Question about Sharp AQUOS Blu-ray Disc Player
Remote Code for Sharp Blue Ray
Is there a remote code for the Sharp Blu-Ray BD-HP21U?
  • Anonymous Feb 15, 2009
    i have the same problem. my remote for the blu-ray doesnt work at all and i cant get it working.
  • Anonymous Feb 17, 2009
    Sharp Aquos BDHP20U 1080p Blu-Ray Disc Player 4 digit code
5 Suggested Answers
SOURCE: Blu-Ray player not reading Blu-Ray movie
Go to sharps website and download updated firmware version for your model, then transfer the file to the blu ray using a usb mass storage device. I had to do that to mine it would not play new blu rays and i just bought the darn thing should've come updated. Good luck!
Posted on Dec 28, 2008
  • 45 Answers
SOURCE: Need code for included blu-ray universal to work with an Olevia TV
if Samsung never included the brand Olevia on there remote, then its not going to work because it was never design to work with that brand. The only way to get around that is to get a learning remote or universal remote that has olevia pre program into the remote.. Olevia did come out with some learning remotes that is able to learn from other remotes.. the model its called Olevia RC-LRN ..
This company called Amergence Technology sells the RC-LRN remote made by Olevia contact them at this toll free number 866-965-3842
Posted on Jul 28, 2009
jan mczeal
  • 632 Answers
SOURCE: want to update my sharp blue ray disk player bd-hp21u
To obtain the software update file, please call 1-800-BE-SHARP (23-74277). Save the update file into a USB drive.
  1. Insert the USB memory device
    with the update file into the BD
    STORAGE/SERVICE terminal on
    rear of this player.
  2. Press SETUP to display the SETUP
    MENU screen.
  3. Press arrow keys to select
    “SETTINGS”, then press ENTER.
  4. Press UP/DOWN keys to select “SOFTWARE
    UPDATE”, then ENTER.
  5. Enter the 4-digit number using 0-9.
  6. Press ENTER to start checking data
    in the USB memory device.
  7. During the data checking,
    “Checking” blinks.
  8. The current version of this unit software
    and the version of the update file on the
    USB memory device are displayed. To
    update this player software with update
    file, select “YES”, and press ENTER.
  9. If the USB memory device is not
    properly installed or the correct update
    file cannot be found on the USB
    memory device, an error message is
    displayed.Check the file on the USB memory
    device, and then reinsert the USB
    memory device correctly.
  10. Press ENTER to start updating.The screen becomes dark for a
    while until the update screen can be
    displayed. Please wait for the update
    screen to appear. Do not unplug the AC
    cord
  11. When the software is successfully
    updated, a screen is displayed
    indicating that the update process is
    completed.If the update has failed, check the file
    in the USB device and try Software
    Update again.
  12. Press POWER to turn off the player.
  13. Remove the USB memory device.
Posted on Oct 18, 2009
SOURCE: how do i unlock the region code on my new sharp
You could try >Menu >settings >parental control> "set a 4 digit password" then change the region code to your country.
Unless you have my problem and updated the firmware incorrectly and nothing changes it...
Posted on Feb 21, 2010
SOURCE: Samsung Blu ray code for direct tv remote
is there any remote that i can program tv,cable,direct tv,and blu-ray player all in 1
Posted on Jan 27, 2011
My Blu ray player keeps flashing an "RC-1" error anytime a button is pressed on the remote.
Remote command mode is different to the unit. Try resetting the remote by doing the following;
While unit is on, but no discs loaded or playing, remove the batteries from the remote (as if you were replacing them), press any button on the remote to clear its buffer, then, if the batteries you removed are OK, re-insert them. Point remote at the player, press and hold 1 and ENTER/OK buttons together for 10 seconds, then release. This should restore your remote's command to the original default mode, and it should control the player fully.
Panasonic and some SONY units operate on this principle with remote command modes (these differ between models). RC1 / DVD1 / SET1 is usually the default.
Very easy to do, takes a few seconds, and costs nothing.
Apr 18, 2011 | Sharp BD-HP21U Blu-Ray Player
I am seeking software update for my BD-HP210U Blu-Ray Player.
You should have an option in the menu which says Update Firmware, failing that the Sharp website will have the update which can be burnt to disc and inserted into your player.
May 30, 2010 | Sharp BD-HP21U Blu-Ray Player
My blue ray bd 21 wont play some movies im told
My advice is to contact the company that makes the unit and ask them if it requires an upgrade. Let me know what they say so i may advise further. Thanks.
Apr 16, 2010 | Sharp BD-HP21U Blu-Ray Player
Need to find software update for sharp blu ray BDHP21 or firmware udate as it wont play certain movies
my sharp aquos will not play certaian blue ray I've exchanged the the disk a couple of time...are there any updates that I need
Mar 01, 2010 | Sharp BD-HP21U Blu-Ray Player
I just got a Samsung Blue-ray disc player program the remote
need code to program the remote for my bd p1590 to control my panasoniic hd tv and the codes that are in the manual dont work
Dec 30, 2009 | Samsung BD-P1590 Blu-Ray Player
I have a sharp bd-hp21u model blu-ray disc player. I am trying to use a brand new blu-ray disc. However, it will only play for 17 seconds and goes blank. What shd I do? It will play regualr dvd's.
Verify version of the firmware, if it is older then PN9062300, you will have to upgrade it. Newer version of the firmware can be found here. For instruction on upgrade procedure refer to the owner's manual.
Dec 28, 2009 | Sharp BD-HP21U Blu-Ray Player
Sharp AQUOS Blu-ray Disc Player Logo
1,767 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
