Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Stripped gear I installed a new gear and it seemed to work perfectly, 10-20 times, then quit, and when I inspected it the gear was stripped again. What is causing the gear to strip?
Try opening and closing your door by hand with the motor detached (detach it by pulling on the rope) It should open and close easily without a lot of effort. If it catches or is too heavy (possible broken spring) it will strip the gear. The door has to be working properly before you can attach an opener to it. If you lift your door up about waist high and let go of it . It should not go up or down but should stay in that position, This tells you that the springs are correctly adjusted
Posted on Feb 05, 2009
How to replace a flywheel on a ford five hundred
Remove the inspection plate and undo the bolts attaching the torque converter to the flex plate Remove transmission If you are not familiar with that procedure give the job to a mechanic. Remove the clutch if not auto again know how to replace clutch pressure plate and clutch plate. Something tells me that the flywheel isn't stripped but the flexiplate has fractured as it is unusual for the teeth of the ring gear to be completely stripped. Moving on use an impact gun to undo the bolts holding on the flywheel/flex plate Installation is reverse to removal. But I recommend you have good advice handy to do this job
PLEASE RATE THIS REPLY FOR ACCURACY
Mar 23, 2013 | 2007 Ford Five Hundred Limited Sedan
I have a sherwood cdc-5090/c/r multiple cd player - it goes on error when using open/close, disc selector, disc skip. have tried troubleshing guide but doesn't seem to work.
The problem is in the CD loading bays, quite often the gears will ware over a period of time causing error messages because it is unable to complete the cycle. The second issue is the timing gears go out of sink because one of the CD'S gets jammed against the other causing it go out. The repairs are tricky because of the timing issue, however if gears are stripped the whole CD bay must be replaced.
Mar 10, 2012 | Audio Players & Recorders
I have a Singer 2662. It has quit picking up the thread to make a stitch.
Try a new needle. If that doesn't work, then the timing is probably off. Check for a broken or stripped gear.
Apr 20, 2011 | Singer Sewing Machines
I have a 50cc sunl scooter, and i cant put it bac in time
with the spark plug out and the valve cover removed; place a screwdriver into the spark plug hole; turn the crankshaft until the valves are all the way up and, not moving as the piston just starts to go down in both directions; (use the screwdriver to see this) this is TDC or, top dead center now; you should see symbols on the faces of the cam gear and, the crank gear and, two places on the chain; line up the chain symbols with the gear symbols chain symbols facing out and, install the chain.
by the way they make a kit for stripped sparkplug holes an auto parts store will have it in case you need one again.
Jul 25, 2010 | Transport Schwinn Rechargeable Portable ...
Driving a 2003 Ford windstar. Went to pass and
Very common on this make and model trans, pump drive splines inside torque converter strip out and pump is not turning, Most times there is no damage to pump shaft. Remove trans and remove torque converter, inspect the splines at the very bottom of the hub hole. If stripped out inspected pump shaft splines which are the smaller center splines coming out of trans, if ok replace torque converter and re-install trans, change out fluid, clean any metal from magnet and replace filter, fill with fluid and verify proper operation.
Mar 01, 2010 | 2003 Ford Windstar
My speedometer quit working on my 1997 ford f150. how do i fix this? is this the cable unplugged and where is it located?
a vehicle speed sensor is located on the transmission on some models. if a cable is attached to yours inspect the gearing behind it for it may be stripped out
Feb 25, 2010 | 1997 Ford Ranger SuperCab
A drive gear seems to slipping when the blade cuts into thicker s
Yes you can get parts for it.The gears tend to strip the teeth.
Jul 06, 2009 | Homelite Expand-It Hedge Trimmer...
Yz 250 2008 possible 5th gear stripped?
I doubt that any gears are stripped. Believe me you would have known it when it happened at 40mph which is where you would have to be in 5th gear. This is a bent shift fork. The actual gear is fine. The slider gear is not moving far enough to engage with 5th gear. The YZ does tend to have this problem in 5th and 1st. "Dirt rider Magazine " did a story on it. Best to let the shop do the repair as the entire motor gets torn down into about 100 parts.
Please rate this solution. Thanks!
Apr 08, 2009 | Yamaha YZ 250 Motorcycles
Stripped beater gear
It is terminal. This is the fatal design flaw of these mixers. The gears are made of soft plastic and strip easily. Even the gear housing is plastic that is either glued or melted together to make it unserviceable. I have never suceeded in finding the part from either Sunbeam or one of the many appliance repair places on the web (who charge the cost of a new mixer for repair). Sunbeam does not repair them; if it is determined to have malfunctioned due to quality or design while under warranty, it is simply replaced with a new one. I had mine replaced under warranty twice, each time they sent me a new one complete with extra bowls and beaters. Now I have three sets of bowls and beaters and no functioning mixer.
May 25, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Something got stripped in my VillaWare 5787
you may have stripped the motor gear sek out a new unit
Dec 27, 2007 | VillaWare 5787 Double Smoothee Work Top...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
78 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
