Question about Lexmark X5470 All-In-One InkJet Printer
Anyone knows where to buy a cartridge carrier?
I bought the Lexmark 3500 - 4500 series all in one printer a year ago, I stopped using it for a while and now i wanted to start using it again. I bought a new ink and wanted to chnage it, but it doesn't seem to have the cartridge carrier inside of the printer...there is nothing to put the cartridge into. Can I somehow buy this part anywhere? I did try to do some research online, but it hasn't been successful so far.... If anyone knows, it would be very helpful. Thank you!
    President:
  • 1,901 Answers
Here is a link to the user guide for your printer:
Lexmark 3500/4500 Guide
The installation of ink cartridges begins on page 70.
Thanks for using Fixya.
A Fixya rating would be appreciated.
Posted on Feb 04, 2009
Cartridge Error .... help!? I've read all the other replies and it's not helped!
Just make sure you are using a genuine Lexmark cartridge and not some remanufactured, refilled or clone cartridges. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
You may also contact Lexmark Technical Support Center for additional assistance.
Jan 14, 2012 | Lexmark X4650 InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
How do I install new color cartridge
You can refer to the Lexmark X2600 user's guide. If you're using Windows and you have already installed the Lexmark software on your computer, you can access the user guide by going to the Start menu -> All Programs/Programs -> Lexmark 2600 Series -> User's Guide. Go to page 44 for the steps on how to install the cartridges. If you can't access the user's guide, you can download it from the Lexmark website for free. Click on this link: Lexmark 2600 Series User's Guide.
Sometimes the ink cartridge carrier won't position automatically to the center even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the center of the printer. Load the color cartridge into the right carrier. Close the cover. Plug the printer back to power source.
Thanks.
Nov 07, 2010 | Lexmark X2600 InkJet Printer
How to load ink catritridge #4&5
plz follow the steps below:
Step 1 Locate the "On" button located on the top right side of the Lexmark 2600 Series Printer Scanner. Turn the unit on by pressing and releasing the "On" button one time.
  • Step 2 Raise the scanner unit until it locks into place. Allow the print cartridge carrier to move to the loading position. Wait for the print cartridge carrier to stop moving.
  • Step 3 Locate the color print cartridge in the carrier on the right. Release the empty color print cartridge by pressing down on the cartridge carrier latch. Raise the cartridge carrier lid. Remove the empty color cartridge by pulling it straight up. Place the empty cartridge in the plastic bag and set aside for recycling.
  • Step 4 Remove the new color cartridge from its packaging. Remove the protective tape from the nozzle and connector on the back and bottom of the color cartridge. Dispose of the protective tape.
  • Step 5 Install the new color cartridge into the right cartridge carrier slot. Close the cartridge carrier lid. Press down on the cartridge carrier lid until it clicks into place.
  • Step 6 Raise the scanning unit slightly. Release the scanning unit support. Close the scanning unit.
  • If u find this post helpful, then plz vote it.
    Thanks
    Apr 27, 2010 | Lexmark X2600 InkJet Printer
    Lexmark 5400 cartridge carrier slams up against back???? Won't stop!! It's a new printer, put in a high cap black and low cap color cartridge. Any ideas how to fix this?
    Cartridges may not be seated properly. Remove all the cartridges from the printer. Close the cover. Unplug the printer from the power source. Wait for about 10-15 seconds. Plug printer back to power source. If printer ink cartridge carrier still slams on the sides, encoder strip of the printer might be damaged. If it's still within warranty from where you bought it, have it replaced at that store. If ink cartridge carrier is not slamming to the sides, re-insert the cartridges. Make sure there are no obstructions along the carrier's path. Close the cover. Let the printer print the alignment page. If it's still going to slam the carrier, have it replaced.
    Apr 07, 2010 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
    Don't know how to install ink
    Installing print cartridges
    1 Open the printer, and then press down on the cartridge carrier levers.
    2 Remove the used print cartridge or cartridges.
    3 If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid.
    Warning—Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridge.
    4 If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid.
    5 Close the printer, making sure to keep your hands out from underneath the scanner unit.
    Removing a used print cartridge
    Apr 13, 2009 | Lexmark X4650 InkJet Printer
    Lexmark all in one x5100 series begins to print then stops with"hardware error message 0502
    This is copied out of Lexmark's KnowledgeBase, just so you know I'm not coming up with this off of the top of my head. Go to www.lexmark.com and click Support > Technical Support, and then search for ID: ENUS22800 if you would like to see the original, complete with pictures. Or, here's a text version:
    The 0502 error can have any of four possible causes:
    - A faulty black/photo cartridge
    - A faulty color photo cartridge
    - A dirty encoder strip
    - The encoder strip being out of position
    The steps below will help you to identify and resolve each of these four issues.
    1. Turn the printer off and disconnect the power cable from the back of the unit.
    2. Open the printer's front cover.
    Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer.
    3. Remove both of the cartridges.
    4. Move the cartridge carrier over to the left-hand side of the printer using the carrier belt.
    5. Gently clean the encoder strip with the cloth.
    6. Move the cartridge carrier back to the right-hand side of the printer using the carrier belt.
    7. Reconnect the power supply and turn the printer back on.
    8. Perform the printer hardware test. Instructions on how to do this are here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:483:0:0&docid=ENUS3744
    Did the printer pass the hardware test?
    If yes, proceed to step 9.
    If no, proceed to Reseating the encoder strip.
    9. Power the printer back off and disconnect the power cable from the back of the unit.
    10. Open the printer's front cover.
    Move the cartridge carrier over to the middle of the printer using the carrier belt.
    11. Reinstall the printer cartridges and move the cartridge carrier back to the right-hand side of the printer.
    12. Reconnect the power supply and turn the printer back on.
    13. Perform the printer hardware test.
    Reseating the encoder strip:
    1. Turn off the printer and disconnect the power cable from the back of the unit.
    3. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently pushthe encoder strip down and then back up to get it into the slot. Ifthe strip is completely out of the slot, it may be necessary to moveit first forwards and then back.
    4. Move the cartridge carrier back to the left-hand side of the printer with the carrier belt.
    5. Reconnect the power supply and turn the printer back on.
    6. Perform the printer hardware test. Click here for instructions.
    If yes, proceed to step 9 of Cleaning the encoder strip.
    If no, proceed to the Black/Photo cartridge troubleshooting steps.
    Black/Photo cartridge troubleshooting steps:
    3. Remove the black/photo cartridge.
    4. Move the cartridge carrier back to the left-hand side of the printer using the carrier belt.
    6. Perform the printer test. Details on how to do this are here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:483:0:0&docid=ENUS3744
    If yes, repeat steps 1-7 with a new black/photo cartridge.
    If no, continue to Color cartridge troubleshooting steps.
    Contact Lexmark if the problem persists with a new cartridge.
    Color cartridge troubleshooting steps:
    3. Remove the color cartridge.
    6. Perform the printer hardware test. Instructions on how to do this are here:
    If yes, repeat steps 1-7 with a new color cartridge.
    If no, contact Lexmark.
    Hope this helps!
    Jan 21, 2009 | Office Equipment & Supplies
    Refilling lexmark cartridges x2500
    There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
    Aug 10, 2008 | Lexmark X2550 All-In-One Printer
    Lexmark X5470 All-In-One InkJet Printer Logo
    102 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
