Question about Samsung DVD-V3650 DVD Player/VCR
Split screen on DVD player
I'm having problems with my V-3650. The VCR side works just fine, but when I turn on the DVD side, a split screen appears on my TV, which I cannot get rid of. Any help would be appreciated!
  • dendawg01 Feb 28, 2009
    Mine was working just fine, I now have the spit screen and distorsion....can't seem to get it back, VCR plays fine.
  • 98 Answers
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Posted on Feb 06, 2009
Thank You mcruz!!! bob
Posted on Sep 10, 2009
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
Feb 26, 2015 | Samsung DVD-V3500 DVD Player/VCR
Pscan message and split screen
well on your memorix dvd player you will get a orange triangle that says pscan (progressive scan) you will go to the back of you dvd/vcr and on the right hand side you will see a switch to turn on and off the pscan you will switch it off and you will be set to go
Aug 23, 2009 | Memorex MVD2022 DVD Player
Image split with black bar in middle
check leads if they are connect in the normal video slot on dvd player and chek the player settings what out pot it is on
Aug 21, 2009 | JVC HR-XVC18B DVD Player/VCR
Dvd player split screen
I had the same problem. It turned out to be my cable that went from the dvd player to the TV. I replaced with new cable & everything worked fine again. Hope this helps & please remember to rate my answer. Thanks.
Feb 06, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Split Screen Output
check on the remote if got some function of format ntsc or pal or check on the menu of the dvd
Oct 31, 2008 | JVC HR-XVC33U DVD Player/VCR
Two problems at the same time: VCR plays split screen and DVD player won't ready Disks (Errrrr)
Getting a new one is about all you can do in this case. A repair for this type of problem would likely cost more than the replacement.
Sep 06, 2008 | Panasonic DMR-ES40VS DVD Recorder/VCR
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony DVP NS71 Component Video split frame
You've inadvertently turned on the progressive scan. Look up in the manual, or ask customer service online, how to turn off progressive scan.
Jan 27, 2008 | Sony DVP-NS71HP DVD Player
DVD gives split image
Progressive scan is turned ON...find it in your menu and turn OFF....GJ
Mar 05, 2007 | GoVideo DV2150 DVD Player/VCR
I called Panasonic, and they told me to try a reset. I'm sorry, but I forgot which button to push and hold to reset it, but it has worked GREAT ever since! A local shop said it was a loss when I described the problem to them. Call the Panasonic Service Center, and they can tell you how to do a reset.
Feb 20, 2007 | Panasonic DMR-ES40VS DVD Recorder/VCR
Samsung DVD-V3650 DVD Player/VCR Logo
366 people viewed this question
Henry  Thomas
Henry Thomas
