Question about Whirlpool Accubake RF362LXTB (Dual Fuel) Electric Kitchen Range
Whirlpool Electric Range RF362LXTB caught fire
While using the cooktop, flames began to shoot from the back of the stove. After we put out- noticed the entire box at the rear base of the stove was melted solid. Range is 15 months old. (Warranty is 12 months)
Called the electrician who tested the outlet and it is fine.
Is this worth being repaired? Any recourse with manufacturer?
I am dealing with the same exact issue as you. 16 month old RF362LXTB. Back buss bar red wire is melted along with the plastic. Looks like it broke away from the plastic and shorted out on the cover. Tripped the breaker as well. My understanding is that you should replace the breaker as well since this was a short.
Posted on Nov 10, 2009
    Genius:
  • 2,920 Answers
I would repair it...
Posted on Feb 04, 2009
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
Fame to low on my whirlpool stove
You mean the flame is low. You need to clean the burner jet hole orifice and also check if their is a gas pressure regulator which you can adjust the pressure a lithe more higher.
May 10, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
Stove sparks but doesn't light
If gas flows and burner sparks,the holes in burner near where the electrode(spark plug) is are clogged. A safety pin or paper clip pushed through those burner holes will clear the blockage
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating&and perhaps a testimonial :)
Gene
Jul 30, 2011 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
Fuses
These heating elements use limiters to control the temp range and here is a link that shows where they are http://www.pcappliancerepair.com/model-display.php Hope this helps...
Sep 11, 2008 | Whirlpool GJC3034 Electric Cooktop
Brown Cook Top (24 Inch - TTL03-3 Model)
All gas appliance should be diagnosed by a professional.
Aug 12, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Whirlpool Accubake RF362LXTB (Dual Fuel) Electric Kitchen Range Logo
318 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
