Question about Toshiba 26AV500U 26 in. LCD HDTV
Problem with TOSHIBA LCD 26AV500A
I just purchased toshiba lcd 26av500a less than a week,but something wrong happened twice so far.the sceen became black and no button except power one could work when i changed channel.what i could do was to turn off the tv and turn on again.i don't why it is.who can give me some advice,thanks.
  • Anonymous Mar 22, 2009
    I have same issue, happened few times in past 8 months.
    President:
  • 1,077 Answers
Only advice I have is use the Warranty. Take it back to the store.
Sorry I can't help more.
Good luck
Posted on Feb 04, 2009
I have a 42hp66 and there are tiny red dots all over the sceen
Main suspects are powersupply (does happen) and the Main board for the set---it does cause this issue a lot.
Dec 12, 2012 | Toshiba 42HP66 42 in. LCD Television
Toshiba 26AV500A start up problem
Ok there might be lots of programm runnning when you start the laptop.
to disable those tyou can do the follwing steps
1.START--RUN--- type "msconfig" without the quotes.
2. now try to find out "Startup" tab and uncheck all the unnecessary programm you can see and apply.
3. come oyt of it and restart your laptop.
Hope this will make you easy. cheers:)
Jul 26, 2012 | Toshiba Computers & Internet
I have a toshiba Satellite L305D-S5900, sometimes while i'm using my laptop my screen became white with color stripes, then my laptop restart automatically. this happens when i plug in my cousin's external...
I had experienced similar problems with toshiba satellite pro M200. the problem is on the hardware on the IC chipset. You may consider to immediately send to toshiba for repair.
Usually this happens when a laptop running a pretty heavy process on I/O
Toshiba Contact Information: 800-457-7777
Mar 02, 2010 | Toshiba Satellite A200-19501F Notebook
Lcd tv toshiba will not come on,sometimes takes few weeks then suddenly come on
find something to do until it does come on or maybe have a tv shop look at it.
Jan 01, 2010 | Toshiba 37HL67 37 in. LCD HDTV
Blurry(ish) picture
nead new picture cartrage
Nov 19, 2009 | Toshiba REGZA 47HL167 TV
My laptop's screen is messing up
this happens when the backlight cable is lose
laptop sceen is an LCD which uses a ccfl backlight to light the screen
this backlight wire sometimes gets lose as it passes through the laptop hinges
get a proper technician to tighten the wire to to put a new one
Sep 29, 2009 | Toshiba Satellite M30 Notebook
Compatible laptop sceens
You won't know until you dismantle and remove both LCD screens.
They could have different video connector and power connector for the inverters.
The best bet is to buy a new LCD screen or if the LCD screen is OK but the backlight CCFL lamp is worn out or the inverter is faulty, then the CCFL lamp or inverter can be replaced fairly cheaply.
Check out LCD Parts for compoments, repair and DIY info. Use this link.
www.lcdparts.net
Jun 23, 2009 | Toshiba Satellite A135-S4527 Notebook
Lcd toshioba tv 42'' damaged screen could it be repaired
If you mean cracked or smashed when you say "damaged", the answer is yes, but it would be far less expensive to buy a new set!
We are an authorized service center for Toshiba. The replacement LCD panels are typically more expensive than the entire set was new! Go figure...
www.mcveyelectronics.com
May 03, 2009 | Toshiba 42HL167 42 in. LCD Television
How do I hook up the DVD player to the TV?
Hi, basically you need to put them into their respective slots in the back of the tv. I know this can be frustrating because the slots are all faced downwards, tucked behind this piece. Look at this image, which should be what you are seeing if you're using a Toshiba 26'' 26AV502U, a model similar to yours.
http://www.bestbuy.com/site/olspage.jsp?id=cat13506&type=page&h=387&skuId=9034733&productId=1218010846690&&viewtype=backView&count=0
Look at the four plugs with labeled "Video 1 In." "L Audio" is your white plug, "R" is your red plug(R actually stands for Right [Audio Input]), and Video is your yellow plug. It would be wise to remember this for every Audio/Video cable accepting unit. It makes sense you are putting the cables IN to the tv, hence "Video 1 In."
Now, to tell the tv to read the video input, find and hit the "Input" button on the remote, and it should be one of those options..(there are only a couple to choose from).
Hope these directions worked for you, and enlightened you!
Dec 29, 2008 | Toshiba 26AV500U 26 in. LCD HDTV
Toshiba 26AV500U 26 in. LCD HDTV Logo
422 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
