Question about Goodman GMS90703BXA Heater
Furnace blower motor dose not shut off.
I have a Patriot 80 plus furnace that has just had the Emerson blower motor PN 47465-001 replaced with a like item MARS #03463 blower motor.. the blower works great but  just does not shut off.... the white,black and blue wires are connected to the same colors to the becket burner and the two brown wires are connected the the same positions on the capacitor  all just as the original blower motor.
    Sergeant:
    Champion:
  • 373 Answers
Do you think it might be the relay switch
Posted on Feb 04, 2009
Bryant gas furnace does the blower motor have to work for the heat exchanger to light up both are not working
It depends....on if you are talking about a small blower in the front of the furnace or the indoor fan motor. If your furnace is an 80% effficiency rating or above it will have a 'combustion air' fan....that will be a small on in front of the furnace in the vestibule under the front cover. If you have that motor and that is the one you are asking about...then YES it has to be running prior to the furnace igniting the gas.
If you are talking about the indoor fan motor for circulating air into your ducts, then NO it does not have to be running in order for the furnace to ignite. But it WILL have to run to remove the heat from the heat exchanger after it ignites or it willl overheat and shut off on high limit.
Jan 02, 2015 | Heating & Cooling
Furnace rattles on our 2011 cf315re cross roads cruiser
Most likely:
The blower fan, commonly called a 'squirrel cage" probably came loose and is hitting the housing. Furnace must be removed to re-align and tighten the allen screw. The motors themselves are very reliable and last years.
If you didn't cover the inlet/outlet exhaust with a screen when in storage you may have wasp nests. I forgot once and removed 4 paper nests and 2 mud dauber ones. Had to disassemble the whole furnace!
Feb 16, 2014 | Crossroads 2011 Cruiser CF315RE Patriot...
I have an Armstrong SX Ultra 90 propane gas furnace that the fan motor will not shut off ,the thermostat is on auto.
Hit the side of the furnace. Some times there's a sensor inside that gets locked up from a dirty filter.
Oct 19, 2013 | Emerson Lennox Ducane Armstrong Furnace...
Heater heats but shuts off
Try the fan in the ON position on the thermostat, do you mean the fire shuts off or the blower?
a395e602-38d7-412e-a553-23ee69e9350b.png89346502-1e77-4384-8244-ea6d6788bd04.png09d1472e-35ed-4d26-be81-011af0d56f26.png
Jan 15, 2013 | Emerson Lennox Ducane Armstrong Furnace...
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
I have a ruud deluxe 80 plus furnace, the blower keeps running and it wont shut off. i have turned the thermostat off and its still running, what could be wrong?
That could be a couple of things....
Open up the bottom cover and take the wire off of the "G" terminal that goes to the t-stat...then replace the cover and see if the blower still runs...
If it runs then the problem is intenal to the furnace, probably the integrated control board or a high limit is tripped...
If that stops the blower from running then you have a bad relay in the t-stat ora shorted wire going to the t-stat.
heatman101
Apr 18, 2010 | Heating & Cooling
I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
NO BECAUSE THE BOARD IS TELLING THE FANS TO STARTARE THE CONTACTS FUSED TOGETHER OR STUCK IN THE CLOSED POSISTION CHECK THIS FIRST
Aug 10, 2009 | Heating & Cooling
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
Is a patriot heater comparable to a goodman heater
The Patriot 80 is an oil furnace made by heat controller, To my knowledge Goodman (aka AMANA) does not make an oil furnace.
Feb 23, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
309 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
