Question about Kyocera Strobe K612B Cellular Phone
DFW 02 When I try to make calls to certain numbers I get 'DFW02 your call can not be completed at this time, please try again late"
  • Anonymous Mar 09, 2009
    I have had the same thing happen. I do know that message will show up if someone blocks you.
I am getting several calls a day from the number 02 43455698. Yesterday I had 7 calls in an hour. I have caller ID so don't answer but if I dial 101 there is never a message just a missed call.
this number is on the service providers list of crank calls and is generated by a computer
It has been reported many times but it appears that nothing can be done
if you have a mobile you can block that number so you do not receive the call
if you have a landline phone call your service provider and ask that the number be blocked to your phone
Feb 28, 2017 | Cell Phones
Facebook troubleshooting
From Facebook's help center:
If you're seeing an error message saying your password reset link is invalid:
  • Try copying and pasting the full link you received into your address bar. Some email providers will separate the link onto several lines, so be sure to copy the entire link.
  • Try resetting your password again.
I can't reset my password because I've reached a password reset limit.
In order to keep your account safe, we only let you request a new password a certain number of times each day. Please wait 24 hours and then try to reset your password again. Also, check your email's spam or junk folder.
Visit this section of their help section for more details or info:
https://www.facebook.com/help/www/374104332645037?rdrhc
Oct 31, 2013 | Computers & Internet
Dear sir/Madam, I want the incoming and outgoing call details to my Airtel prepaid number is 09878201121. I need 01-02-2011 to 15-02-2011 incoming & outgoing call list. please send me that on my...
Dear sir/Madam,
I need 01-02-2011 to 15-02-2011 incoming & outgoing call list. please send me that on my above e-mail address is kumardeepak7077@yahoo.com
thank you
Feb 22, 2011 | Cell Phones
Check engine lite on,o2sensor down stream replaced,315.00 to fix.one day later check engine back on again? 2005honda accord
This can be another 02 sensor malfunction or it could be you are having misfires and your not feeling them, also the catalitic converter may be going out it can be tested with a infraded heat gun to see if it's changing tempiture from one end to the other if it is it's working if not it is failing also the upstream 02 sensor may be decteting a firing proble now that the new one was replace, they get whats called lazy 02 sensor after a certain amount of time. If you want more help let me now.
Oct 09, 2009 | 2005 Honda Accord
My terminal is reading spvc 3200 dfw file error what does that mean?
Eat that machine because it is fried. The internal memory is completely corrupt sometimes you can recover though depending on how bad it is.
Try this at the error screen hit enter and 7 at the same time it should prompt for the password.
1 ALPHA ALPHA 66831 if it works it will say SYSTEM=VP........ hit 0 then enter and then enter again it should dial out to your merchant account provider and redownload the file. give me a call if that doesn't work.
www.greenlightpayments.com
Jun 23, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
When faxing, what is Error 387? Can fax other places, why not this place?
Specifically, error code 387 on that machine is : Try to send the fax at a different time when telephone line conditions have improved. There is nothing wrong with your machine that I can tell from your description. It sounds like it is trying to handshake, fax term for connect, but does not complete. I had the same thing happen to me yesterday with some very important papers. I even called the person at the other end and they said they had been receiving faxes ok. Took me 4 tries but finally went through. It's just the phone lines. Keep trying. It can take several tries. If this helped please rate a big 4 fix ya. If you can't get through no matter how many times you try just post a comment and I'll be happy to come back and help you out.
Mar 25, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
HOBART D 300,SERIAL NR. 94.819 808, ML NR.116 12
hi i work for hobart and these part numbers dont sound right.you have to make sure you have the ml number or spec number to get the correct parts.you can call your local hobart branch and they will help you further.
Oct 21, 2007 | Hobart D300-6036 Mixer
Kyocera Strobe K612B Cellular Phone Logo
670 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
