from subs
No sound is produced. ? The output disable mode is turned on. ? Refer to the instructions at ?Output Disable Mode? to turn the output disable mode off.
May 21, 2009 | Alpine MRD-M300 Car Audio Amplifier
SUBS NOT PLAYING THROUGH AMP
There is an otion to turn sub output on/off in the "audio menu". Hit " in lower left to turn sub out put on.
Mar 17, 2009 | Xtreme Sound WMS336 CD Player
Nitro BMW 484 1200 watt amp.
check fuses and remote wire at the head unit. must have a good ground at amp.
Dec 03, 2008 | Nitro BMW-482 Car Audio Amplifier
Metrik Amplifiers MAX-1202 Car Audio Amplifier Logo
85 people viewed this question
Top Metrik Car Audio & Video Experts
xxxxxx xxx
Are you a Metrik Car Audio and Video Expert? Answer questions, earn points and help others
