Question about Acer Aspire™ T180 PC Desktop
Ram and Bios issue
Someone please help I have 2 sticks of ram installed and only one is showing up. It will not boot with only one stick of ram installed I get the infamous beeps when only one is installed. I went out and bought another stick( all are the same brand and speed) thinking I had one bad well that didnt work. I have used CPUZ and it only shows one installed even though there are two in the slots. I have tried every possible config in the slots. It will NOT boot with they are in the same colored slots or as said before with only one installed. Running vista 32 on acer T180 Tried updating Bios but Bios does not seem to upgrade either Please any info would be greatly apperciated
  • 4 more comments
  • ccfdman1 Feb 04, 2009
    No beeps except for the standard one beep as everything loads
    Managed to get bios to update an oversight on my part also managed to get both into the same colored slots tried clearing CMOS did not work either
    two 1 gig sticks
    i m sorry i keep posting i see what you were asking I m tired and its late 2-3 beeps when the one stick of ram is installed
  • ccfdman1 Feb 07, 2009
    ok well i found the first three slots wont take ram only fourth slot will take ram I can have all four slots full and cpuz can only see slot 4 any ideas????
  • DEKR
    DEKR May 11, 2010
    are you getting any beeps and how much ram you talkin
    Genius:
  • Acer Master
  • 1,102 Answers
Did you upgrade to vista
Posted on Feb 04, 2009
  • DEKR
    DEKR Feb 07, 2009
    i don't think your other ram is compatible
    or you are trying to use too much ram
    go into bios setup and check ram in there
    then restore to default settings at bottom of page f10 to save and exit
  • 38 Answers
Make sure your other stick of Ram is installed properly, once that is done make sure that the stick of ram is compatible with that computer. After that even, check to see if your computer is capable of processing that amount of RAM.
  • sylus16 Feb 07, 2009
    The drives probably need to be upgraded, if not that then the ram ports are just busted. What was the model and series of your computer.
What will you do if the cpu doesn't work?
Here is my flow chart.
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you are the victim of a bad BIOS flash, don't freak there are some options. First off, if the computer (or motherboard) is still under warranty the Computer (or motherboard) can be sent to the Vendor for a BIOS reprogramming.
If you are a DIY PC builder and the warranty is expired you can take out the bios chip and sent it someone who reprograms BIOS chips or you can buy a brand new chip form them. I will show you my people.
http://myworld.ebay.com/***angelb***
or
http://stores.shop.ebay.com/Bios-Depot__W0QQ_armrsZ1
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen.
Jul 08, 2009 | Acer Computers & Internet
I put a new power supply in, still get nothing but green light in back any ideas?
or
Jul 07, 2009 | ASUS M2N-E SLi Motherboard
We bought and installed a new motherboard and power supply for our Dell Optiplex GX 280. After connecting all the connections and power cord, the computer would not turn on. On orange light is lit on the...
or
Jul 07, 2009 | Dell Optiplex GX280 (99301) Motherboard
Cooling fan does not come on no power to the computer
or
Jul 07, 2009 | HP (158800-001) for Compaq Presario 1246,...
Hi, Computer does not start. "F" is displayed on Abit A17 GURU motherboard.
or
Jul 05, 2009 | Abit A17 Guru Motherboard
Gateway gt4010 blue light does not come on the fan run no vidio
Hi
Please check the cable running between the monitor and processor unit. Also check whether the processor's inside fan is working or its just the cooling fan which is working. Also check whether the RAM is firmly fixed in the slots.
Please accept the solution and revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Gateway GT4016 Desktop PC
Power button not working power button not working even when mains is connected
or
May 03, 2009 | HP Computers & Internet
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
Installing 2 sticks of 1 gb ram = DRAM error beeps
If the computer is working with one gb stick and not the other, try this:
Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
Jun 13, 2008 | Gigabyte GA-K8NS Motherboard
Ram DDR2
Hi Terry, you're board, PC Chips P23G only supports a max memory of 2GB. Please check pg. 9 of your manual, Installing Memory Modules.
Please be noted you can NOT use DIMM DDRII 1~2 (DDR2 533/400) and DIMM DDR1~2 (DDR 400/333) simultaneously. Only use either DDR2(533/400) or DDR(400/333) memory modules! (You should check the spec's of the other board before inserting memory that may not be supported). (You can damage the memory)
Click the link listed below for you're PC Chips P23G board.
Suggest you save this link to you're favorites.
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=92&LanID=2&DetailID=387&DetailName=BIOS
You will notice there is a fix for:
Patch code to fix REALTEK clock buffer sometimes couldn't detect DDR2.
Once there, click BIOS. Scrol down to the bottom of the page & read special notes. Than click the drop down menu & pick a download site. Creat a folder on you're desktop to store the download. Uncompress the .zip file. You will than have a folder named 070115 & a ROM file named 070115.ROM
This bios flash program requires you to use a floppy disk drive to flash the bios.
Follow the instruction at this link to flash you're bios.
http://www.motherboards.org/articles/guides/42_1.html
If you find to hard to folow you can pick another from this google search site.
http://www.google.com/search?hl=en&q=how+to+flash+a+bios+&btnG=Search
Good Luck! & Take your time.
Have more questions, feel free to ask.
Mike
How to vote you're expert.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 12, 2008 | PC Chips P23G Motherboard
Acer Aspire™ T180 PC Desktop Logo
163 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
