centralux vacuum two years old doesn't have the volume air movement it once had. Unit will still quickly reach an extremely high head of suction so no broken pipes. ran napkins thru no blockage, overode filter safety switch ran with out filter no difference. just don't move air like it used to
Comments:
Feb 14, 2009
- thank you with your suggestion i inspected further and found beyond the filter the 1 1/2" dia. hole screened with 1/8" o.c. grids that was coated with lint, cleaned off now it moves air like congress spends money and now we have the giant sucking sound you here coming from the district of criminals. next tim i'll open my eyes when overiding the filter switch
Extreme vaccum turns on, sounds same as when it worked but has no suction. I cleaned out all clogs,...
(More)
Extreme vaccum turns on, sounds same as when it worked but has no suction. I cleaned out all clogs, cleanned out the canister, and it still will not work. When I take the back hose off there is no suction.
I just bought a Z1750 twin tech vacuum. I am wondering if I can buy a power brush attachment for...
(More)
I just bought a Z1750 twin tech vacuum. I am wondering if I can buy a power brush attachment for this. It only comes with the floor and "carpet" brush but does not have the beater bar (power brush).
Hi I need help with a problem I am having with my Frigidaire Gallery Stainless Steel Dishwasher...
(More)
Hi I need help with a problem I am having with my Frigidaire Gallery Stainless Steel Dishwasher Model # GPDB998JCO. I barely use it and when I recently went to use it I press the wash buttons to set my wash and the lights and numbers light up but Nothing happens and it does Not wash or water does Not come out or Nothing happens what so ever. I tried resetting the circuit breaker but it did Not help. So, does anyone know what this problem is???
I want to remove the hose from the handle of the vacuum? I already removed the plastic clip. I...
(More)
I want to remove the hose from the handle of the vacuum? I already removed the plastic clip. I thought that would free the hose, but it did not. Any ideas?
