Question about Epson PictureMate Photo Printer
Claims new ink cartridge is low...
I installed a new cartridge and the first print came out with horrible lines, so I ran the head cleaning utility. After 10 runs, the confirmation print still has gaps and now the printer claims that the ink is low, so it won't run the utility. When I run the status check utility, it shows the ink cartridge as being full.
  • Anonymous Apr 02, 2009
    Printer says cartridge is 'low' or 'empty' due to running head cleaning too many times. The cartrdige is NOT actually empty.
    An expert whose answer gotĀ voted for 100 times.
  • 79 Answers
Hello, at this point I would suggest COMPLETELY uninstall your photo printer, reboot your system and reinstall. Hopefully this helps.
I will tell you though, usually if after running cleaning utilities, the picture still has lines and spaces, could be due to print heads drying up and unable to output the proper amount of ink. This happens alot when people are not using their printer often enough to keep the ink flowing properly.
Recently I had to replace a printer that I had not printed on in like 3 months, the print heads dried up/ clogged up. And the new ink I had just purchased was a waste of money. Had to replace entire printer.
Posted on Apr 24, 2009
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
Problem with printhead please consult user guide
Use the printer's utility program to self-clean the printer. This process may need to be repeated as many as 5 to 10 times. Often this will resolve the problem.
Turn the printer off, preferably overnight, if the self-cleaning utility has not worked. The ink may need to soften before the self-cleaning utility will be successful. Turn the printer on and try the self-cleaning utility again several times.
Determine from the owner's manual where the print head is located. Epson printers, for example, are usually in the printer. Many other brands place the print head in the cartridge.
Remove the cartridge. For models where the print head is in the printer, drop seven to 10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area. This is the hole where the ink flows into the head from the cartridge. Run a few self-cleaning utilities. If necessary, allow to sit a few hours or overnight and repeat the self-cleaning utility.
Soak the cartridge print head in hot water if the print head is in the cartridge. Allow to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
Place the cartridge print head in isopropyl alcohol if the hot water soak did not unclog the print head. Leave the print head covered in alcohol overnight. Use a damp paper towel to wipe off the print head area. Dry carefully. Try the self-cleaning utility again.
Purchase a new cartridge if the alcohol soak did not unclog the print head in the cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the print head.
Mar 01, 2011 | Office Equipment & Supplies
Lines when picture is printed
Usually the print head just needs to be cleaned. There's a Brother utility included with your printer, that you can select Clean. Run this. Afterwards run a print test page to see if it has cleared up your problem. If the unit STILL does it, your print cartridges may be low, or perhaps a 3rd party print cartridge was used, and the printer doesn't really KNOW how much ink is in them.
I believe the print cartidge itself, IS the print head, thereby, when you install a new cartridge, you renew the print head. which is good. However, I don't know on this model. If not, the print head, can be cleaned with a cotton q-tip with a little alcohol.
I hope this helps.
Jan 28, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Keep ink cartridges out of the reach of children and do not drink the ink.
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Check color ink always blinks and does not allow to do any job.
Make sure that you installed the correct ink. It is not enough for it to fit, the numbers on the cartridge have to match those on the cartridges you replaced. You may also have problems with off brand ink that claims to work. Use Kodak ink. Also, many of the Kodak have the ink jet nozzle on the printer, not the cartridge.You can try cleaning in and around the cartridge casing, especially on the copper areas, with an alcohol swab. Then run the cleaning utility on the printer 2 or 3 times.
Nov 09, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Black wont print I've cleaned the print heads and there is ink it just keeps printing lines. It's like the print nozzle is cloged. I've cleaned the print heads so much that I've had to take the cartridges...
Hi and welcome to FixYa,
A possible workaround if it is an Epson brand is to use "Deep Cleaning" feature of a 3rd party utility program. Please check for model compatibility and if workable, download, install and run "SSC Service Utility". Additionally, there are special cleaning cartridges that contain cleaning solution rather than ink that maybe used in this process.
Good luck and thank you for asking FixYa.
Aug 08, 2009 | Epson Office Equipment & Supplies
Carriage cycles normally but no ink on paper.(Stylus color 880)
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
Epson PictureMate Photo Printer Logo
188 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
