Question about HP Compaq dc7100 PC Desktop
Won't reconize DVD burner
I picked up a DC7100 tower and it came with a CD/DVD rom drive. It seems to have a ribbon cable that would able me to add a second drive. I have a DVD burner and wanted to add it to the HP but it doesn't reconize it after hardware install... I installed it first thing when I got the computer and it did not even reconize the CD rom that came with it. I had to go into F10 and config the CD drive there. There was no DVD burner drive there in the setup. Maybe I need to do one at a time, I don't know.
Also want to add a hard drive and believe I can with the full size tower. 40 gig original drive is way to small, but my second hard drive from my older computer hooks up differant, with a ribbon cable... More than likely it means new drive as I would like it internal.
Thank you in advance. Rob
  • Rob Liszi
    Rob Liszi Feb 04, 2009
    I have 1 ide slot, which is used for the CD ribbon. 80 wire, set the jumpers for slave and master, and did not even have to configer... My drive id's are backwards from what I wanted but I am gratefull that they work.
    Thanks for the quick fix for me.
  • 474 Answers
Well, the CD ribon cable goes into the IDE 2 slot on the Mainboard and the furthest connector on the other end is the master, the second one closest to the board is the Slave connector. The CD drive has a jumper on the back between where the ribbon and the power connector go, on the case some where it should have a diagram showing the jumper setting to put it in as master or slave. Set it accordingly.
Same with Hard drives.
If the Hard drive has a diferent Cable like a SATA, then be sure to get a SATA as the new one.
Now the IDE cables may be bad check them for damage just to be on the safe side.
Posted on Feb 04, 2009
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
I have a Dell Inspiron 9200 that does not reconize my cd/dvd drive. What would be the estimate cost for this repair.
Hello there:
Your drive may not necessarly be bad , what i would do is open the case and switch the ribbon from the harddrive and place it on the cd rom and then place the one that was on the cd rom and put it on the harddrive and boot the computer into the bios and see if the cd rom is now showing up.,
If so good which may mean that the ribbon cable that was originally attached to the cd rom may not be good .
But if still nothing than you can put every thing back the way it was and if the ribbon cable that was attached to the cd rom originally has a extra end to hook up to the cd rom try to use it and see what happnes if still nothing than yes replace the drive they usually run about 30 to 60 dollars ok?
best regards michael
Sep 29, 2009 | Computers & Internet
OS is Windows XP Professional CD drive will not reconize a DVD+R for recording data. The drive is a HL-D-ST CDRW/DVD GCC4244.
A CDRW/DVD is a CD-burner and DVD-ROM combined unit. It is not meant to record DVDs only CDs.
It will not recognise a blank DVD as it is unable to read any file system.
Jun 01, 2009 | Dell Computers & Internet
Dvd / cd rom not recognized on my computer list
1) Go to Control Panel. Open the System Icon.
2( Click on Hardware Tab, then click on Device Manager.
3) The device manager will list all of your hardware that is on your computer.If you see a yellow? mark oryellow ! mark next to your DVD/CD rom drive,simply click on it then click Repair. It also may tell you that it is not recognozied. Follow the directions.
4) If you do not see this in your Device Manager go to Add Hardware in your Control Panel which is next to your Add/Remove Programs icon. Click on Add Hardware and it will scan for all hardware.
** This should take care of your problem.If not then somehow the actual connection in your tower has come loose. If so you must open your tower and look for a loose wire going to your DVD/CD rom drive.
*** Please let me know if this corrects your problem.Simply email me(Phil) at:
Jan 01, 2009 | Gateway GT5468 Desktop PC
G4 350 mhz agp powermac
Can you try installing the new burner as a slave and the zip as the master?
Had a pc once that refused to boot at all with a new DVD burner in it, alongside a DVD-ROM. The burner was replacing a CDRW drive, swapped the drives master and slave settings over and it worked.
Oct 15, 2008 | Apple Power Mac G5 Desktop
Dvd/cd burner
Go to bios settings, usually you go there by pressing F2, or Del, etc , depending on your motherboard.
In the first bios page often you find installed drives, your dvd should be there.
On some motherboards, like many dell's PC MB, you need to do explicitly HDD/cd/dvd autodetections to have the DVD installed . In this case you need to locate the bios command saying autodetect disk drive. If the disk is not detected you may need to check the jumpers at the back of the dvd (eventually test it a Master on single cable). If you are using IDE ribbon cable check also that the cable is plugged in the right way.
Check this page for a general procedure.
Apr 13, 2008 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Dvd/cd internal drive cable(s) connection
this isn,t a big task.
1:- cable 40 strand IDE Ribbon Cable to DVD Rom. If there is a secondary device such as hard-drive. view it,s jumper ( plastic Block) setting will be Master Or Slave. Setup your DVD To Opposite of Hard-Drive ( If applicable )
2:- 4 pin Molex plug power cable, Red-Blk-Blk-Yellow. Only goes in 1 way, usually yellow facing outside edge of case.
3:- turn on computer, drive should be detected, install device drivers via CD if requested by the system.
Mike @ compurepair.
Feb 17, 2008 | Computers & Internet
Problem with cd-r/dvd rom
does the light come on on the drive ? have you tried straightening a paper clip an putting it in to the little hole to push the draw open this may make it work if its stuck or try right clicking the drive in explorer and choosing eject from there
good luck
Jan 23, 2008 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Drive doesn't play CD-ROM but plays DVD games...
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer
Dec 26, 2006 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
HP Compaq dc7100 PC Desktop Logo
158 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
