Question about GE DBSR453EBWW Electric Dryer
Dryer has power won't start cycle Hi - The light goes on inside the dryer, but when I close the door and select start nothing happens.
  • 1 more comment
  • Dave Feb 05, 2009
    The door switch appears to work OK, I am able to open the door and manually push the switch in a the light goes off and on. so I took the back off the power cover to look for a loose connection on any of the 3 wires. They are very tight, so I believe we are OK there. I took the back off the top main switch panel and made sure all the connections to the switches where tight, which they were. I did see a terminal block that hat two wires connected but I wasn't sure that was the one you were refering too as I did not take the large back panel off yet behind the drum. This has really got me stumped.
    A little history --- I bought this dryer off my sister-in-law who just purchased it new in Nov 2008. I wired an upstairs laundry room for my wife using 75 feet of #10 3-wire + ground wire to a double pole 30 amp breaker. I do have power at the new receptacle on both 110 poles. I did not connect the bare ground wire since the receptacle did not have a place for that. Any other thoughts?
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    door swith.you would use an ohm meter to see if failed,but it was most common for a GE dryer
  • Anonymous Mar 12, 2014
    Dryer won't start even though programme selected and door closed
  • 979 Answers
If that doesn't do it, (door switch), then check underneath the top and look for the thermal overload switch. Bypass it and see if it runs. If not, then start back at the wiring at the receptacle and then follow to the terminal block located in the back of the dryer. You could be getting power to the receptacle but it may stop there because of a loose wire. You could have lost a leg of power.
Posted on Feb 04, 2009
  • Bill Dickerson
    Bill Dickerson Feb 05, 2009
    The terminal block that would join the incoming wires and the wires to the dryer parts is what I am referring to. It is possible one of the wires is burned off. You mentioned the bare ground wire not having a place to attach to. As long as you attach it to something metal you are O.K., preferably the junction box. It should have a place for a screw or you can even slide it under the cover plate and then fasten it down with the screws. The receptacle however, should have a screw at the end of it to attach the bare wire. Bottom line is you want to have it grounded. Once this is done, remove the top to the dryer and you will find a small barrell shaped switch, located at or near the drum, which is the thermal overload switch. By pass it and try and see if it works. If it does, then you know it is the switch. If not, you may want to see if it may be under warranty. It is not very old. Do you get any humming noise when you try to turn it on? The last thing I am thinking of is the starter switch itself. It is unlikely but possible. By the way, the wiring you did is plenty for what you did. Good luck and let me know how you make out.
Won't start
Is door securely shut? Safety switch could be preventing start. Might try unplugging for about 1 min, then plug back in and try. On some models, this will allow circuit to reset. Good luck!
Apr 08, 2014 | GE GFDR485EFMC GFDR485EFMC 8.3 Cu. Ft....
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
When I push the start button nothing happens; no "resistance" from the button, no clicking sound. Power is on as light inside dryer goes on.
Hi- Sounds like you just need a start switch but possibly a door switch (the dryer won't come on if it thinks the door is open). Depending on what model you have the start switches usually aren't too expensive and easy to replace. Just be SURE that the dryer is unplugged anytime you work on it. Hope this helps...
Sep 24, 2010 | Dryers
Dryer humms but doesn't actually run.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 03, 2010 | Hotpoint NVL333EY Electric Dryer
Dryer will not start
A dryer may not start for many reasons...
heatman101
Apr 11, 2010 | LG DLG5932W Gas Dryer
Dryer acts as if there is no power getting to it, but it does have 220 volts. still nothing happens when the dials are turned(timer and start dial) Start dial seems a little spongy. what should be the...
The easiest way to check the door switch if you do not have a meter is to connect the wires coming to it together. Then try it. If it work the switch is bad. All you will be doing is bypassing it so you can test. If you do have a meter, the switch is a normally open switch. When the button is pushed in, it closes making a circuit. While you have the back off. Go to http://www.partselect.com/ModelFrames.aspx?ModelID=323612&ModelNum=DBSR463EG2WW&mfgModelNum=&ManufactureID=2&Selected=00125777i04&Position=2&mfg=GE&Type=&Mark=2 and look at #507. This is most likely the problem. If it is, if your not able to check these you will want to replce #505 and #506. When #506 goes bad the dryer cycles on #505. When #505 goes bad the it cycles on #507. When #507 goes out the dryer stops all together. #507 can also be put out by the vent being clogged. Good luck.
Dec 15, 2009 | GE DBSR453EBWW Electric Dryer
Lost power after opening door during cycle.
Try and flip the breaker to off again and push lightly then on , when a breaker trips somtimes just flipping it on it wont catch a latch inside the breaker to actually flip it on.
Oct 29, 2009 | Dryers
The dryer just stopped in the middle of a cycle
This is a bad door sensor. For some reason as soon as you opened it up then closed the door the sensor went bad and now needs to be replaced. You can find your part at repairclinic.com also when you purchase your product you will also get instructions with it
May 21, 2009 | Dryers
Kenmore 70 series dryer problem
HI. This may be an issue concerning the pressure switch that is located inside the rim of the actual door.
This switch activates the main drum motor when a cycle is selected when you are ready to dry your clothes. As soon as you select the desired cycle and you load the clothes and shut the door, the last thing to do is push the start switch. if the door pressure switch is malfunctioning, it will not allow you to start the dryer. it will simply not spin.
If you can visibly see the light inside the drum/basket while the door is closed, this will confirm the malfunctioning pressure switch that is located inside the inner part of the door rim.
Its located in this position so that the actual door can make contact with it, in return, applying pressure to close the switch and complete the circuit. this will cause the dryer to spin.
You stated that you can see the drum light shinning when the door is closed and, this will confirm my diagnosis. You can preform a hard reset just to make sure of this defect. Simply unplug this unit for 5 minutes or, shut down the circuit breaker for 5 minutes as well. Any methods will work. Once the 5 minutes are up, simply plug back in this unit and try to run a normal cycle. if this problem is still and issue, it will once again confirm a door pressure switch failure and you will need to replace the switch in this unit.
I would check the wire clips and connectors as well located on this switch for lose or worn contacts. this can be a problem spot as well.
Please rate and god bless:)
Apr 26, 2009 | Kenmore Dryers
GE DBSR453EBWW Electric Dryer Logo
110 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
