Question about JVC AV-32230 32" TV
Help I don't know how to explain the problem, but I have black static on my tv. When the tv has been off for several hours it is ok for about 30 minutes then gradually the static builds. I have attached an image. Any help would be greatly appreciated. Same problem . If I shut tv down for a few minutes then turn tv on it is ok for a few minutes. Then the black interferance returns . Other tvs on the same cable box are fine.
    Brigadier General:
  • 8,619 Answers
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Rylee
Posted on Feb 04, 2009
  • 679 Answers
Might be there is some problem with the picture tube.
or in display Ic.
  • rockfixya
    rockfixya Feb 04, 2009
    please let me know for further assistance.
    Thanks for using FixYa.
The maytag neptune MAH8700AWW Front Lodaer door will not unlock. Help. I need to know how to get the door unlocked. I have unplugged it for 30 minutes. I don't know what else to do
Hello there and thank you for choosing fixya
there may be several ways to do this first if you press the cancel or off button and wait for several minutes without touching it it may unlock. if not check to see if there is a kick panel at the bottom of the machine if so remove it then pull the machine out about 10 inches and tilt the machine back now reach up under the machine and feel for the door lock there will be a small cable with a tear drop piece hanging there pull down ******* this and this will open the door for you.
Also these machines have a internal memory on them and sometimes it takes up to 1 hour to reset so you may need to unplug it again and leave set for a minimum of the 1 hour ok
Please keep me posted on how this is going i have more information i can give you but i need to see how all of these things go first ok?
Best regards Mike
Aug 04, 2011 | Maytag MAH9700A Neptune Energy Star Front...
As I am watching TV, after an hour or so, I start getting horizontal static running across the screen....within minutes if gets worse, i turn off the tv, wait awhile and turn it back on and it's...
It seems that it may be over heating. If you are knowledgeable about these things you can take it apart and dust out the insides. That may help. Otherwise one of the system boards are failing. Then you would need to take it to a TV tech to have it tested to figure out exactly which board is failing and have it replaced.
Mar 29, 2011 | Samsung PS42P2S 42 in. Plasma Television
Need charging instructions for black & decker model sl1028 type 1
Hello. Use an ordinary extension cord and plug it into the back of the light and into the wall. Charge it for 20-30 hours, but not more than 30 hours. Here is the downloadable manual for future reference
http://demandware.edgesuite.net/aaea_prd/on/demandware.static/Sites-black-and-decker-Site/Sites-cpo-master-catalog/default/v1269899899597/dw_manuals/black-and-decker/bdknvec157bd/bdknvec157bd_manual.pdf
Mar 29, 2010 | Black & Decker Black And Decker 2 Million...
JVC Model no: AV-48WP34 Projection Problems
OK, problem seems in convergence section of TV and can be confirmed by testing voltage supply as mentioned in schematics.
You can download service manual copy from Manual Zone for small fee and it has schematics, exploded views. board location, part numbers info.
Let me know if you need further help.
Thanks.
May 07, 2009 | JVC Televison & Video
Model VS 50501A TV. Works fine for awhile then screen goes black
most likly its your lamp you just need to get a new one off the internet or you can bring it to a repair shop and they will be able to replace it for alittle bit more then the lamp itself will cost
Mar 14, 2009 | Mitsubishi VS-50501 50" Rear Projection...
PRO 510HD PROBLEMS
if you know anything about the tv, take off the back and remove the power supply board. Reflow or resolder the solder points, takes like 2 hours, but is well worth it as my tv works fine now. make sure to use rosin core solder and good luck
Sep 11, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Help
picture line in the middle
Jun 29, 2008 | JVC AV-32230 32" TV
Static on my SLVR L6 phone
just wondering do you remember the user that you bought it from?
Aug 10, 2007 | Motorola Mobility Earwrap Handsfree For...
Static on screen and then turns itself off then on
My first aproach will be to see if the tv reacts to tap on the sides if you see a reaccion when you do it most likely you have a loose conection and need to call someone to find it and resoldered it.Dont do it yourself if you dont know how.
Sep 11, 2006 | Proscan PS27125 27" TV
JVC AV-32230 32" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
