Question about Crosley Audio Players & Recorders
Califone 2155 plays fine but heats up like crazy
I bought this 2155 K player on ebay, found a new stylus and cartridge for it and now it plays great...except I could literally fry bacon on the top of it after ten minutes of use. It heats up even without the platter spinning. There's no electrical burning smell but I haven't played it more than 30 minutes
The heat generates from the top right (if you're looking above it), away from the controls and platter, and radiates from there. Anyone else with this problem?
  • Walter Harrington Apr 09, 2013
    I recently purchased a Califone 2155 on eBay - exhibits the same behavior (super hot near tone arm base). I've had it apart - there is a giant heat sink on that side in which I believe the "cin-tran" transformers are mounted. I need to do more diagnostics, but the size of the heat sink would indicate that this is endemic of this model. By the way, what cartridge/needle did you find for it? I've ended up modifying Astatic 1150 cartridges to fit around the tone arm light.
2 Suggested Answers
  • 7 Answers
SOURCE: platter spins very slowly
Well hope fully its something small. check your pitch control first make sure its not set at a slow speed. then check your start stop knobs at the bottom of the table. roll them one way then start it see if that works, then the other way... if its not that then its possibly its a malfunction ,, Numark with there new awesome products but sometimes faulty that turntable wigs out goin slow then normal then slow ect... If its less then a year send it in it is coverd by warrantee
Posted on Oct 19, 2007
I have a Magnavox stereo console: Astrosonic Series. The record player was playing fine until a month ago. The volume is now so low you can hardly hear the record playing
Since the volume of the radio seems to be fine it is doubtful that the amplifier is malfunctioning. I will check the stylus to see that it's fully seated and examine the wires in the tonearm that connect to the cartridge. If they seem okay then I suspect the cartridge may be bad
Mar 02, 2015 | Audio Players & Recorders
Is there a replacement stylus/cartridge for the Califone 1477K? Everything else on mine is mint. I'd love to fix it.
Every cartridge has a maker and model number. You find them and enter it in google and it should come up with both.
However you don't have to have the same make of cartridge. You just need to find one that fits. You do need to bear in mind however that some of the cartridges that use 78 rpm stylus sometimes are Ceramic cartridges. This means that they don't need a pre-amp for it to be the same level as say a tape deck. Many cartridges these days are Magnetic. This means that if your amp doesn't have a pre-amp for these built in, then getting one of these cartridges will mean a purchase of a magnetic cartridge pre-amp. Some of these magnetic types of cartridge have no ability to fit a 78 stylus. In others you can get a 78 stylus available separately.
For example the Stanton 500 has this ability. One I use too!
The reason you might want to get a magnetic cartridge is that they give better sound quality over the ceramic type - well on 33 and 45 anyway!
Sep 23, 2014 | Audio Players & Recorders
The problem can be fixed by replacing the CD drives.
Dec 31, 2013 | Califone International (2385AV-02 ) Single...
About 11 months ago I bought an Elliptical upgrade stylus for the PL-990 and it worked great. Recently, it started giving me problems. The left channel would be very distorted and also would fade in and...
Very odd! Sounds like it's not fitting in right. Are you sure that you have the right type of stylus for the cartridge? If in doubt replace the entire cartridge & Stylus. If it still plays up then it's in your amp after that course of action.
Aug 18, 2011 | Pioneer PL-990 Turntable
My 2455AV-02 Califone will not operate if I power it up; I have to wait 30 minutes to an hour before radio, Cd player will play and function. They will function with no problem after the wait time. What is...
sounds like power supply capasiters or transformer. but most likely a cold solder joint in the same area. heat the player with your hairdryer for a few minutes and then see if it comes on faster. if not freezer is in order. freeze it and try it again. If either of the temp tests work it is a cold solder joint.
Mar 09, 2011 | Califone International 2395AV02 Boombox
Hi. Reusing my old Epson Color (photo) Stylus 870 after a period of non-use; took it to work to use with my work laptop. Plug and play found and installed the drivers instantly. Bought new cartridges...
normally you will need to let the printer know that you have preformed any maintenance on it by clearing the error count after such an error occurs and is fixed it is normally listed under general or service options on the printer menu but you may need to look through the users manual
hope this helps
Oct 27, 2010 | Epson Stylus Photo 870 InkJet Printer
How to remove the stylus N72 from the cartridge?
Pull straight out on the plastic stylus while holding the cartridge in your other hand
Jul 17, 2009 | Califone International 1030AV Turntable
Adjust pitch on a Califone turntable.
This one is actually fastened from underneath (inside). You need to open the player up and you will see the usual C shaped fastener on a cleat near the motor assembly. Most old direct drive record players have a C pin around the spindle that you can unfasten (pry with a twist) with a screwdriver. Irealize you figured this out yourself, but I'll take the guess work out for someone else... yeah..l you gotta take it apart!
Feb 15, 2009 | Califone International 1030AV Turntable
Record PIN needs to be changed, where can i get spare in Bangalor
It is called a stylus and is part of a cartridge. There is a small release lever or it comes out as a plugin device. I cannot see where you are but eBay will have your stylus/cartridge for your turntable if a stereo shop is not nearby. Also any TV repair shop can order it for you. Steve Medley
Feb 07, 2009 | Philips Audio Players & Recorders
143 people viewed this question
Top Crosley Audio Players & Recorders Experts
da surgen
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
