Question about Sony VAIO K45 Notebook
Gateway laptop i have a 2 year old gateway laptop. it use to only work when i had the ac wall charger plugged in and now it doesnt even turn on. i brought my laptop to my local gateway tech and he said it needs a new mother board. the tech also estimated it to run me about $500 to fix it. is there any other cheaper way to fix it. like do it yourself type deal?
    Master:
  • 474 Answers
If you can get the board fthrough someone online at a good price ( $150) or so, you can do it yourself.
It seems hard at first but its really not. Just set down a piece of paper and draw a few 2 inch circle on it, then when you take the screws out, put each in ther own spot and label them so its easy to put them back. I.E. label one, BASE SCREWS for the bottom, Mobo screws for Mother board and so fourth, also put how many on the paper in case they get knocked off.
Then start removing the bottom covers to the wireless card, Hard drive, memory, etc. and set aside as these will be the last you put back.
once you rmeove the keyboard, you will see inside and will be able to start removing the screen screws and so on.
You may be able to find a repair manual that will shows you step by step on the manufacturers website.
remmeebr though, New laptops are getting cheap, if they want $500 for parts and labor, just buy a new one and sell your old one on ebay for parts.
Im affraid the problem with yours does sound like its the mother board. happens to Dells and HPs alot where I work.
Posted on Feb 04, 2009
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Gateway wont power up the batt has been failing ,if pluged in the charging light comes on for a while then goes out if you try to start it tries then shuts down. could a bad batt cause this
If your battery is more than 2 years old, then it is a distinct possibility. Every battery type has a certain number of charge cycles (drain->recharge->drain) or time period. Lithium batteries run about 2 to 3 (tops) years. NiMH run about 10,000 charge cycles (or it could be 50,000 cycles if you know what to do). But if you're NOT using the original Gateway charger, then plug it into your laptop and see if it works. The 3rd party charger may have burned out the internal power components over time. In the worst case, you'll have to replace either the motherboard (hope you still have the product key!) or the motherboard's power connector, inside the laptop. At best, you might have to continue using the original power adapter. It will probably turn out to be a worn down battery, which needs replacing.
Feb 19, 2011 | Amstron Gateway P170X Laptop AC Power...
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
I have a Toshiba Satellite laptop and it's about 10 years old. That's why I need to plug in to my ac adapter in order to turn it on. But now, even when I have the ac adapter plugged with my laptop, the...
sounds like charger is gone , can you hear a humming noise from your charger when you press it againts your ear, if so it seems ok if not its gone, you can search ebay for a charger and they are very cheap.
hope this helps
Dec 04, 2009 | Toshiba Satellite A105 Notebook
Battery charger not working. Power adapter checks out ok. Laptop operates on battery only. 7325gz.
if it is not charging the battery will go dead.soo recharge it if it doesnt work then it could possibly be your charger.but alot of times the soldier on the input plug becomes loosened and doesnt get a connection. how did u check the chager
Oct 10, 2009 | Gateway 7325GZ Notebook
Hp compaq nc6320 doesnt charge
i thibk the charger head went out thats what happend to my gateway just cut the part of the charger that goes into the computer (if its not the prob u can fix it back later) cut it open and see if any of the wire has broke off if so use a soutering iron (i dont know how to sourtering)
and some souter and souter it back on thats the best i can help
ps i done this to my gateway labtop and it worked fine
Oct 02, 2009 | HP Compaq nc6320 Notebook
Old battery not charging plug in charger green light goes out
If the system will not power on, and the LED on the AC adapter goes out when plugged into the system, then the most likely senario is the motherboard has failed. Remove the battery, Wireless card, Drives, RAM and connect the AC adapter see if anything changes. If no change, the MB is most likely bad.
May 01, 2009 | Dell Latitude D505 Notebook
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Gateway 7330gz Laptop Won't Charge
Could be your connection inside the laptop itself.
They tend to go easily in gateways.
The wear and tear from plugging it in and out.
Cost approximately $70.00 - $100.00 to repair.
Can usually get the best price at a small computer repair store
Jan 12, 2009 | Gateway 7330GZ Notebook
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Sony VAIO K45 Notebook Logo
47 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
