Question about Palm TX Handheld
My TX crashes every time I try to hot sync
This is a new problem for me - I was able to hot sync before - but now the palm crashes and reboots each time when I press the hot sync button.
At the same time, when I click on one program (epocrates), the same crashing and rebooting also started.
I wonder if I should erase that program (used to work perfectly): would that fix the sync problem?
My on/off button doesn't work anymore either, so I turn the palm on with one of the 4 keys on the front (home, calendar, contacts, or web): is there another way to hard reset?
  • 4 Answers
You could delete that app if you want, however I would go into hotsync config and sync only one section at a time, such as Notes, but not contacts or calendar (or anything else). If it works then add a section, such as contacts. Keep adding sections until it malfunctions. Pimlico software makes a product dbfixit ($) that can fix database (blob errors). You can download and install it, and it will report on (but not fix) any errors it finds.
Posted on Feb 04, 2009
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
On Palm TX Hotsync Manager will not open
check whether the power supply is proper
Jun 21, 2008 | Palm TX Handheld
Have a palm tx ,When calendar is chosen,the handheld crashes.
You probably need hard reset because there is most likely a corrupted program that is messing it up. I've gone through over ten different times where I had to hard reset. Get used to it.
Feb 12, 2010 | Palm TX Handheld
Hotsync Problem with Sony Clie PEG-T615C using XP SP3
Maybe you could also try updating Palm Desktop or maybe downgrading Palm Desktop because I have that exact same PDA and I know it's old. If neither of those work, just pull a system restore or whatever you had planned.
Dec 23, 2009 | Sony CLIE PEG-T615C Handheld
By typing hot Sync my palm makes a restart
Try this, uninstall your current version of Palm Desktop, then go to this link on the Palm support website http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/home/page_en.html this will give you the link to the download for the TX version of Palm Desktop, this may or may not fix your particular problem but it is worth a try.
Mar 24, 2009 | Palm TX Handheld
I broke my old Palm TX. Now I have another one
Great!
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 14, 2009 | Palm TX Handheld
TX in a crash, reboot, crash cycle since I deleted contacts file
When reset button is pushed, the Palm screen comes on in color, then in gray, then the screen goes blank. Can I repair it?
Jan 11, 2009 | Palm TX Handheld
Crash after Hotsync
There were some problems with the hotsync working with Vista. I don't know if they fixed them yet. Best bet is to look on Palm.com and see if the current hotsync program supports Vista.
If it isn't listed, it may not support it.
Oct 12, 2008 | Palm TX Handheld
Pda will not hotsync
assuming that you use your palm tx on a windows xp system, files from the emails could be corrupted. are you using palm desktop or outlook?
if you are using palm desktop, you can rename the back-up folder to old and try to resync
Oct 08, 2008 | Palm TX Handheld
Palm T/X won't hot sync on Window XP Media Center Edition
i had that problem too. sorry it is bugging you.
i know you probably want to sync your data rught now. So for now try to disable the syncing of documents to go (just for now)
on palm desktop, look for the conduits and temporarily disable the syncing of docs to go. Also ensure you plug in your pda charger as well as the usb cable (I found out this helps through experience) and sync. (Just to back it up)
as for the documents to go, there is probably a file(document) that is generating the errors. please look through documents to go on your palm desktop and remove any file you feel is not necessary. also take note that it is best if your pda has some free memory on it. you may want to save those documents on a disk (If you are not already that is..) clearing up ram made my tx more stable esp during hot sync.
please let me know it that worked for you. i still have some suggestions
good luck and enjoy
Nov 05, 2007 | Palm TX Handheld
Palm TX Handheld Logo
119 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
