Question about Hoover Vacuums
Hoover freespace noise light on for no reason
I got my hoover freespace about 4 months ago, and it worked just fine until a couple of days ago. The light indicates that the filter needs to be cleaned eventhough i did this already, and the hoover makes a very loud noise as if something is blocking the airway. I checked and there is nothing there. How do I fix this?
  • 833 Answers
SOURCE: freespace pets cylinder hoover 2000w tfc6207
It is possible that the belt is broken.
Posted on Jan 02, 2008
  • 25 Answers
SOURCE: Hoover Light on
ALTHOUGH MOST FILTERS SAY WASHABLE THEY DO STILL NEED TO BE REPLACE AS WASHING THEM SHRINKS THE FILTER AND EVENTUALLY CLOSES THE AIRWAYS. WHICH ALSO IF NOT REPLACE WILL OVER HEAT MOTOR IN MACHINE AND CAUSE MOTOR FAILURE.
Posted on Mar 27, 2008
GoVacuum1
  • 6 Answers
SOURCE: No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
  • 11 Answers
SOURCE: Looud noise and no suction
the motor impella is blocked. you have to access this from the bottom
Posted on Jan 23, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: Just bought this a month and a half ago - used 3
Is there any thing caught in the roller brush? Carpet string, plant leaf,Coin?
Try removing the suction hose and putting a broomstick through it to unclog any thing you may not be able to see.
At the area where the roller brush is look at the suction hole, feel with your finger if anything may be caught inside.
If all is clear you may have a defective motor.Return it while you still can.
Thanks and good luck.
Posted on Jan 12, 2010
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Power switch doesn't work
so replace the power switch you can get one at guarantee vacuum and sewing center
Mar 19, 2014 | Hoover Freespace Evo Pets TFV2015
HOOVER Freespace TFG 5123 - Red Light?
Check the entire flow path from intake to bag. You may find it is clogged.
Dec 12, 2013 | Vacuums
My Hoover TFV2015 has excessive sparking at the motor.
get new one fast do not turn on anymore, if you have a warrenty i would take it back if not look for a used one, hope this helped, jamie
Dec 14, 2012 | Hoover Freespace Evo Pets TFV2015
Hi, I have a Sebo X4 which is almost 3 years old. I haven't had any problems with it until the last couple of days when I notice a slight screeching noise when in upright position, coming from the roller...
I dismantled the top part of the machine from the bottom and there stuck right down in the bowels of the tubes was a piece of card, a dress label! somehow it was only making a noise when the machine was in an upright position. It took a bit of stretching and maneurering but once it was out the problem was solved.
Jun 11, 2009 | Sebo X4 Bagged Upright Vacuum
Hoover only two years old an stopped working!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=564949
Hoover only two years old and it stopped working!
Posted by baby_nurse on May 02, 2008
My Hoover self propelled wind tunnel was working great until a couple of days ago when it started shutting on and off while vacuuming. I thought it was the outlet but when I plugged it into two different outlets it did the same thing. Then finally yesterday it just stopped working it won't even turn on when plugged in. I thought it was the switch but it is not. Is it the motor? Has the motor burned out? Do I need to buy a new one? Help!!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Hoover U6616-900 WindTunnel Bagless...
Hoover Light on
Mar 27, 2008 | Vacuums
Freespace pets cylinder hoover 2000w tfc6207
Dec 31, 2007 | Vacuums
Brushes are not moving
You should be able to get a manual from Hoover.
Oct 21, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
24 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
