Question about Frigidaire GLEF396 Electric Kitchen Range
Self cleaning oven door lock is stuck and buzzing
My daughter opened the oven door near the end of the self cleaning stage and now the latch does not move back. The oven door buzzes when opened and there is smoke coming from the top of the control panel, as if something is overheating. We ran the cleaning cycle for another two hours and when it was done, the latch still did not switch back. Can I still use the oven until we get a repairman in? Does it sound like the locking mechanism is broken? The range is about five years old and is a Whirlpool Gold from Sears
    Genius:
  • 2,920 Answers
You can still use the oven i would gt someone out as soon as you can to get the lock released but yes you can still use the oven
Posted on Feb 04, 2009
My old Westinghouse range self-clean oven door latch is in the locked position with the door open. The door cannot close with the latch in the way. The clock is making a buzzing sound.
The first question I have for you is, how did the latch even come out in the first place? Normally the latch comes out ONLY when the oven has been set to cleaning mode.
The buzzing noise is probably there because the oven 'thinks' it has completed the cleaning or that the latch is out.
you may have to take the door off the oven and remove the inner cover to see if there is a way to get the latch to retract. Otherwise, call a professional to come take a look at it.
Nov 11, 2017 | Hardware & Accessories
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
How do I know when my stove is done self cleaning?
to get all the detailed instructions
just click this link directly
http://www.applianceaid.com/selfclean5.html
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
thanks.
Nov 11, 2009 | Kenmore Cooktops
Whirlpool self cleaning oven Accubake. 2 yr old
Hi
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Cleaning over but lock light will not goff and i can not open my oven
May 20, 2009 | GE JKP15 Electric Single Oven
Door locked after shutting down cleaning cycle earlier than
May 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning oven door won't open
May 15, 2009 | Ovens
Door won't open after cleaning
After self cleaning the range the door won't open....
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Apr 01, 2009 | GE Kitchen Ranges
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Door won't open after self cleaning.
it is locked the leaver has become detached from the door latch and even though the leaver moves the lock part doesn't have you tried it lately push in on the door and try to move the leaver if that doesn't work get a wire coat hanger make a Small hook and from the left hand side see if you can snag the hook and pull it over ive done that before theopen end of the hook should point up start just abve the door gasket about halfway over well i cant reamber which way the latch moves but im sure you can figure it out push slighty in on the door after you hook the latch but try to open it fist some have asensor that wont let the oven door open till its cool enough to be safe let me know
Dec 31, 2007 | Ovens
Frigidaire GLEF396 Electric Kitchen Range Logo
409 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
