At a stop sing a 1992 honda accord just quite running. im getting fuel. the car cranks over. i checked for spark i only get spark when i turn the key off
There is a sensor under the left hand side of the dash that would not allow it to start, provided that you have replaced the electronic spark module inside the distributor first, which is what it sounds like it would be, When you say you replaced the distributor I assume you replaced it complete!
Make sure your distruibutor rotor in turning while cranking engine, if it is timing belt ok, more then likely your not getting spark to spark plugs check your ignition coil, but more then likely it's going to be your ignition module.
MAKE YOU HEAR FUEL PUMP RUNNING WHEN TURN ON IGNITION KEY. IF NOT CHECK FUSE AND RELAY.IF YOU HEAR PUMP RUNNING. CHECK FUEL PRESSURE.IT SHOULD 36 TO 40 PSI.IF NOT REPLACE FUEL FILTER.IF FUEL PRESSURE IS STILL LOW FUEL PUMP IS BAD.
When you turn the key to start, the engine cranks over? You must check for spark and fuel, if one is missing, the car won't run. Pull a spark plug, with plug wire connected and plug on a metal surface of the engine, have someone turn the key to start, while you watch for spark at the plug. It is easiest to see spark with car out of direct or bright light. If you have spark, attempt to start several times, pull a spark plug and check for evidence of fuel (wet) on plug. Let me know what you find, we can then continue.
check for spark and fuel...then replace ur vehicles igniter..(in ur distibutor)have ur pgm fi main relay replaced....up under the drivers side dashboard..
did you replace the the plug wires right i would double chect them and make sure and check the disribotor. and try runing some fuel injector clener through it. after you check all that can you start it with starting fluid
Have u checked for spark? U can pull a plug wire off, install a plug in the wire (saves u from taking a plug out), place plug on metal surface, crank engine while someone watches for a spark. If no spark check coil and ignitor (inside distributor). If u have spark check to see if u have gas making it to plugs. Crank engine over (no more than 10 seconds, give it a 10 second rest, try again for 10 sec. etc, ) After doing this for several minutes, pull a plug and check it--it should be wet from gas. If the plug is dry, u aren't getting gas (change fuel filter, check fuel pump). countrycurt0
