Question about Toshiba TheaterWide 46HM94 46" Rear Projection HDTV
Toshiba 52 inch Screen
Between the screed and the outer screen there is dust and cobwebs there and I bneed to know how how to pop off the outer screen
    Genius:
  • 2,920 Answers
The outer trim just pops loose behind that there are several screws the plexi is held in by those crews i believe so once you take the screws out you can clean between the two screens
Posted on Feb 04, 2009
Broken Screens the inside one and the outsid one
Toshiba or any Toshiba parts distributor. Do a goole search. The outer is called the Lenticular screen and the inner is the fresnal screen. Not hard to change.
Nov 17, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
The screen "shield" on my tv broke, i need a replacement part #
mine got broke also
i called the local tv repair shop, they had the piece in stock and it was 100.00
it was and easy replacement for me too do it myself!!!!!!!!
Jun 01, 2009 | 1992 Chevrolet Camaro
The screen on our 52 inch TV needs cleaning-inside and out
The outer screen is a protective screen. it is just glorified plexiglass. just use a soft cloth slightly damp.
Apr 09, 2009 | RCA D52W19 52" Rear Projection Television
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Tv screen is cracked
try www.tvscreenprotectors.com
they help with finding discontinued tv screens
Apr 29, 2008 | Toshiba TP55H60 55" Rear Projection...
Replacement of outer screen for a Toshiba TP50H60 projection tv
A frosted sheet of plexiglas works well. I put a plexiglass screen on my own 62 inch projection TV. It must be frosted to received the image being projected.
Jan 03, 2008 | RCA R52WM24 52" HDTV Projection Television
Clean behind the screen.
hey,
to packerfan. yesterday i did some thinking. i had the same problem w/ my toshiba 57". cobwebs in the viewing screen. i found the solution to be simple. take the front panel off. it's just held on by some clips. remove the black cardboard cover that protects the wiring. it's simple just w/ a screwdriver. attach a feather duster w/ duct tape to a 2 ft. dowel or longer if your arms are short.there are several places you can go up to dust. i found that if you clean 1/2 of the screen then the other 1/2 you should be done all tolled in about 10 mins. presto! my screen has never looked so good.too bad it's taken me 3 yrs. to figure it out. hope this solution works for you as great as it worked for me!!!
Nov 24, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
How do i clean my screen
  CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
Oct 29, 2007 | RCA P52926 52" Rear Projection Television
Toshiba TheaterWide 46HM94 46" Rear Projection HDTV Logo
156 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
