Question about Toshiba Satellite A100-S8111TD Notebook
Batterry backup not working - when i unplug the power cord the laptop switches off immediately can you give me the authorized service centre number in chennai->tamilnadu->india.
  • 4,889 Answers
I ran a search here
https://www.toshiba-india.com/service_centers.aspx?sid=1
and got these 3 results
HCL Infosystems Limited Ground & Mezzanine Floor,Shop No.5,Aarti Chambers,189,Anna Salai,Chennai - 600 002 . 044-64531602 RT Outsourcing Services Limited #403, B-Block, Shivalaya Building, 4th Floor, Commander-in-chief Rd, Eggmore, Chennai - 600 008 . 044-45582582 / 45582583 9841282822 TVS-E Servicetec Limited 34, Developed Plots, South Phase, Industrial Estate, Guindy, Chennai - 600 032. 044 – 044-42005200 / 4227 batterry backup not working - spacer.gif
Regards,
Sai.
Posted on Feb 04, 2009
What is wrong when AC Adapter is beeping continuously, and does not recharge laptop battery?
The adapter's Syscon detects a short circuit. It might be within the adapter itself; or with your system. Contact the authorized service centre in this case. If you have an other adapter, load it with. By this way, you can get an idea about the faulty unit. Electro help
Nov 29, 2014 | Computers & Internet
When I plug the power cord it won't boot. I need to charge the batterry first so I could use it. What is the possible trouble.
It sounds like you need a new power cord. The power cord may be giving just enough juice to charge the battery, but not enough to charge WHILE running. You can pick up a universal power supply from Radio Shack to diagnose if this is the issue. If it is, you can either keep the universal supply or return it and pick up a power supply from e-bay or toshiba.com. Just put in your model number with the toshiba link and look for "accessories", then find the power supplies.
Aug 23, 2011 | Toshiba Satellite Pro L300 Notebook
I have an Onkyo Tsxr 577 amp. The wires on the speakers crossed and the amp stopped working. It might be in autoprotect mode and I don't know how to reset it.
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
To obtain service, take or ship your Onkyo product to an Onkyo Authorized Service Center. Please also include in any mailing a contact name, address and telephone number. Please include a copy of the original sales receipt/invoice as well as a letter stating what the problem is, with your name address and phone number so the service center knows who to return the unit to. Please note, before shipping, you must contact the authorized service center to inform them that you will be sending your unit in for repair.
Feb 22, 2011 | Onkyo TXSR577 71 Channels
Laptop has frozen and won't even switch off
replace the batterry and try to switch on
Dec 09, 2010 | Samsung N310-13GB Netbook
Battery does not charge and does not provide backup power
change the batterry immediately...it will surely damage ur laptop
Apr 18, 2009 | Computers & Internet
Laptop problem
you can try this: unplug from power, remove battery, press power button for about 30 to 60 seconds, connect back to power leave battery out, turn power back on. see if that works.
Let me ask you this, when you turn the power on: do you see or hear the hard drive spinning?
let me know if it works,
good luck
Mar 28, 2009 | HP Compaq Presario C500t Notebook
Lg tv no menu display
give the exact model number of the tv.
Dec 03, 2008 | Televison & Video
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
My hp zd8000 switched off when using it and wont go back on! Any ideas?
Unplug the laptop (if plugged in). Take out the battery, and hold down the power button for 10-15 seconds, plug in the power cord and see if you can power the unit on at that point in time (without the battery in). If it powers on then insert the battery. If this does not work then contact HP to find your closest authorized HP service provider (assuming you have a warranty on the product still).
Apr 20, 2008 | HP Pavilion zd8000 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
229 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
